We normally use SIG brand castor oil. Usually a Hobby Shop can provide it or you can buy it online too. http://www.sigmfg.com/IndexText/SIGCO001.html
You can also get the Klotz Benol from many motorcycle shops or buy online too. http://www.klotzlube.com/proddetail....od=BC-175_Pint Some of the model engine glow fuel companies also sell their brand label version too. Byron Fuels for example sells a "Oil Booster" for people. If time is tight, like you need it fast, then you can use medicinal castor oil, but you must ensure it is plain, with no flavoring or sugar or other additives added to it. You can typically get this at many pharmacies all about. But it has to be 100% pure with no additives. Generally this castor oil can be the most expensive which is why it is a last resort kind of thing, but sometimes it is cheaper though. Medicinal castor oil is merely a more sterile version versus the commercial lubricant oils. |
Latest blog entry: My Low Wing plane
United States, MO, Byrnes Mill
Joined Aug 2011
thanks for all the replies its been very informing. to be honest i always tend to buy fuel that has castor in it but I also have gotten into nitro cars and seen all the LHS fuels only use synthetic so i was wanting to add some to that fuel
http://manuals.hobbico.com/osm/40-46-65la-manual.pdf Byrons AeroGen 10% Nitro blend has 20% oil, and their Premium 18 has 18%. Chart here: http://www.byronfuels.com/pages/prod...l#chart_anchor Morgan Cool Power 10% nitro is also 18% Oil blend: http://morganfuel.com/coolpower_mv_detail Morgan Omega Castor/Synthetic blend has 17% oil. this is usually what I use, but I dont run any bushed engines like the LA. these are the most commonly available fuels at most hobby shops that I know of. hope that helps out the OP. |
. In my Enya 61 RE I'm using 20% castor with 5% synthetic. Just as an experiment though to find out if a bit of synthetic really does keep any carbon down.
United States, CA, Corona
Joined Aug 2008
For the OS 40LA, scratch Coolpower off the list. It does not have any castor oil in it. Omega does give its castor/synthetic mix ratio as 30/70%. Byron's and Powermaster do not specify their oil mix ratios.
Powermaster does also make an all castor fuel they call GMA. They have 5 to 15% fuel with varying castor oil ratios from 24% to 29%. If GRRMISFIT is interested, Schaeffers Hobby in St Louis is a Powermaster dealer. They may have the GMA (or the Sig or Fox) in stock, or may be willing to get some for you. |
United States, CO, Arvada
Joined Nov 2010
I'm not sure if it's a company wide thing, but we've noticed here in CO that Hobbytown is bringing on all Cruelpower and getting rid of the good fuels, you gotta love profit margins. I'm stocking up on what old stock remains as Cruelpower is $3 more a gallon too.
Iowa
Joined Oct 2009
Too bad really, SIG has a fine line of fuels and even has an all synthetic called Syn Plus. Its 5 or 15% nitro and 18% lube. It also has an additive to keep down head temps. I have used it often and found it an excellent fuel for whenever you need an all synthetic fuel since it offers so much more lube than some other brands.
| Thread Tools | |
| Discussion Why have castor oil in your fuel opposed to synthetic oil? | Sir-Ipswich | Car Talk | 1 | Aug 09, 2007 06:48 AM |
| Cool castor oil or synthetic | bogas | Fuel Plane Talk | 15 | Mar 18, 2005 06:02 PM |
| Castor or synthetic oil? | W'rkncacnter | Engines | 10 | Aug 18, 2004 04:25 AM |
| Removing Castor Oil from Wood? | Brill 1 | Fuel Plane Talk | 12 | Jan 27, 2004 03:04 PM |
