Old Mar 18, 2012, 10:14 AM
A.B. is offline
Find More Posts by A.B.
A.B.'s Avatar
Calgary Alberta, Canada
Joined Feb 2008
Trouble shooting Sailmaking
I have built a set of IOM sails, using sailblocks as described in many books, and web articles. They look great finished, not much draft in them, but they will only set on one side. I made them out of 3mil PET previous try i aliggned the seams with the role but that put a huge curve in sails because then went with the curve of the roll. The current set i built i made the other way so if there was any rolling it would be top to botom not side to side.
So I can not figure out why they set real nice on one side but not the other:
*maybe i just need to get then out on the water and let the wind settle them in?
Andrew
A.B. is offline Find More Posts by A.B.
Old Mar 18, 2012, 12:31 PM
Woodbark is offline
Find More Posts by Woodbark
Whitby, ON, Canada
Joined Apr 2011
Andrew, you did not mention anything about Battens,
if you have not installed these your sail will not be able to keep the air flow attached all the way to the Leech. They are necessary for keeping the Leech from curling
Woodbark is offline Find More Posts by Woodbark
Old Mar 18, 2012, 01:37 PM
hiljoball is online now
Find More Posts by hiljoball
hiljoball's Avatar
Canada, BC, Strathcona
Joined Jul 2011
Hi Andrew.
When taking the material off the roll, even used top to bottom, it will still try to curl. Did you reverse the sheets for each panel? This helps cancel the curl.
Also 3mm sounds a bit heavy and will be stiffer and more reluctant to flip that the more normal 2mm (some use 1.4mm for the A rig jib - but it wrinkles by just looking at at????).
John
hiljoball is online now Find More Posts by hiljoball
Old Mar 18, 2012, 04:27 PM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
John
That was my first reaction too when i converted to microns. It came out as about 75 microns, whereas 50 micron mylar is pretty standard and some use only 35 micron for weak winds.
martin richards is offline Find More Posts by martin richards
Old Mar 18, 2012, 08:31 PM
A.B. is offline
A.B.'s Avatar
Joined Feb 2008
Sorry, I was wrong it is 50 microns, and battens have been installed. I did not reverse the sheets.
Old Mar 18, 2012, 09:19 PM
hiljoball's Avatar
Joined Jul 2011
I think this is the problem.
John
Old Mar 25, 2012, 12:08 PM
pocketcruiser13 is offline
Find More Posts by pocketcruiser13
pocketcruiser13's Avatar
USA, IN, South Bend
Joined Jan 2011
Ripstop nylon and kite repair tape work very well for sail making. They both come in many colors, and "flip" easily. No battans required if you use two layers of tape, (one layer per side of the sail).
pocketcruiser13 is offline Find More Posts by pocketcruiser13
Old Mar 25, 2012, 09:31 PM
Woodbark is offline
Whitby, ON, Canada
Joined Apr 2011
Do you mean using the tape in place of battens? And.... what weight of ripstop would you recommend for a one meter boat?
Discussion Need help trouble shooting controller photopilot Simulators 2 Feb 02, 2012 11:16 AM
Discussion Trouble shooting help- Axe CX Nano board El Paso Mark Coaxial Helicopters 0 Jan 09, 2012 09:48 AM
Question Trouble Shooting I think gamergeek Mini Helis 9 Dec 29, 2011 08:41 PM
Discussion video interference trouble shooting i3dm FPV Talk 57 Dec 18, 2011 07:52 AM
Help! BEV rc 5.8Ghz 200mw trouble shooting Mat Holliday FPV Talk 12 Sep 25, 2011 09:01 AM
