Old Mar 17, 2012, 01:27 AM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
HK ESC + Turnigy Motor Timing Issue
Running a 270kv Turnigy 5060 with a 17x8 prop
ESC is a 60-70 HKSS
Motor throttle up fine for 30 seconds then starts to jump between low throttle and high throttle. ESC is cold, Motor is cold.
Pull the power and straight away plug it back in you will get another 30 seconds before the same problem occurs.
Any ideas what might be wrong here?
lipoflyer is offline Find More Posts by lipoflyer
Old Mar 17, 2012, 03:11 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Some ESCs pulse the motor to notify you they've reached lvc. Could this be what's happening? If so, is your battery fully charged, and large enough to supply the amps your motor wants? Or is your ESC set for the wrong cell-count?
abenn is online now Find More Posts by abenn
Old Mar 17, 2012, 11:52 AM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
You are likely hitting LVC as previously mentioned. Unplugging/replugging gives the battery a little time to recover. If your using too small a battery (mah), that would easily explain the 30 second run time. Even a large battery with a too low "C" rating can do the same thing.
Try a battery with at least 5000mah capacity, I'd suggest a 30C rating in whatever cell count you use. That would deliver the amps required with the capacity to sustain flight times. FWIW Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Mar 17, 2012, 05:02 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
I am no way near LVC and i'm using a watt meter to determine that
Before it does it you can hear a couple of metalic clunks and then it starts throwing the prop around
Old Mar 18, 2012, 11:10 PM
Joined Oct 2008
Check magnets and bearings, clunking could indicate a loose magnet(s) or a damaged bearing. HK motors are rather famous for throwing magnets, and bearing issues. FWIW DougB
Old Mar 19, 2012, 07:41 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
I've always found their motors to be good and had no issues.
I have true two motors of the same size/make with the same results. I'm suspecting the esc is the cause.
Is it possible to reflash an esc???
Old Mar 20, 2012, 10:19 AM
buracho topspin is offline
Find More Posts by buracho topspin
Joined Feb 2012
Sounds to me like the ESC and I would try it with another motor. Also, what is the max voltage rating for the ESC? I think it's 22 volts, are you exceeding that?
The only other thing that would cause that would be one winding in the motor shorting out as the motor spins up.
buracho topspin is offline Find More Posts by buracho topspin
Reply With Quote  (Disabled)
Discussion Timing issue with Turnigy Plush 60 ESC palmsp9 Power Systems 1 Jan 02, 2012 08:45 AM
Question TURNIGY BASIC ESC 25A timing question kryptoknight Multirotor Talk 4 Oct 17, 2011 12:04 PM
Discussion Turnigy 180 esc timing help.Stock Surge Crusher motor maxmekker Racing Boats - Electric 5 Oct 08, 2010 03:45 PM
Discussion Motor/ESC Issue (timing???) GB57 Power Systems 11 Aug 10, 2010 11:58 PM
Sold NIB HK-100A ESC and Turnigy SK50-55-580 motor Eury Aircraft - Electric - Power Systems (FS/W) 3 May 10, 2010 06:40 PM
