This thread is privately moderated by jrej, who may elect to delete unwanted replies.
Old Mar 16, 2012, 04:32 PM
jrej is offline
Find More Posts by jrej
Trader Rating: 18
Joe
Bend, OR
Joined Jun 2010
Trader Rating: 18
Sold
Hextronic 2 gram Outrunner w/ TGY DP 3A 1S 1 gram ESC
I've had this lying around for a while, so I tested it on a AR6100 powered by 1S pack. Works perfectly. The rear body has been sleeved to 1/4" OD. I bought this originally for my Vapor, but never got around to it. You can also have the 6 props I bought which were recommended for this motor. GWS EP3020 Everything is brand new, never installed and only run for testing purposes. Includes the ESC user manual for programming purposes (not shown). $15. shipped to the ConUS, Paypal. Reply directly PM if interested.
hexTronic D1000 2 gram Outrunner
Kv:7700rpm/v
Weight: 2g
Voltage: 3.7v
No Load Current: 0.1A
No Load Speed : 12200
Load Current: 1.5A
Suggested Propeller: GW/EP 3020
Thrust: 36g+
Shaft: 1mm
TGY DP 3A 1S 1g Brushless Speed Controller
High speed MCU. Fast resolution for snappy throttle response and excellent low speed timing.
Cell Protection, signal lost failsafe.
Smooth startup.
Linear Throttle
Supports 240,000RPM (2 poles) / 40,000RPM(12 poles)
Spec.
Cont. Current: 3A
Burst Current: 4A
Max Voltage: 4.2v
Weight: 1g
Dimensions: 11x13x8mm
jrej is offline Find More Posts by jrej
Old Mar 16, 2012, 04:34 PM
Keenan smith is offline
Find More Posts by Keenan smith
Trader Rating: 4
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Trader Rating: 4
how much shippd to uk?
Keenan smith is offline Find More Posts by Keenan smith
Old Mar 16, 2012, 04:36 PM
lilbutch is offline
Find More Posts by lilbutch
Trader Rating: 27
skypup
United States, MS, Bay St Louis
Joined Feb 2012
Trader Rating: 27
pm sent.
lilbutch is offline Find More Posts by lilbutch
Old Mar 16, 2012, 04:41 PM
elvill is offline
Find More Posts by elvill
Trader Rating: 37
Eugene, Oregon
Joined Apr 2009
Trader Rating: 37
me too - eugene
elvill is offline Find More Posts by elvill
Old Mar 16, 2012, 04:48 PM
jrej is offline
Trader Rating: 18
Joe
Bend, OR
Joined Jun 2010
Trader Rating: 18
Sold to lilbutch
Thanks to everyone who responded
Discussion TGY DP 3a 1 Gram Brushless ESC ($20!) critterhunter Scratchbuilt Indoor and Micro Models 180 Oct 01, 2009 07:36 PM
Wanted TGY DP 3A 1S 1g Brushless Speed Controller Dimarazumov Aircraft - Electric - Power Systems (FS/W) 0 Aug 14, 2009 04:20 AM
Wanted TGY DP 3A 1S 1g Brushless Speed Controller Dimarazumov Aircraft - Electric - Power Systems (FS/W) 0 Aug 14, 2009 04:19 AM
Help! manual for TGY DP 3A 1S 1g Ivan2280 Scratchbuilt Indoor and Micro Models 24 May 20, 2009 01:09 PM
Help! Plantraco 4ch RX with TGY DP 3A 1S 1g ESC Veteran Scratchbuilt Indoor and Micro Models 8 May 20, 2009 12:46 AM
