Old Mar 17, 2012, 06:18 AM
lotus_cb is offline
Find More Posts by lotus_cb
Joined Mar 2012
Advice needed for first quadrotor building
Hi all,
I'm a newbie and going to build my first quadcopter. Below is my proposed configuration:
Frame:
Homebuilt using 1x2 cm aluminum, rotor to rotor distance is about 35cm.
Motor:
Turnigy 2209 28turn 1050kv 15A Outrunner, $11.83/ea, http://www.hobbyking.com/hobbyking/s...Outrunner.html
Propeller:
8x4.5 propellers, http://hobbyking.com/hobbyking/store..._SF_4_pc_.html
ESC:
TURNIGY Plush 18amp Speed Controller, $11.9/ea, http://hobbyking.com/hobbyking/store...ontroller.html
Battery:
ZIPPY Flightmax 2800mAh 3S1P 30C , $17.76, http://www.hobbyking.com/hobbyking/s...3S1P_30C_.html
IMU:
Sparkfun IMU Digital Combo Board - 6 Degrees of Freedom ITG3200/ADXL345, $64.95, http://www.sparkfun.com/products/10121
Other parts:
TX/RX:
Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 2), $22.99, http://www.hobbyking.com/hobbyking/s...2_Mode_2_.html
Battery charger:
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories, $22.99, http://www.hobbyking.com/hobbyking/s...cessories.html
Would the configuration be proper regarding the frame size? I'm a little worried since the total weight without frame is upto 630g already, I haven't constructed the frame but i assume it will weigh about 400g, so my quad will weigh about 1,1-1,2kg including other accessories. Would it be too heavy? Later, I want my quad to be able to do some aerobatics if possible.
I would appreciate any comment and advice.
Thanks.
lotus_cb is offline Find More Posts by lotus_cb
Old Mar 17, 2012, 06:25 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
good god, how can sparkfun charge that much for 2 sensors that cost $6 combined and keep a straight face.
even this is a better value (assuming you want to stick with obsolete 8bit stuff)
What do you plan to hookup that "IMU" to?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Mar 17, 2012, 06:26 AM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
If you are using multiwii, you can pickup an arduino nano which imo is easier to work with than a mini pro.
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Mar 17, 2012, 08:49 AM
zerosight is offline
Find More Posts by zerosight
Deutschland
Joined Nov 2011
Those motors could handle 9" props. Do not expect to much from this battery, it might limit your copter noticeable - the given specs are mostly overrated. You only get what you pay for. Try Turnigy nano or gens ace instead.
zerosight is offline Find More Posts by zerosight
Old Mar 18, 2012, 07:44 AM
lotus_cb is offline
Joined Mar 2012
Thanks everyone for your feedbacks.
@timecop and chaosdestro0:
Since this is a school project I have to build a flight controller board which uses an ARM mcu. The MultiWii is a really good suggestion however my supervisor probably wont be happy if i use it. I chose the Sparkfun breakout board cause i want to do as less soldering as possible. Sparkfun must have earned a lot of money from noobs like me ><.
@zerosight:
Thanks for your advice, i haven't bought the battery. I will consider the Turnigy nano.
Old Mar 18, 2012, 07:57 AM
David Jenkins is offline
Find More Posts by David Jenkins
David Jenkins's Avatar
United Kingdom, England, Ipswich
Joined Aug 2011
If this is a school project, PLEASE look up the safety issues, and also the gory pictures of what these multirotor props can do to the unwary!
These beasts are great fun, can give a lot of pleasure, etc. but they can do great harm if care isn't taken.
Not trying to put a damper on your project - just saying that you do need to think about what you're doing and consider the risks.
Oh - and I hope that you do have great fun, and enjoy yourself! (without injury)
David Jenkins is offline Find More Posts by David Jenkins
Old Mar 18, 2012, 08:25 PM
lotus_cb is offline
Joined Mar 2012
Thanks David, I did read the safety issues and will definitely check them out again when doing preflight testing and maiden flight (hope i will get there).
Old Mar 18, 2012, 08:33 PM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
Don't feel too bad...I don't know why, but I still buy some stuff from them (I should know better). I couldn't believe this (see attached photo) when I bought a 3.3V FTDI! I sent them a pretty nasty letter about paying top dollar and receiving this kind of poor quality.
CheckSum is offline Find More Posts by CheckSum
Discussion Building a FPV Multicopter Drone, Advice Needed divedaddy03 Multirotor Talk 0 Dec 07, 2011 11:10 AM
Discussion Building a FPV Multicopter Drone, Advice Needed divedaddy03 FPV Talk 9 Dec 07, 2011 10:54 AM
Discussion Advice needed to shop for the first time cdgan Beginner Training Area (Fuel) 20 Aug 09, 2009 07:07 PM
Discussion Advice Needed: which heli for very first dwmumford Coaxial Helicopters 17 Jan 12, 2007 03:00 PM
First hotliner ready to go. Advice needed for maiden. argarre High Performance 22 Aug 06, 2004 06:46 PM
