Old Mar 15, 2012, 09:43 PM
The Don is offline
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Build Log
Wicked Powered Mini Concept X 50mm
Here is my build log for the Mini concept X. I bought mine from X-flight.
The Don is offline Find More Posts by The Don
Old Mar 15, 2012, 09:47 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
For power I decided on the:
Wicked 4800KV Wemotec microfan combo
Pentium 40 amp ESC
Photos:
1) added some wire to the ESC battery leads
2) mounted the fan unit, I moved it back about 1/4" to clear the wooden mounting blocks.
Old Mar 17, 2012, 06:04 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Got some more work today. This is a real easy build, not too much to show you really.
Old Mar 17, 2012, 10:47 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Last comments before the maiden:
1) the outlet is about 93% FSA of the wemo fan. If you want lees top speed but more thrust then leave the outlet as it is. For 80% FSA (what I always use) then you need to make a wedge cut that is 3/8" wide at the end. Then reglue to get the correct outlet sizce of ~37.6mm. Before gluing you can reforn the foam with your fingers so that it will be round when glued together instead of oval.
2) AUW is 19.3 ounces with a 4S 1320 lipo. That is about 350 watts per pound which is a nice number for these 50mm EDFs.
3) I used a razor and cut some of the foam hinge line to loosen up the ailerons and elevators to make the servo load a little less.
Next up is the maiden, hopefully tomorrow!
Don
Old Mar 18, 2012, 04:38 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Here is my video:
Wicked Powered Mini Concept X (3 min 22 sec)
Old Mar 20, 2012, 02:58 PM
MikeontheBike is offline
Find More Posts by MikeontheBike
MikeontheBike's Avatar
sacramento. ca
Joined Dec 2010
I'm going to be ordering one of these kits and will be getting a balanced wicked/wemo combo from you.
MikeontheBike is offline Find More Posts by MikeontheBike
Old Aug 23, 2013, 12:46 PM
YFZ450MANNY is offline
Find More Posts by YFZ450MANNY
YFZ450MANNY's Avatar
United States, FL, Fort Lauderdale
Joined May 2013
Who is selling these little jets now? I bought one through NP a while back but they are out of stock and looks like they're not planning on getting any more.
YFZ450MANNY is offline Find More Posts by YFZ450MANNY
New Product 3/15/2012---NOW W/VIDEO!!!..Post #133..50mm Nitroplanes.com Exceed RC Mini X 26'' Jet Kevin Greene Foamy EDFs 355 May 22, 2013 04:54 AM
Build Log Wicked Powered Banana Hobby Jpower 50mm AMX The Don Don's RC 199 Dec 19, 2012 08:19 PM
Discussion Nitroplanes Exceed R/C Mini Concept X 50mm alpea 41 Foamy EDFs 0 Mar 14, 2012 11:47 AM
New Product A-RC Concept-X 50mm version Slaanesh Foamy EDFs 1 Jan 11, 2012 06:04 AM
Build Log Wicked powered X-flight ARC Vector Exceed RC Concept X EDF The Don Don's RC 52 Jul 11, 2011 12:27 PM
