Old Mar 17, 2012, 11:48 AM
Serpico is offline
Find More Posts by Serpico
Joined Feb 2012
Something just not adding up - need help :/
I am admittedly a noob to RC battery technologies...
Bought this battery:
http://www.amazon.com/Thunder-Power-...=5336432818-20
and this charger:
http://www.amazon.com/Thunder-Balanc...=5336432818-20
However the adapter for the charger (2S) doesn't match the adapter on the battery (2S). I am so confused lol.
Do I need to mod the ends? The Battery end has a 4 pin female but is only utilizing 3 of them.
Thanks!
Serpico is offline Find More Posts by Serpico
Old Mar 17, 2012, 12:10 PM
big bird is offline
Find More Posts by big bird
Belfast / Dublin
Joined May 2004
there are a number of different types of balance plugs available - generally who ever sells the charger will also sell a range of balance boards so you can balance charge lipos from different brands
however having a thunder power battery not matching a thunder power charger's default balance board is quite odd ... anyway for a few dollars you can buy the appropriate board - i would avoid modding the plug on the battery
big bird is offline Find More Posts by big bird
Old Mar 17, 2012, 12:38 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Not odd however when the charger is not in fact a Thunder Power charger.
Old Mar 17, 2012, 12:45 PM
Southern Pride
Serpico
You need a Thunder charger to Thunder Power Lipoly adapter. Hobby King has them
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
5 for $1.99 plus shipping.
but if you want one sooner
http://rclipos.com/Accessories.htm#PQALAdapters
TP-AL-2S $5.25
That battery has a JST type parkflyer main leads connector. While waiting on balancing adapter you can charge it at 1C non balanced charge using main connector and the charger's main output leads only.
Most Thunder Powers rarely relly need balancing anyway and two cell ones often do not even have balancing leads as they rarely get out of balance.
Charles
Old Mar 17, 2012, 03:02 PM
KB9STD is offline
Find More Posts by KB9STD
Joined Feb 2007
That "Balance Board" if for batteries with an XH plug,not the "Thunder Power" type.Getting this board should work for You, and connect to different (3S,$s etc.)"Thunder Power" batteries as well.
http://www.hobbyking.com/hobbyking/s...rger_plug.html
KB9STD is offline Find More Posts by KB9STD
Old Mar 17, 2012, 04:25 PM
Southern Pride
That will only work if his charge takes Poly Quest / Hyperion balancing connector to the charger.
My recomended sex / type change adapters will work with his present balancing board.
Old Mar 18, 2012, 05:16 PM
Scarface26 is offline
Find More Posts by Scarface26
Colorado Springs, CO.
Joined Mar 2009
You have a nice little charger, but the Thunder AC6 I believe is made by "Hota". It is not related to "Thunder Power"
Scarface26 is offline Find More Posts by Scarface26
Old Apr 14, 2012, 02:03 AM
Serpico is offline
Joined Feb 2012
Yeah -after additional research they are named similar but in fact are different companies. Live and learn.
I was able to find an adapter for this charger that works with the battery pack(s) I listed. So I now have a charger, the battery packs, and the proper adapters
Thanks again folks - I know I haven't been back in a few weeks, but please don't perceive that as disinterest or being unappreciative. All of your comments lead me to finding what I needed!
FYI I am VERY close to launching my rocket project - launching an Android figurine and returning him safely to earth (very NASA/APOLLO-ish lol): (www.AndroidWasHere.com (#AndroidFlight)
Follow along on twitter if you wish - I'm always up for input and advice
Cheers!
-Serpico
Complaint Just what we need...not. Mark Wood Site Suggestions / Complaints 4 Dec 14, 2011 01:36 PM
Question Ratings not adding up Hunkus Site Suggestions / Complaints 3 Nov 03, 2011 06:18 PM
Wanted I need a .035-.074 (running or not(just looks good)) Transplant92 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 17, 2011 09:43 PM
Discussion Have a set up laying around...just need something to put it on!! flynfunny Power Systems 1 Apr 18, 2011 11:30 PM
