Old Mar 16, 2012, 02:17 PM
motiganot is offline
Find More Posts by motiganot
motiganot's Avatar
Israel
Joined Jun 2008
Where I could find to buy propellers are already balanced ?
I am currently using APC 10x4.7 that is not balanced, and that's why I get a vibration in the picture.
motiganot is offline Find More Posts by motiganot
Old Mar 16, 2012, 02:31 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
learn to balance them. it is not hard. alternately, the best props are graupners. they do cost 3x to 4x apc though.
askman is offline Find More Posts by askman
Old Mar 16, 2012, 03:15 PM
olivdudu is offline
Find More Posts by olivdudu
olivier
olivdudu's Avatar
Dinan ,Brittany ,France
Joined Jun 2007
Try this kind of balancer, it really worths the few bucks you will pay for it. Place two magnets in a vise-clamp, so that it gets no mechanical pressure on the balancer, then, place a piece of tape (or some drops of varnish) on the lightest blade
the engine shaft will thank you
oliv'
olivdudu is offline Find More Posts by olivdudu
Old Mar 16, 2012, 03:25 PM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
If you dont have a balancer, carefully throttle up motor, to 1/4-1/2 throttle to get an idea of what vibrations the prop causes. Next, add a piece of tape the the prop, and throttle up again. If it gets worst, remove tape and add tape to other side. Throttle up again. And so on and so forth.
I downloaded a vibration meter for my android phone. I'm gonna try using it next time by rubberbanding it tightly to my plane or multicopter and trying the balancing procedure.
rcbif is offline Find More Posts by rcbif
Old Mar 16, 2012, 03:26 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
It's not hard to do and with every penny to buy a balancer even if it's a little finger balancer.
For smaller props (under 10") use simple electric tape on the back side of the blade to offset the heavy side. It's easy to cut to the length needed and will not come off in flight.
If not able or just don't want to I sure you could buy a few props already balanced here on RCG.
1320fastback is offline Find More Posts by 1320fastback
Old Mar 16, 2012, 05:31 PM
California Condor is online now
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
If you mount the APC props properly, ie. with the insert, they are balanced.
California Condor is online now Find More Posts by California Condor
Old Mar 16, 2012, 08:58 PM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
Gemfans are nicely balanced too.
http://gothelirc.com/shopdisplayprod...=GF+Propellers
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old Mar 16, 2012, 09:14 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
I find that apc still could be better balanced. may be it is the inserts, but I do find balancing them still helps. (especially the SF props)
Old Mar 16, 2012, 10:45 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
i had had about 40 APC props in the last 4 months and most of them the hubs are out of balance...
maybe 1 in 10 is actually ballanced...
I use the top flite balancer and the dubros....
but i guess it would depend on your standard of balance.
I fly sport fly with APCs out of the bag.... but add a camera and
Adidas4275 is offline Find More Posts by Adidas4275
Old Mar 17, 2012, 08:41 AM
Old Timer
Joined Apr 2001
Fred the owner died (cancer) a year or so ago and perhaps the new operator does not check the balance of each run as Fred did. The drilled hole may not be centered but the insert should correct this.
Old Mar 17, 2012, 08:46 AM
Joined Feb 2004
I've never really had an issue with apc props as long as I used the shaft adatper that comes with them. My only issue with apc is the price. It seems rather odd that a CW prop is different priced than the exact same size and pitch in a CCW prop.
Old Mar 17, 2012, 03:07 PM
Wenlock is offline
Find More Posts by Wenlock
United Kingdom, England, Liverpool
Joined Jul 2009
There's a set-up cost involved with making the moulds for any moulded part, and that cost has to be recouped from the sales. The set-up cost will be the same for CW and CCW props, but they'll probably sell 10 or 50 times as many CW props as CCW, so naturally the CCW props will be more expensive.
Wenlock is offline Find More Posts by Wenlock
Old Mar 17, 2012, 03:18 PM
motiganot's Avatar
Israel
Joined Jun 2008
Hello guys.
So I want to display the last clip I did on Saturday.
it was a day with very strong winds ...
I have not done propellers balancing yet, but I found another way to connect the
Camera to the Gimbel.
This might still not perfect but I'm getting closer ..
170312 (2 min 34 sec)
Old Mar 18, 2012, 05:37 PM
motiganot's Avatar
Israel
Joined Jun 2008
So guys.
Until I get the propeller balancer.
Meanwhile I built a basic one.
What do you say?
Old Mar 18, 2012, 05:43 PM
Joined Feb 2004
Are those plates magnetic? Looks pretty good.
Help! anybody got any 10 mil lam film in L.A. I could buy? grfcon Dynamic Soaring 0 Mar 15, 2012 10:57 AM
Discussion where can I find these propellers? huskerwr38 Multirotor Talk 15 Jan 24, 2012 01:59 AM
Discussion Where to buy GWS (or better!) propellers? Cheesehead Vendor Talk 3 Nov 09, 2011 07:56 AM
Discussion Where can I find folding propellers for my .061 Norvel (gas)engine for a 100" glider? aviator1zz Thermal 4 Jan 29, 2006 02:59 PM
Question where do you find your propellers? didiver Submarines 14 Mar 22, 2005 09:20 AM
