Espritmodel.com Heli Air
Old Mar 17, 2012, 01:43 PM
United States, AZ, Seligman
Joined Nov 2011
Can a Tricopter Do Flips and Rolls Like a Quad Can?
Thinking of tearing apart my quad and building a tricopter. I was wondering if a tricopter is aerobatic? Can they do flips and rolls etc?
Dave8888 is offline Find More Posts by Dave8888
Old Mar 17, 2012, 02:27 PM
FPV really is fun.
Scotth72's Avatar
Sedona, Az
Joined Sep 2001
Yes.
Scotth72 is offline Find More Posts by Scotth72
Old Mar 17, 2012, 02:54 PM
OLDTOM's Avatar
United States, TX, Waxahachie
Joined Jun 2011
Absolutely......... sometimes unintentionally...
OLDTOM is offline Find More Posts by OLDTOM
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
oh yeaaa no problem
Nelapaty is offline Find More Posts by Nelapaty
Old Mar 17, 2012, 03:06 PM
Joined Nov 2011
Thanks people that's what I was hoping to hear. I have been researching and see that tricopters are huge compared to my 500mm quad. Each arm on the rc explorer v2.5 is 500mm. Can it be made smaller or will it be too unstable?
Old Mar 17, 2012, 05:24 PM
OLDTOM's Avatar
Joined Jun 2011
At 32" motor to motor it is doctile,...... yet still aerobatic, at 10" motor to motor it is wild with only a kk board..... but flyable..
Old Mar 17, 2012, 07:18 PM
Joined Nov 2011
I'm trying to make with the materials that I already have. The biggest I could make it would be 18" motor to motor. No camera or anything just sport flying around the field. What do you think of that size? With a KK board.
Old Mar 17, 2012, 07:37 PM
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
the smaller it gets the more fun you can have with it. what I mean is less turning radius compared to a longer arm tri.
Old Mar 17, 2012, 08:35 PM
OLDTOM's Avatar
Joined Jun 2011
I had a 19" that was fun till the trees ate it........Good size for fun, still pretty stable with only a kk...
Old Mar 17, 2012, 09:15 PM
Joined Aug 2007
TRICOPTER MADNESS (3D SESSION) (3 min 8 sec)
SGsoar is offline Find More Posts by SGsoar
Old Mar 18, 2012, 08:02 PM
Joined Jan 2006
i have a tcopter 49cm M2M with a KK+ with MEMS ACC mod.
it flies so stable ...
mandis is offline Find More Posts by mandis
Old Mar 19, 2012, 07:18 PM
Multi Rotor Maniac
Stunt Double's Avatar
Joined Oct 2007
It was watching tretch's videos that inspired me to learn tri aerobatics. Definitely need a smaller motor to motor distance for more responsive moves (50-60cm is ideal) but most of your performance will come from a good flight controller like multi wii.
+1 for the t-copter, better for orientation.
TRICOPTER - Flips, Rolls & Loops with a T-copter (2 min 40 sec)
Stunt Double is offline Find More Posts by Stunt Double
Old Jul 16, 2012, 05:32 PM
mcashatt's Avatar
United States, WA, Bellevue
Joined May 2012
Aerobatic advice
Hi Folks!
I have been into multicopters for several months now and have built hexas, quads, and tris.
I am hitting a plateau and getting bored with standard flight so I want to do some tricks like flips, rolls, etc, but I need some help getting started.
I put together a tri on which to practice aerobatics:
  • 18" motor-to-motor
  • 1000kv motors
  • 8X4.5 prop
  • KK board
  • 20Amp ESC
  • 3S battery @ about 30C
  • Turnigy 9X
That's all well and good, but still stuck--can some one please help with the following:
  • What is the best firmware for aerobatics on a KK tri?
  • What are the best Turnigy 9X settings?
  • Is there anything wrong with my setup that may be bad for aerobatics?
  • Any how to's or YoutTube training videos on *how* to do these tricks??
MANY, MANY THANKS!!!!
mcashatt is offline Find More Posts by mcashatt
Latest blog entry: SkullCopter Labs
Old Jul 16, 2012, 07:42 PM
Livin' On The Edge
hallstudio's Avatar
Marietta Ga.
Joined Apr 2005
Xcelent flying on the 2 videos above. i realy like the t copter when you grab it then throw it. here is my video. keep in mind its in my limited size front yard.
http://www.youtube.com/watch?v=2t_H9vP0c4w
hallstudio is offline Find More Posts by hallstudio
Old Jul 17, 2012, 12:59 AM
Multi Rotor Maniac
Joined Oct 2007
Mcashatt, for aerobatics with a kk there is the 1.6 acro firmware available with the lazy zero flash tool. For the radio start with 100 % rates and something like 40 % expo on roll n pitch. This firmware gives a lot more agility so be careful with the first flight.
Your setup should be fine, the only thing that stands out is the frame size which is small and will be difficult for orientation. I prefer something like 60-70cm motor to motor. I used to think smaller the better up until recently when i built an 80cm tri for fpv, its actually very good for acro the big frames is easy to see and follow during aerobatics. It really comes down to the power to weight ratio but mostly radio/flight controller setup.
With the kk the amount of gain dialled in to the pots directly affects the amount of travel for roll n pitch so you need a fairly low gain to throw it around. The trick is to find the right balance of rates/expo/gain so that it has enough agility for tight loops n rolls but also so that it is not too twitchy and difficult to fly in between. Buy lots and lots of props......
Question Can a 4 Ch heli do loops and rolls? And help with first heli please. panther3001 Electric Heli Talk 40 May 14, 2012 06:27 PM
Wanted Trade Heli for U Can Do or like 3D rz22g Aircraft - Fuel - Airplanes (FS/W) 0 Mar 17, 2012 08:44 AM
Video FY-X4 Quad flips/rolls CorporalB Electric Heli Talk 0 Feb 27, 2012 12:01 PM
Discussion Can the 4#3 do loops/flips raviolichef Micro Helis 17 Sep 27, 2008 08:06 AM
Blade tracking off after loops/rolls/flips? Dylwad Micro Helis 3 Oct 17, 2004 12:07 AM
