Old Mar 16, 2012, 10:52 AM
bigfoot216 is offline
Find More Posts by bigfoot216
United States, MI, Davison
Joined Feb 2012
grayson microjet v3 question...
I just bought a v3 and I already have a 40A esc and a 1- lipo BATTERY 2200MAH 11.1V 20C. will the battery and esc work with this V3 motor? If not what battery and esc combo would I want for this v3? BTW it is going on my wild hawk.
bigfoot216 is offline Find More Posts by bigfoot216
Old Mar 16, 2012, 11:17 AM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
They'll work together, yes. Make sure you use the right prop (~6x4 for that motor).
You might find you want a slightly smaller, lighter battery to keep overall weight down, but the one you have will still work fine.
Piece is online now Find More Posts by Piece
Old Mar 16, 2012, 11:36 AM
Joined Feb 2012
Great, Thanks! So the bigger the esc the better?
Old Mar 16, 2012, 11:42 AM
Piece is online now
Piece's Avatar
Joined Aug 2009
Not necessarily. An ESC that's bigger than necessary has no negative effect on the power system and will usually run a little cooler, but it'll also be heavier. At some point the extra capacity isn't worth the additional weight.
For your plane, you won't notice the extra couple grams.
Old Mar 16, 2012, 12:46 PM
Joined Feb 2012
Thank you C4H10.
Discussion Max prop on Grayson Microjet V3? prelator Power Systems 9 Aug 21, 2011 06:11 PM
Wanted Grayson Hobby Microjet V3 motor spencer6891 Aircraft - Electric - Power Systems (FS/W) 1 Jan 17, 2011 08:41 PM
Sold Grayson Microjet V3 Motor and ESC Hightray Aircraft - Electric - Power Systems (FS/W) 1 Oct 01, 2010 09:21 AM
Mini-Review Grayson MicroJet V3 (39g, ~2300kv) Dr Kiwi Power Systems 24 Aug 09, 2010 11:44 AM
Discussion Grayson MicroJet V3 motoror similar Angus Sugna Power Systems 3 Mar 24, 2010 12:24 PM
