Old Sep 25, 2012, 04:09 PM
keith S is offline
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
could almost call them Springer Liite or a Springer "Mini Me"...... big difference is the power to size ratio so far. i think mini ha an advantage..
keith S is offline Find More Posts by keith S
Old Sep 25, 2012, 05:07 PM
SUGAR COATED is offline
Find More Posts by SUGAR COATED
Joined Aug 2012
size matters..maybe
I have run from 180 to 550 brushed in all the sizes of springers and similar shaped hulls. At no point has anyone thought that some testing with some published results of the different size motors and running hardware was necessary, as in this build. Just some pre-Modonna's building with bits laying around the shop or hand made. What is the cost?..most peoples time, so far, and the lack of respect for the builders ability to properly bring a product to our market place ,with the proper support and details required to succeed.
What ever happened to the guy that designed the hull? Why did he delete all of his posts (or who ever did)?
SC
SUGAR COATED is offline Find More Posts by SUGAR COATED
Old Sep 25, 2012, 09:14 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Some more photo's from Riverside
Some more views, for those that are building. The one where I am going around the Airplane, it got breezy, and the boat still handled good.
CaptCB is offline Find More Posts by CaptCB
Old Sep 25, 2012, 09:24 PM
capntroy is offline
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Yep, I was really happy with the handling of the boat during the very small amount of time that Charlie let me hold the transmitter...
Charlie has a first generation rudder on his boat that doesn't have the large defined whale's tail that the rudders in the kits have, so I'm looking forward to seeing some sea trial reports when the other lads get their boats running...
capntroy is offline Find More Posts by capntroy
Old Sep 26, 2012, 06:00 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Motor and battery info
The motor that I chose to run was a Speed 400, 7.2v, from ElectriFly. The 385, just did not have enough power. The amp draw at full throttle, with the Prop Shop prop, is just about 3amps. That should help all of you building one, to decide on your running gear, and batteries. No need for everyone to experiment. CB
Old Sep 26, 2012, 06:05 PM
capntroy is offline
capntroy's Avatar
Orange County, CA
Joined Nov 2007
This is the info on the motor that Charlie installed, they call it their "T-400"
http://www.electrifly.com/motors/speed400.html
He mated it with the Maxx Products ACC347 gearbox and the 3:1 ratio, it's a pushy little boat...
http://www.maxxprod.com/pdf/acc347instructionsheet.pdf
Old Sep 26, 2012, 09:25 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Originally Posted by CaptCB View Post
...No need for everyone to experiment. CB
Heck...I'm throwing in an Astro Flight .035 Cobalt, hooked up to an old school Astro Flight belt drive. I think it'll have a 2.86:1 ratio. Even managed to squeeze in a 3/16" prop shaft, stuffed into an 11/32 tube, with a small amount of hull alterations. Spinning a four blade screw with just enough room to clear the space provided.
Experiment all you want is what I say!
woodybob is offline Find More Posts by woodybob
Old Sep 26, 2012, 09:38 PM
gpzy is offline
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
Originally Posted by woodybob View Post
Heck...I'm throwing in an Astro Flight .035 Cobalt, hooked up to an old school Astro Flight belt drive. I think it'll have a 2.86:1 ratio. Even managed to squeeze in a 3/16" prop shaft, stuffed into an 11/32 tube, with a small amount of hull alterations. Spinning a four blade prop with just enough room to clear the space provided.
Frankenboat !
gpzy is offline Find More Posts by gpzy
Old Sep 26, 2012, 09:43 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Woodybob
Are you trying to out do Gene Sauter, in the small boat class?? CB
Old Sep 26, 2012, 09:58 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
He just wants some horsepower.
Horsepower (3 min 7 sec)
Kmot is offline Find More Posts by Kmot
Old Sep 26, 2012, 10:07 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
I'll have to check out that video once I land on a compter that allows video.
Old Sep 26, 2012, 10:40 PM
dostacos is offline
Find More Posts by dostacos
some what irregular
dostacos's Avatar
Diamond Bar, California
Joined Feb 2004
I think he needs to adjust his...ah, dive planes
dostacos is offline Find More Posts by dostacos
Old Sep 26, 2012, 10:52 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Kmot
At full throttle, with out a barge, I had water flowing over the bow, similar to that, just not as bad. But the boat stayed dry inside. CB
Old Sep 27, 2012, 11:15 AM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Nice one Tom, sure way to keep to deck clean.
Old Oct 07, 2012, 03:14 PM
dostacos is offline
some what irregular
dostacos's Avatar
Joined Feb 2004
so you are NOT using 6V batteries
Build Log 1/32 Truckable Tug JOHN SCALE BOAT Scale Boats 35 Oct 20, 2012 07:31 PM
Question 1/24 Truckable Towboat hull in fiberglass CaptCB Micro and Sub-Micro Boats 3 Apr 01, 2012 12:11 AM
Sold Douglas Greg Tug Hull 1:24 scale (1:25?) joe31hat Boats (FS/W) 1 Dec 04, 2011 08:29 AM
Discussion fiberglass sport hull for the ep-1 redlined_b16a Dock Talk 0 May 18, 2011 12:07 AM
For Sale Fiberglass PT hull compatible for 1/30 Dumas kit Tollytime Boats (FS/W) 4 Mar 22, 2011 10:50 PM
