Old Nov 03, 2001, 03:11 PM
temacc is offline
Find More Posts by temacc
H2OFLY
Portland Oregon USA
Joined Feb 2000
What did You use in your Magic?
Getting the Magic ready, and am wondering - looking at the size and deflection of the 4 control surfaces:
What servos did You use in your Magic?
Different ones for ailerons vs Rudder and Elevator?
How many flights have you had on the model? Any problems with the servos?
I ask because my "advisor" suggested that HS 81's would not, in his opinion, be adequate.
Thanks!
Terry
temacc is offline Find More Posts by temacc
Old Nov 03, 2001, 04:33 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Your advisor would have a heart attack if he saw what I'm using then. I have 2 of the Naro MAX (19oz inch) servos on the elevator and rudder, and 2 of the Naro HP(25 oz inch) on the ailerons. The reason I did this was to save some weight, and I'm using a 8:1 gear ratio with the pitch speed in the low 40 mph at max throttle. I also am using the Magic as an E3D trainer, so I don't have the throws at maximum either. Having a slow model and short control throws allows you to use smaller servos. Your HS-81's will be fine as that is what most people around here are using.
Jim McPherson is offline Find More Posts by Jim McPherson
Old Nov 04, 2001, 12:19 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
F12 (just happen to have one around) 10 cells and HS81's and 225's.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Nov 04, 2001, 12:38 AM
Adam Neat is offline
Find More Posts by Adam Neat
Adam Neat's Avatar
Winchester; Ohio
Joined Feb 2001
Hey Fred; How about a few more details on your F-12 setup. Ive been running an Endo with a 6:1 on 10 cells but also happen to have an F-12 laying around and was considering the Magic as a good place for it.
Adam
Adam Neat is offline Find More Posts by Adam Neat
Old Nov 04, 2001, 12:55 AM
temacc is offline
H2OFLY
Portland Oregon USA
Joined Feb 2000
Fred -
Where are you using the 81's and where the 225's?
How many cells are you running? Prop size? Gearing?
Oh - and just how many F-12's DO you have?
Terry
Old Nov 04, 2001, 10:53 PM
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
225's for the rudder/elevator and the 81's for the ailerons. I have no issues with them having more than enough power.
Sorry I only have 1 F12 right now. But there was one on EBay for $199 yesterday, and the seller has a good rep.
F12 on 10 cells and a 14-5 prop puts out 80 ozs of thrust at 40mph and 345 watts out at 40 amps. I think that will do quit well on a 55 oz plane.
Plus I know I am not pushing the motor at all and can push the motor to 50 amps easy
Old Nov 05, 2001, 12:04 AM
temacc is offline
H2OFLY
Portland Oregon USA
Joined Feb 2000
Thanks to all -
I will use HS 81 mg on the ailerons, and the Futaba 9601's (that I already have) for the tail.
Terry
Poll What capacity lipo do you use in your Blade CP/Honey Bee? LuckyDuc Micro Helis 12 Feb 15, 2006 07:04 PM
What Batteries Do You Use In Your SS? SkyRCJon Batteries and Chargers 28 May 15, 2005 08:47 PM
What do you use to keep your computer healthy? kist2001 Life, The Universe, and Politics 6 Jan 03, 2003 09:46 AM
for all you in the north what do you use to keep your hands warm? kushal_22 Electric Plane Talk 42 Dec 11, 2002 10:26 AM
Foam Conversions: What did you do with your $4? watersharer Electric Ducted Fan Jet Talk 22 Aug 06, 2001 06:39 PM
