Old Jan 21, 2004, 08:12 PM
hoser is offline
Find More Posts by hoser
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
wow !!!! rewind what is a tanic pack ????
and why is it smaller that a TP 6s4p (what i use).... i need to know
hoser is offline Find More Posts by hoser
Old Jan 21, 2004, 11:52 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Hoser:
it's abit smaller and lighter because it's an 8s2p. 16 cells total compared to 24 cells in the TP. capacity is also less though. 4.4hr.
i should get an easy 7-8min @ 36a.
here's the link
http://www.tanicpacks.com/BatteryListing.htm
gregg f is offline Find More Posts by gregg f
Old Jan 21, 2004, 11:54 PM
U812 is offline
Find More Posts by U812
Joined Sep 2002
Gregg,
When are you going to do the maiden?
I'd like to see it.
I've always liked this plane and kit.
Congrats on the new bird.
Steve
U812 is offline Find More Posts by U812
Old Jan 22, 2004, 12:03 AM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Originally posted by U812
Gregg,
I'd like to see it.
Steve
Sat 1-31 at the Newport Beach Mikoyan-Gurevich flight test facility........
Old Jan 22, 2004, 12:05 AM
U812 is offline
Joined Sep 2002
Thanks Gregg,
I'll try to make it. Good place to test.
Wish my Huck had a hook.
Steve
Old Jan 22, 2004, 01:25 AM
Daren is offline
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Originally posted by Ed Waldrep
I guess I could fly during the noon time jet window if there will be one again.
That's the plan. Please do, your is quite impressive in the air.
Daren
Daren is offline Find More Posts by Daren
Old Jan 22, 2004, 01:45 AM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
hopefully, fast movers will get a couple of one hour slots each day.
Old Jan 22, 2004, 05:08 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Thanks Gregg,
<snip>
Steve
LOL....I know you didn't just type that, <cut and pasted> for the record!
Bungi are our friend.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Jan 22, 2004, 06:06 PM
hoser is offline
shut up & fly
hoser's Avatar
Joined May 2001
rubber bands are DEAD !!!!
just kidding.... no i take that back they are dead ! LOL
how could you Steve :O
Old Jan 22, 2004, 06:49 PM
PhilLin is offline
Find More Posts by PhilLin
Oshkosh, WI
Joined Nov 2002
Thanks for posting the Tanic pack photo & link, GregF. You sure showed out-of-the-box thinking. Can you please clarify the pack arrangement? I take it from the photo that you have two cells per layer in series, then series with the next layer. The two 4S then hooked in parallel?
Second the 7 to 8 minute duration based on my 6S4P-7800's, only you will have have 25% more top end power! Also, you will triple your flight enjoyment. Instead of a take off & a landing circuit sanwiching 3 circuits of flying with GP3000, you should now get about 9 flying circuits plus the take off & landing.
I'll be glad to do the same in my EJF18E. I still have the 30/3. Should shed a half lb AUW with that & the Schubie
Is your field too rough to do gears? Your earlier flight pixes seem so.
PhilLin is offline Find More Posts by PhilLin
Old Jan 22, 2004, 07:00 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Phil:
each pack is 4s2p. the cells are rather long, they assembled the pack in two groups of four. each pack is two cells in length.
i usually fly the jets at an all electric club field. it's a bit rough for retracts there. but thats were the jet action is!
i fly the El Bandito at a public field with a nice runway.
Old Jan 23, 2004, 12:31 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
battery tray installed.
the tray has two ply small ply blocks underneath. 2 6/32 screws hold it from the fuse bottom.and two small screws are countersunk from under the velcro.
you can see the whip antenna mounted on the side of the fuse.
Old Jan 23, 2004, 12:36 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
rx and switch tray is siliconed to the upper intakes
Old Jan 23, 2004, 01:11 PM
U812 is offline
Joined Sep 2002
Hey Gregg,
Which RX are you using?
Steve
Old Jan 23, 2004, 02:25 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Hey Gregg,
Steve
hitec super slim 8ch
Build Log Aeronaut Panther Build from A-Z w/ video carl rich Electric Ducted Fan Jet Talk 161 Jun 01, 2010 07:46 PM
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
WTB: Aeronaut Panther Arbo Aircraft - Electric - Airplanes (FS/W) 2 Jun 19, 2003 04:00 PM
