Old Feb 07, 2004, 11:02 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Great news Gregg, I hope to follow you soon Any chance for some video ?
I'll have the cockpit all done and colored by tuesday (I hope!)
Haldor is offline Find More Posts by Haldor
Old Feb 07, 2004, 11:44 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Maybe
gregg f is offline Find More Posts by gregg f
Old Feb 08, 2004, 06:26 AM
Bob P is offline
Find More Posts by Bob P
Senior Member
Bob P's Avatar
Wiltshire England
Joined Feb 2001
Gregg
Congrats. Great stuff.
Bob
Bob P is offline Find More Posts by Bob P
Old Feb 08, 2004, 12:58 PM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Hooray!! Congrats on a great maiden Gregg.
Gordon
Gordon is offline Find More Posts by Gordon
Old Feb 09, 2004, 12:42 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Almost complete :
Old Feb 09, 2004, 12:44 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Cockpit frame rivets were burned in using a solder iron with a thin metal pipe attached, then a small philips iron (1,5mm diameter) was used to burn in the heads. Once painted I'll know how well (if) this worked.
Old Feb 09, 2004, 01:22 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
wow! going for the Ralle look eh i can see you need some flying weather.............
Old Feb 09, 2004, 03:22 PM
RalleKnalle is offline
Find More Posts by RalleKnalle
RalleKnalle's Avatar
Germany
Joined Sep 2002
Haldor, ...it will be very well. sand the rived lines softly (carefully) with 600 grain paper bevor painting and after masking.
RalleKnalle is offline Find More Posts by RalleKnalle
Old Feb 09, 2004, 09:39 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Masked, sanded and shot a light coat of filler on the canopy just to check how it showed through. Looks promising
Paint mask need to stay on a bit longer...
Old Feb 09, 2004, 09:45 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
..and as Gregg implied weather over here isnt worth flying in so I made some improvements on the Panther. This time I made 4 retainers for the tail section. When built per instructions I felt it (the fin/elevator assy) flexed a little too much and I wanted to stiffen it up. Tape over the edges would work but I wanted something tidier. Worked very well
I glued in 4 pieces of plywood along the tail assembly edge and drilled a hole in each. Then a 2mm machine screw was inserted and matching holes on the flange drilled/filed out. I think the pics will tell what I couldnt in words
Old Feb 09, 2004, 09:47 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Close-up:
Old Feb 09, 2004, 10:59 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
excellent modification!!!
i used a modified heavy duty servo horn to stiffen the rear. it worked ok, but this looks much better.............
Old Feb 10, 2004, 03:50 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
I've gone over the complete model once again to verify everything so I'll be ready when a window opens for my Panther maiden. She's hot to go, lets hope it will pass the range test this time.
Put her up on the scale with everything and got 2247g (79.3oz)
Power 900W (=180W/pound) Not very far from your numbers Gregg.
How did you use the servo horn to stiffen up the fin?
Old Feb 10, 2004, 11:07 AM
TGoodwin is offline
Find More Posts by TGoodwin
TGoodwin's Avatar
Las Vegas, NV
Joined Dec 2000
maiden
Good luck on the maiden Haldor.
TGoodwin is offline Find More Posts by TGoodwin
Old Feb 10, 2004, 11:41 AM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
bad pic, but you can see it
Build Log Aeronaut Panther Build from A-Z w/ video carl rich Electric Ducted Fan Jet Talk 161 Jun 01, 2010 07:46 PM
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
WTB: Aeronaut Panther Arbo Aircraft - Electric - Airplanes (FS/W) 2 Jun 19, 2003 04:00 PM
