Old Oct 22, 2003, 12:19 PM
Ductedfann is offline
Find More Posts by Ductedfann
Ductedfann's Avatar
mid west
Joined Jan 2002
Bob and all, fixed gear, spar mod, plug ends.
Lg has a thin foam strip between the plane and rear gear.
241 servo on stearing, I reversed the hatch latch didn't care for making a hole canopys plastic.
Ductedfann is offline Find More Posts by Ductedfann
Old Oct 22, 2003, 12:20 PM
Ductedfann's Avatar
mid west
Joined Jan 2002
2
Old Oct 22, 2003, 12:30 PM
Ductedfann's Avatar
mid west
Joined Jan 2002
wanting to be able to remove the wings and having times when I have caught the hanging wires, I fixed the plugs and had added screws like Haldor (I had not counter sank them).
Old Oct 22, 2003, 12:35 PM
Ductedfann's Avatar
mid west
Joined Jan 2002
The CF spar does not go all the way through high wing loading for my bird added spar in center all the war through stoping just before the end and filling the spaces between the spar and the wing with expanding foam foam sand bags used top and bottom to keep wing in shape if needed. over kill ?
Old Oct 22, 2003, 09:24 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
DuctedFann - has it flown yet?
I recieved the decals from Ralf yesterday, they look great!
Haldor is offline Find More Posts by Haldor
Old Oct 22, 2003, 09:45 PM
bruff is offline
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
battery cooling
How are you going to get air flow over the batteries for cooling?
Bob
bruff is offline Find More Posts by bruff
Old Oct 23, 2003, 12:55 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Battery cooling, have considered opening up the 4 gunports in the nose and have a hole in the intake ducts. The low pressure of the intake will suck air from the fuselage.
I'm not sure its really needed though as the fuselage is very generous in area.
Old Oct 23, 2003, 02:29 AM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
I have no battery cooling on mine, after a 4-5 min. run the FAUP's
are hot but nothing to worry about, after 30-45 mins they are ready to take another charge. My pack is just velcroed to a plate glued to the bottom of the fuselage so it's plenty of room around it when in the plane.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Oct 23, 2003, 08:46 AM
Ductedfann's Avatar
mid west
Joined Jan 2002
Haldor, Not on this power plant only taxi test.
For cooling the large opening by the front gear, in the photo the batts are in the way they were just placed for the shot, the bottom pack is placed back. The intake by the fan that aggressive cutting that I mentioned opens up so that the fan pulls a bit of air though a 32 mm tube fix with CA in the center hole in the front former?
Old Oct 30, 2003, 02:06 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Power update
I have finally squessed in enough 5min jobs to get the fan all mounted up with the ducts and have just performed the first power on tests.
First tried a 10CP1700 pack to check that the fan is running smoothly, then a uncharged 18x2600 pack was connected:
18V/30A = 600W (off a fresh charge I'd expect around 700W/34A)
Then I peaked two 10xCP1700 packs and connected these in series to get 20cells, hot off the charger this gave me 41A/900W total. However the final pack setup will be 2x 10 FAUP's which are 5,6oz lighter than the CP1700's. These should yield the same numbers and with some throttle management 4-6mins of airtime is achievable.
RTF weight with 20x CP1700's and rx battery : 2,4kg which is a little heavy. With the FAUP's and UBEC weight will decrease down towards 2,2kg (~80oz)
Smooth fan that Schubie....
Old Oct 30, 2003, 02:51 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
For those who has flown theirs, whats your RTF weights? and with what kind of power? I'm just curious.
Old Oct 30, 2003, 10:10 PM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
No more pictures yet but they will come. All hardware is now installed and checked for operation. Only gluing left is the battery tray + canopy.
I ran the rx arial through one of the wings and it will probably exit somewhere at the tip to run full length.
Also got the paints for it today so now I'm just waiting to put the maiden behind me.....
Old Oct 31, 2003, 02:58 AM
Helge Sondresen is offline
Find More Posts by Helge Sondresen
Helge Sondresen's Avatar
Stavanger Sola, Norway
Joined Oct 2000
Haldor,
Good, that was quickly done...
If you need a camera man...I'm available..
Helge
Helge Sondresen is offline Find More Posts by Helge Sondresen
Old Nov 01, 2003, 09:31 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Originally posted by Helge Sondresen
Haldor,
Helge
How does tues/wednesday next week sound, noonish?
Old Nov 01, 2003, 09:48 AM
Joined Oct 2000
No problemo,..Call or send a message..
Helge
Build Log Aeronaut Panther Build from A-Z w/ video carl rich Electric Ducted Fan Jet Talk 161 Jun 01, 2010 07:46 PM
I got some Fan Fold what to build thread part II started by emoone!!! Don Sims Foamies (Kits) 188 Jan 23, 2010 08:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
Switchback re-build thread (or What the $#*& was that!) Biggles604 Parkflyers 17 Jun 23, 2003 09:34 PM
WTB: Aeronaut Panther Arbo Aircraft - Electric - Airplanes (FS/W) 2 Jun 19, 2003 04:00 PM
