Old Apr 14, 2012, 10:07 AM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
Did you measure the current on those 8S and 7S setups?
How did the CG work out? Did you need to add any nose or tail weight?
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old Apr 14, 2012, 10:40 AM
Gungho is offline
Find More Posts by Gungho
Gungho's Avatar
Singapore
Joined Aug 2006
Hi Lenny,
The CG for the 8s setup is about 10mm forward of the recommended CG of between 91-97mm. I have not needed to add any weights on the plane to balance it SO far I have run these set ups
1. 5s 3300mah TPs 65C - 441 grams
2. 6s Optipower 3000mah-475 grams
3. 5S +3S TP 3300mah 65C- 8s - 715 grams
4. 5S+2S 3300mah TP 65C - 7s - 645 grams
For the single packs there is room to move the pack back and forth to adjust the CG. For the 7s and 8s setup, there is no room to move the packs. They are jammed in between the back of the nose cone and the ESC upfront. However its a tad still nose heavy which is a good situation to be in. I did not like the recommended CG range....she seems to fly better nose heavy.
As for current measurements......I don't have the unilog yet...still working on getting a set. But guesstimate the 8s setup was pulling in excess of 300amps and the 7s setup is in an around 250 amp peak. On the 7s setup, I had to put back 1.68Ah after 40 secs of full throttle time. When I eventually get my unilog I will measure it.
BTW, I hope you read Germen as I had to translate the Hurricane Glider manual to get the settings.
Id suggest to maiden your plane on 6s and than when you get into the groove...move it up to 8s. But I can't guarantee your motor on 8s won't disintegrate like mine first motor did. Its a hell of a sight to see it on 8s.
Gungho is offline Find More Posts by Gungho
Old Apr 14, 2012, 10:52 AM
GeorgiMirov is offline
Find More Posts by GeorgiMirov
The props of tomorrow
Varna , Bulgaria
Joined Feb 2007
This Neu looks like the Leomotion motors
GeorgiMirov is offline Find More Posts by GeorgiMirov
Old Apr 18, 2012, 08:51 PM
Gungho is offline
Gungho's Avatar
Singapore
Joined Aug 2006
Some in flight photos
Old Apr 19, 2012, 04:31 PM
schiwo1 is offline
Find More Posts by schiwo1
Joined Nov 2009
VERY Nice!!
I ordered mine a month ago with the Neu 1515 and a 18x19 / 7Deg prop. Still investigating if I should go for the recommended YGE ESC or to try the brand bew Jeti Mezon ESC.
Question, do you need to split cells into 3s and 5s as shown on your vid or can you go also for 4+4s?
Best Stephan
schiwo1 is offline Find More Posts by schiwo1
Old Apr 21, 2012, 05:11 AM
Gungho is offline
Gungho's Avatar
Singapore
Joined Aug 2006
Hi There,
For CG balancing purpose, you need the setup the 5s+3s or 5S_2s with the bigger pack behind the smaller pack. Reason being the large pack actually sits below and slightly behind the wing joiner. The lighter pack sits in front of the joiner. The 1515 is a heavy motor so this configuration balances the plane nicely without weights. If you go with the 4+4....there is a likely chance you will be too nose heavy.
Old Apr 21, 2012, 10:15 AM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Dennis, any more flight with the Hurricane and the YGE? On 7S now? How is that working out?
jjmouris is offline Find More Posts by jjmouris
Old Apr 21, 2012, 04:11 PM
Gungho is offline
Gungho's Avatar
Singapore
Joined Aug 2006
7s is ok. No over temp cutoff. But I did send the YGE back for a checkup just in case.
Old Apr 21, 2012, 04:32 PM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Roger!
Old Jun 28, 2012, 05:46 AM
schiwo1 is offline
Joined Nov 2009
Mine finally arrived yesterday. The manufacturing quality is really impressive.
Look forward to get it ready
Best
Stephan
Old Jun 28, 2012, 06:29 AM
Gungho is offline
Gungho's Avatar
Singapore
Joined Aug 2006
Great!!!
My suggestion...start with 7S. Thats about 5000 watts with the 1515/1/5D.
With Throttle ramp, you can lower the power to about 4500 watts...
Beware....on 8S this plane screams(from prop stalling)
See attached unilog curve on 7s
Old Jun 28, 2012, 01:19 PM
Lenny970 is offline
Lenny970's Avatar
Joined Feb 2000
Best
Stephan
Sweet! That looks like the colors I ordered too.
Lenny
Old Jul 20, 2012, 11:45 AM
schiwo1 is offline
Joined Nov 2009
Hi Gungho,
in the middle of my built and I ran into a problem with the Rx battery placement.
Where did you place the on/off switch?
Thx for your hints.
BTW thanks for posting your built pictures above - very helpful!
Best Stephan
Old Jul 20, 2012, 06:39 PM
Gungho is offline
Gungho's Avatar
Singapore
Joined Aug 2006
Stephan,
I used one of these. I drill a hole just slightly behind the rx in the fuselage and installed this. It's on when you remove the Plug and off when inserted. And you can charge the rx battery thru the plug.
http://www.so!ringusa.com/product.ph...&cat=59&page=1
I will post a picture later.
The only thing I did not do is get excess to the balancing plug of the rx lipo.
One thing to note, becos of the way stratair wires up the green multiplex plugs, power from battery to rx can only flow when u plug the nose In. The nose plug is also a switch.
I must also warn you it is "fun" trying to Slide the whole assembly with the switch and the antenna wires into the back. I had to use a long stick and masking tape to hold the switch.
Sold E-flite hawker hurricane 25e bnf hi2nr Aircraft - Electric - Airplanes (FS/W) 7 Mar 06, 2012 08:21 AM
Gallery NEW! E-flite Hawker Hurricane: Stunts and Such RobscoRC Electric Plane Talk 0 Feb 19, 2012 04:34 PM
