Old Mar 18, 2012, 09:15 AM
kdmiller6679 is offline
Find More Posts by kdmiller6679
Joined Jan 2012
First scratch foamy build
Here are some pics of my first build. It seems to be working just fine but I haven't yet taken it for its maiden flight.
<a href="http://www.flickr.com/photos/78157570@N08/6846773950/" title="photo.JPG by Kdmiller6679, on Flickr"><img src="http://farm8.staticflickr.com/7186/6846773950_9d2a0bb8bb.jpg" width="375" height="500" alt="photo.JPG"></a>
<a href="http://www.flickr.com/photos/78157570@N08/6846783744/" title="photo.JPG by Kdmiller6679, on Flickr"><img src="http://farm8.staticflickr.com/7194/6846783744_73f30e8b0b.jpg" width="375" height="500" alt="photo.JPG"></a>
<a href="http://www.flickr.com/photos/78157570@N08/6846789980/" title="photo.JPG by Kdmiller6679, on Flickr"><img src="http://farm8.staticflickr.com/7208/6846789980_c6799650cb.jpg" width="375" height="500" alt="photo.JPG"></a>
kdmiller6679 is offline Find More Posts by kdmiller6679
Old Mar 18, 2012, 09:18 AM
Joined Jan 2012
Sorry, I thought you had to upload pics and Insert the HTML code for them. I guess not how do u get pictures in the post?
Old Mar 18, 2012, 09:25 AM
Joined Jan 2012
Ok, I think my problem is I'm on a iPad. Looks like rcgroups only uses flash to upload pictures. Does anyone know how to get around that on the iPad?
rchank is offline
Find More Posts by rchank
I used to like trees
rchank's Avatar
United States, WA, Spokane
Joined Jul 2011
You can use the "Insert link" function to post a photo on a website.
If you have the photos on your computer, you click on "Attachments" and then select photos for upload.
rchank is offline Find More Posts by rchank
Old Mar 18, 2012, 09:33 AM
demondriver is online now
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
I can't wait to see this plane. . . . . it's like waiting for a movie curtain to open but the curtain is busted Lol
demondriver is online now Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Mar 18, 2012, 09:59 AM
Joined Jan 2012
OK, now i'm a computer that can handle flash. Ipad isn't cracked up as much as they say. here are the pictures. my 11 month old decorated the tops of the wings. lol
Old Mar 18, 2012, 10:12 AM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
If this is your first scratch build, congratulations it looks pretty good better than my first attempt.
Where is your CG? Looks like it might be a little tail heavy... short nose long tail servos behind the CG and large tail wheel might add up tail heavy.
Check your balance at about 1/3 of the major cord from the leading edge. This should get you close enough for tweaking.
Good luck on the maiden and welcome to the addiction.
In second look... it looks like your nose isn't that short so from the picture it looks like your CG might be in the geometric center of the plane so it might be close. Is this your design or did you do it from a pattern?
larryross is offline Find More Posts by larryross
Old Mar 18, 2012, 10:49 AM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Prop's on backwards. Flip it over before you fly it or you'll have very little thrust...
Other than that, it looks darn good for a first build. I see no reason why it shouldn't fly (other than the prop). What equipment do you have in it?
Piece is online now Find More Posts by Piece
Old Mar 18, 2012, 06:04 PM
Joined Jan 2012
I put in it
Moxie Brushless Outrunner Motor 1900KV
Moxie 30A Brushless Speed Controller 2-4S 2A BEC PROFESSIONAL
Moxie Punch Series 20C 11.1V 3S 2200mAh Lipo
8x4 prop
I ordered the prop saver but I couldn't figure out how to get it on. The o ring won't fit over the prop. Any suggestions? Or did I just get the wrong thing?
Old Mar 18, 2012, 08:31 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
How did you choose the 8x4 prop? That seems like a bit much considering your motor and battery choices.
Old Mar 18, 2012, 09:23 PM
Joined Jan 2012
Not sure, I don't really understand all of it. What prop would make sense. I did turn the plane upside down to find cg and it was about half an inch in front of the aileron servos. Does that sound and look about where cg is suppose to be
Old Mar 18, 2012, 09:48 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
You might want the CG to be a little farther forward. Generally you should start around 30% of the wing's chord (distance from front to back).
Too big a prop will make the motor draw excessive current, which will quickly fry the motor and/or the ESC. Check to see what the manufacterer recommends, and get yourself a wattmeter to keep an eye on the system.
Old Mar 19, 2012, 12:29 AM
Up-Out-&-Gone
Joined Mar 2007
Very cool little plane Mr Miller! She'll fly great!
Old Mar 19, 2012, 09:11 AM
Joined Jan 2012
this was my first attempt at building. I started with balsa wood and then found this Foamy Thread and found that it is 10x easier to work with so I think the balsa wood is no longer in my future. lol I never even got any electronics in it. It would have been a really small plane i thing to try and control.
Old Mar 19, 2012, 11:50 AM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Being a High Wing COG should be checked with the plane right side up , You do flip low wing planes over to check
Wilfor is offline Find More Posts by Wilfor
Discussion Scratch-built 28" FFF Tiger Moth biplane (first scratch build) mclarkson Foamies (Scratchbuilt) 20 Apr 04, 2012 02:39 PM
Discussion First post, first scratch build and first question.... I R Grunt Hand Launch 2 Nov 16, 2011 06:47 PM
Help! First Scratch Build EyeintheSkys Foamies (Scratchbuilt) 2 Sep 25, 2011 05:27 PM
Discussion My First Foamy Scratch Build melkor Scratchbuilt Indoor and Micro Models 3 Jul 08, 2009 09:26 PM
