Old Jan 20, 2013, 10:36 AM
mike_victoriaBC is offline
Find More Posts by mike_victoriaBC
victoria, bc
Joined Oct 2003
My first hull was one of Don's boom boats using a Marx Schottel unit - that goes back a few years! Would have liked to have got one of his smaller boom boats. His detailed fittings do get around - could use more hatches, deck details.
That looks good Charlie.
mike_victoriaBC is offline Find More Posts by mike_victoriaBC
Old Jan 24, 2013, 06:13 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Mike, Thanks!
I now need to finish the little things on mine, and, try to get Troy's twin screw, ready for Riverside. Pat, I know that feeling. Charlie
CaptCB is offline Find More Posts by CaptCB
Old Jan 29, 2013, 09:32 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Latest Progress
I finally got trays made to hold the batteries. At 4.4 oz. each, in a boat that only weights 3.75 lbs., if they shifted much, I would be in trouble. They have been held in place by double sided tape till now. I want to be able to swap them out at regattas. The trays sides are 1/2'' high, and should keep the batteries in place. I also did a temporary mount for the on/off switch. I would like to do a cleaner wiring harness, with plugs on the motor and ESC, when I have some more time. Also got the horn painted and mounted. Charlie
Old Jan 29, 2013, 11:31 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Looks good Charlie.
Hey, I know you are 'well off' but seriously, gold bars for ballast?
Kmot is online now Find More Posts by Kmot
Old Jan 29, 2013, 11:40 PM
fooman2008 is offline
Find More Posts by fooman2008
United States, ID, Rexburg
Joined Sep 2008
I have seen more than a few people make a piece (like your stack in the last view) the on/off switch. The smartest way to do it a simple slide attached to switch, up is off (that way you don't accidentally turn it off launching it).
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Jan 30, 2013, 12:13 AM
MILLERTIME is online now
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
" gold bars for ballast"
Must be nice to have money.
MILLERTIME is online now Find More Posts by MILLERTIME
Old Jan 30, 2013, 09:56 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Brass Ballast
I like using brass flat bar for ballast. In a semi-flat bottomed boat, it works good, is clean, and keeps the weight low. It weighs 77% the weight of lead, and is a lot cleaner to work with. Charlie
Old Jan 30, 2013, 08:12 PM
JOHN SCALE BOAT is offline
Find More Posts by JOHN SCALE BOAT
JOHN SCALE BOAT's Avatar
United States, PA, Slatington
Joined Feb 2007
Another option for the on off switch is in a unused bit.
JOHN SCALE BOAT is offline Find More Posts by JOHN SCALE BOAT
Old Jan 30, 2013, 09:25 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Thanks guys for the ideas. All my bitts are reinforced for towing in tug competition. I have seen guys hide a switch control rod under various deck details. My concern with that is that my deck can run wet, and, I will run at a contest in the rain. So all my boats are pretty sealed up, the exhaust stack being the only vent in the hull, once the house is set on. Charlie
Old Jan 30, 2013, 10:51 PM
Joined Sep 2008
Had a though about an idea I did see once (though it was on a truck) the on-off switch was rigged to the dummy steering wheel, turn it to the right for on, back left for off.....just an idea
Foo
Old Feb 09, 2013, 03:43 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
woodybob is doing great! How are the rest of you doing on your builds?? I have had to take several weeks off from the boats, but I hope to be back on both soon. Charlie
Old Feb 12, 2013, 02:39 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Adding Details
Just finished prepping, and adding, more details to the stern deck. I am enjoying having the bulwarks, I can add details, and not catch my tow line in them. Charlie
Old Feb 12, 2013, 04:04 PM
keith S is online now
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
need to get back on mine as almost there.......just been a bit worn out lately ( and not in the good way).
keith S is online now Find More Posts by keith S
Old Feb 12, 2013, 07:46 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
it's all in the details...
woodybob is offline Find More Posts by woodybob
Old Feb 17, 2013, 06:15 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Progress on Troy's Twin Screw Boat
Here are some photo's of where I am on Troy's twin screw boat. From the deck up, it will be typical kit, except for the 2 exhaust stacks. Below and inside the hull, is where things will be totally different.
Build Log 1/32 Truckable Tug JOHN SCALE BOAT Scale Boats 35 Oct 20, 2012 07:31 PM
Question 1/24 Truckable Towboat hull in fiberglass CaptCB Micro and Sub-Micro Boats 3 Apr 01, 2012 12:11 AM
Sold Douglas Greg Tug Hull 1:24 scale (1:25?) joe31hat Boats (FS/W) 1 Dec 04, 2011 08:29 AM
Discussion fiberglass sport hull for the ep-1 redlined_b16a Dock Talk 0 May 18, 2011 12:07 AM
For Sale Fiberglass PT hull compatible for 1/30 Dumas kit Tollytime Boats (FS/W) 4 Mar 22, 2011 10:50 PM
