This thread is privately moderated by bwoollia, who may elect to delete unwanted replies.
Old Mar 17, 2012, 06:42 PM
bwoollia is offline
Find More Posts by bwoollia
Trader Rating: 57
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Trader Rating: 57
Sold
E-Flite 3200kv BL15 Motor and 60-Amp Pro SB ESC
Working pulls out of a PZ Habu.
BL15 Ducted Fan Motor, 3200Kv SOLD
$40 Shipped to Canada and the Lower 48
Key Features
Purpose-built for the Delta-V 15 69mm EDF (EFLDF15)
Replacement motor for Parkzone Habu EDF
Ideal for 68-70mm EDF units requiring a 28mm diameter inrunner motor
Ideal for up to 800 input watts
High-quality construction with ball bearings and hardened steel shaft
6-pole design
Product Specifications
Type: 6-pole Inrunner Brushless
Size: 15-size for Ducted Fans
Bearings or Bushings: Bearings
Voltage: 11.1 - 16.8V
RPM/Volt (Kv): 3200
Resistance (Ri): 025 ohms
Idle Current (Io): 2.20A @ 15V
Continuous Current: 44A
Maximum Burst Current: 52A (15 sec)
Cells: 3S–4S LiPo power 10–14 Ni-MH/Ni-Cd battery
Speed Control: 60A brushless
Weight: 106 g (3.7 oz)
Overall Diameter: 28mm (1.10 in)
Shaft Diameter: 4mm (0.16 in)
Overall Length: 40mm (1.56 in)
60-Amp Pro Switch-Mode BEC Brushless ESC
$50 Shipped to Canada and the Lower 48
Key Features
Up to 60-amp continuous current with proper air flow, 75-amp peak
5-volt Switch-Mode BEC circuit capable of 2.5-amp continuous current on any recommended input voltage
Drives up to 7 analog or 6 digital standard-sized servos, with the BEC on any recommended input voltage
3–6S Li-Po, 9- to 18-cell Ni-Cd/Ni-MH input voltage
Finned heat sinks
Programmable motor braking
Safe power-arm mode prevents accidental starts
Programmable low voltage cutoff with settings for 3-cell Li-Po (9V), 4-cell Li-Po (12V), 5-cell Li-Po (15V), 6-cell Li-Po (18V), or 70% of battery starting voltage
Programmable soft start for helis and airplanes
Auto motor shut down if signal is lost or there is interference
Programmable timing—5 user-selectable ranges for use with a larger variety of brushless motors
Programmable throttle input range (1.1–1.9 ms or 1.2–1.8 ms)
Utilizes new smaller MOSFETs technology to minimize weight
Radio System Power On/Off Switch
No Battery Connector
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Old Mar 18, 2012, 09:36 PM
ogopogo is offline
Find More Posts by ogopogo
Trader Rating: 7
Canada, ON, Waterloo
Joined Dec 2010
Trader Rating: 7
bl15 and esc
pm en route
ogopogo is offline Find More Posts by ogopogo
Sold E-Flite Delta V-15, BL15 Motor and 60amp Pro Esc iPOWERSi Aircraft - Electric - Jets (FS/W) 1 Dec 23, 2011 02:43 PM
Sold E-Flite 450 Brushless Outrunner 890Kv AND E-Flite 40-AMP Pro SB Brushless ESC $55 ! shooboy Aircraft - Electric - Power Systems (FS/W) 4 Nov 24, 2011 11:51 AM
Sold E-flite 30 amp pro sb esc - cheap! $20 shipped aquaanox Aircraft - Electric - Power Systems (FS/W) 1 Sep 06, 2011 03:03 PM
Sold E-Flite 60 Amp Pro SB ESC $60.00 shipped btpalc Aircraft - Electric - Power Systems (FS/W) 1 Dec 31, 2010 10:23 PM
Sold E-Flite 60-amp Pro SB Brushless ESC Aut0tek Aircraft - Electric - Power Systems (FS/W) 3 Nov 23, 2010 09:40 PM
