Old Mar 16, 2012, 06:50 AM
mastmec is offline
Find More Posts by mastmec
mastmec's Avatar
United States, MO, Joplin
Joined Apr 2010
Question
Bud nosen 1/4 scale citabria
Two questions, what size twin four stroke is the best size and on servos, what torque range and best locations? Thanks.
mastmec is offline Find More Posts by mastmec
Old Mar 17, 2012, 08:49 AM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
I'd suggest at least a 1.60 twin,as a minimum, and servos are so much better at the flying surface, with short pushrods...80 to 100 oz.will be adequate,unless you tell me in your next post that you want a 3-D aircraft!....then you also want a 300 twin!
That airplane was designed to fly with a .60 -.90,in it's original state.
A good rule of thumb,for sport flying, is 12 lbs. per cubic inch of displacement,so yours could weigh as much as 18 lbs.,and still fly well.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Mar 17, 2012, 02:45 PM
mastmec is offline
mastmec's Avatar
Joined Apr 2010
Thanks, thats a lot of help.
Old Mar 24, 2012, 08:15 PM
Brian Allen is offline
Find More Posts by Brian Allen
Veni Vidi Volavi
Sterling, VA
Joined Jan 2002
I built and flew a 1/4 scale Nosen Citabria back in the late 80's early 90's. It originally flew with an OS120 twin and flew great on that engine. I later swapped it out for a OS 160 twin as a buddy wanted to use the 120. Flew the same on the 160 at a bit less throttle. Mine weighed about 17 lbs with a Coverite/dope finish. The 160 twin is a fine power plant for the Citabria, flies it in a very scale like manner and you can not beat the sound. Plane has scads of lift. Lost the plane after many fine flights when the TX battery went south on final approach. Still miss it.
Have a kit in the stash that I will build one day and E power.
Brian Allen
Veni Vidi Volavi
I came I saw I flew
Brian Allen is offline Find More Posts by Brian Allen
Discussion Bud Nosen 1/4 Scale Citabria Plans?? Keith Smith Giant Scale Airplanes 41 Jun 23, 2016 06:50 PM
Power options for a Bud Nosen 1/4 scale Citabria dr.E Scale Kit/Scratch Built 17 Mar 13, 2012 02:38 PM
Found Bud Nosen 1/4 scale Aeronca Champ plans mountainman2442 Aircraft - Fuel - Airplanes (FS/W) 1 Mar 06, 2012 06:23 PM
For Sale Bud Nosen 1/4 scale Citabria Brad B. Aircraft - Fuel - Airplanes (FS/W) 12 Jan 08, 2009 06:54 PM
For Sale Bud Nosen Citabria 1/4 scale framed up Brad B. Aircraft - Fuel - Airplanes (FS/W) 8 May 25, 2008 11:19 PM
