Old Mar 17, 2012, 10:56 AM
ian145's Avatar
United States, CA, Santa Cruz
Joined Nov 2010
Trex 450 pro 3gx rudder control problem.
I was flying my stock trex 450 pro 3gx the other day and it started spinning uncontrollably. Luckily I was able to land with out breaking anything. I took a look and the tail rotor pitch will respond extremely to left rudder input to the point where the contol arm is bingding. And it wont even respond to the right rudder input. It was flying perfectly before. Can I just change where the pushrod connects to the servo? Any help is very appreciated.
Thanks, Ian
http://www.rcgroups.com/forums/showt...6#post21060751
ian145 is offline Find More Posts by ian145
Old Mar 18, 2012, 03:13 AM
Denver, CO
Joined Dec 2005
You need to verify that the servo is good. If it is good, then you need to redo the 3gx tail settings.
Roto Rob is offline Find More Posts by Roto Rob
Old Mar 18, 2012, 11:28 AM
Joined Jun 2008
Yeah, that sounds like the servo type has changed to a narrow band servo.I've done that accidentally on my other flybarred heli. The servo arm moves right over, and you get the symptoms you described
fishfiend is offline Find More Posts by fishfiend
For Sale trex 450 pro 3gx nyesteban Aircraft - Electric - Helis (FS/W) 3 Apr 26, 2012 01:10 AM
Sold Stock Trex 450 pro 3gx lklansingkiter Aircraft - Electric - Helis (FS/W) 1 Mar 16, 2012 08:41 PM
Discussion mini protos carbon vs trex 450 pro v2 3gx which is best? Legendary_Agent Electric Heli Talk 7 Mar 15, 2012 10:23 PM
Sold Deleted xxrando Aircraft - Electric - Helis (FS/W) 0 Mar 02, 2012 12:18 AM
Sold Brand new Trex 450 Pro 3GX Flybarless. $450.00 LMAO Aircraft - Electric - Helis (FS/W) 5 Jan 20, 2012 08:03 AM
