Old Aug 22, 2012, 03:09 PM
capntroy is online now
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Originally Posted by CaptDH View Post
Young Padwan I am not. Get building!
C'mon Darrin, you know you have time to fit one of these in between your airboat build...
capntroy is online now Find More Posts by capntroy
Old Aug 22, 2012, 03:54 PM
CaptDH is offline
Find More Posts by CaptDH
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
I don't even have time for the air boat right now.
D
CaptDH is offline Find More Posts by CaptDH
Old Aug 22, 2012, 05:19 PM
woodybob is offline
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Springer thread anyone?
woodybob is offline Find More Posts by woodybob
Old Aug 22, 2012, 07:01 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
It is defiantly NOT a Springer! A Springer is 18'' long x 8'' beam, and cannot easily be carried on an Airliner, to go to events anywhere. CB
CaptCB is offline Find More Posts by CaptCB
Old Aug 22, 2012, 07:14 PM
louie R/C NUT is offline
Find More Posts by louie R/C NUT
no such thing as to many boats
louie R/C NUT's Avatar
United States, NY, New York
Joined May 2010
That's cool carry on I can take it on vacation nice what until my girlfriend finds out hehe.
louie R/C NUT is offline Find More Posts by louie R/C NUT
Old Aug 22, 2012, 07:18 PM
woodybob is offline
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Originally Posted by ralphhager View Post
...Please put your build thread here so we can track it, and use your ideas. Thanks Ralph
Originally Posted by CaptCB View Post
It is defiantly NOT a Springer! A Springer is 18'' long x 8'' beam,... CB
"Springer thread" was a reference to that quagmire on DockTalk, not to this little jewel.
Build thread coming...
Old Aug 22, 2012, 07:22 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Oh no! Don't let these get swallowed up in that black hole of a thread! Dozens of Springer's have been lost in there.
Kmot is offline Find More Posts by Kmot
Old Aug 22, 2012, 07:29 PM
capntroy's Avatar
Orange County, CA
Joined Nov 2007
I knew what you were cooking Pat! Looking forward to your build...
I should have the instruction sheets emailed to you guys in a day or so.
Old Aug 23, 2012, 07:08 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
My running gear layout
Now that some of you have your kits, these photo's should give you an idea of how I installed my rudder, prop, and shaft. Notice that there is a THRUST WASHER, between the prop and stuffing box. There will be one on the universal drive end to. If you need, I can give you the prop hub to skeg and rudder spacing that I used, but it may be different, depending on the prop used. Troy and I are using Prop Shop props. I ran the rear edge of the rudder, even with the back of the hull. Charlie
Old Aug 23, 2012, 08:20 PM
Joined May 2010
what size prop is that.
Old Aug 23, 2012, 09:56 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Running Gear in Boat #1
We used a 1.5'' dai. 4-bld, it fits a 4mm shaft. If you are using a gearbox, as we are, the part number is PS1517/4R. We got both props, and shafts/stuffing box's from Harbor Models. I turned the tail cone off the prop's, and shortened the stuffing box and shaft. I also added a grease tube to the stuffing box. The rudder stuffing box was made using K&S tubing, and some bushings from Northwest Shortline. The .060'' thrust washers I used, I made from black DELRIN. Charlie
Old Aug 23, 2012, 10:25 PM
Joined May 2010
Thanks for the info.
Old Aug 24, 2012, 11:47 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Our running gear choices
This is the list of running gear, and sources, that Troy and I picked for our boats. We plan on USING them, so we are using good equipment, that should last. The gearbox is a smaller version of the one I have had in COOS BAY, for the last 5+ years, I also like the Heat Sink motor mounts, just extra safety. Charlie
Old Aug 24, 2012, 02:59 PM
dostacos is offline
Find More Posts by dostacos
some what irregular
dostacos's Avatar
Diamond Bar, California
Joined Feb 2004
where do we get the motor, mount and gearbox?
dostacos is offline Find More Posts by dostacos
Old Aug 24, 2012, 04:02 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Truckable Parts
The motor mount and gearbox, are from MAXX Products. The motor can be any 6V, LOW DRAW, Med RPM, 380-400 size motor. The gearbox comes with 3 pinion gears, approx. 2-1, 2.5-1, and 3-1. Troy may still have some 385 motors, from when he owned Harbor Models. I am going with the 3-1 gears, easier on the motor, and longer run times. As for the glue question above, I would use TENAX-7R. liquid solvent , for the Styrene, and GORILLA Super Glue, when gluing parts that are not all styrene. Slight sanding (180-220) to have a surface for the CA to grab, will make for a stronger joint. CB
Build Log 1/32 Truckable Tug JOHN SCALE BOAT Scale Boats 35 Oct 20, 2012 07:31 PM
Question 1/24 Truckable Towboat hull in fiberglass CaptCB Micro and Sub-Micro Boats 3 Apr 01, 2012 12:11 AM
Sold Douglas Greg Tug Hull 1:24 scale (1:25?) joe31hat Boats (FS/W) 1 Dec 04, 2011 08:29 AM
Discussion fiberglass sport hull for the ep-1 redlined_b16a Dock Talk 0 May 18, 2011 12:07 AM
For Sale Fiberglass PT hull compatible for 1/30 Dumas kit Tollytime Boats (FS/W) 4 Mar 22, 2011 10:50 PM
