Old Mar 15, 2012, 07:32 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
New Product
Has Anyone Seen One of THESE???...AS3X---MOVE OVER!!!
Title says it all!!!......Seriously, has anyone taken a look at this 3 axis gyro that weighs a scant 8g???...Sounds promising for some of the larger micros...Waduya think???......
http://www.century-rc.com/ecs/produc....php?p_id=6115
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Mar 15, 2012, 09:43 PM
smasher41 is online now
Find More Posts by smasher41
United States, GA, Snellville
Joined Nov 2005
i ordered one from ebay for the heck of it
seems to be a basic version of this:
http://www.rcgroups.com/forums/showthread.php?t=1596644
smasher41 is online now Find More Posts by smasher41
Old Mar 16, 2012, 01:21 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Wow! Just over 40 bucks delivered to my doorstep. Slap a 5 buck orange rxer to it and giddyup!
NitroCharged is offline Find More Posts by NitroCharged
Old Mar 16, 2012, 02:39 AM
Mendo is offline
Find More Posts by Mendo
Mendo's Avatar
United States, CA, Ukiah
Joined Dec 2011
You got my attention! I must know more.....
Mendo is offline Find More Posts by Mendo
Old Mar 16, 2012, 03:43 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
http://www.hobbyeagle.com/manual/2012-03-13/8.html
There's the manual from the hobbyeagle site.
Not as fancy as the guardian but still worth testing in the small stuff!
Old Mar 16, 2012, 05:57 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Very nice! Seem to be very programmable. Doesn't seem to have any interaction between the 3 gyros though. AS3X has some kind of coordination between gyros allowing the control of more than one axis together. But I'll likely give it a shot for my bigger airplanes! I was thinking about buying the gardian so now, it's a toss up. Though this one is smaller. Good find! Thanks
Somehow, it make HH look good though. They added those gyros to their smallest receivers without cranking the price. The same receivers without the MEMS gyros costed the same as today's AS3X receivers.
RealGambler is offline Find More Posts by RealGambler
Old Mar 16, 2012, 06:39 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
I like the specs of the guardian - being able to switch everything to different settings or off, adjust each gain while in flight... nice stuff for the price and size.
Likewise, I see this one as a 'set and forget' system - once it's tweaked nicely you shouldn't have to touch it again.
The AS3X for micro stuff because it weighs less.
I think each one has a place.
Old Mar 16, 2012, 07:00 AM
Canada, QC
Joined Oct 2009
So true!
Old Mar 16, 2012, 08:40 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Do you know whether it'd work with 1S, 2S, 3S, etc., setups?
That is, does it matter what battery size your plane uses?
Also, will this call for upgraded servos, the way AS3X does?
pugsam is offline Find More Posts by pugsam
Old Mar 16, 2012, 09:40 AM
Joined Mar 2007
I've read just a small amount about the Guardian---Something about not being able to use all three gyros at once---Somehow, the rudder gyro can't be use in conjunction with ailerons???---I'm not sure, I'll have to thouroughly read up on both systems...
For a SUPER light setup you could remove the servo pins from both the RX and the gyro board and if you're up to it---Solder the wires directly to each, negating the extra weight of the connectors...Just a thought...
Kevin
Old Mar 16, 2012, 10:42 AM
Canada, QC
Joined Oct 2009
Works on 4 to 6 volts, so basically, it will work with any BEC from a ESC. So 2S and above. The big question is would it work on 1S? Rating is 4V so that would be a BIG no, but often, it's simply to be safe. I know I would be tempted to try it! I fly the AR6300 on 1S even if it's not recommended!
That would make sense... If the rudder need to kick in, you end up with some rolling force that need to be compensated with the ailerons. Without a CPU onboard, that may yield some interesting results for sure.
Old Mar 16, 2012, 11:18 AM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Thanks, RG.
What about whether it would need upgraded servos, like AS3X does?
Old Mar 16, 2012, 11:49 AM
Mendo is offline
Mendo's Avatar
Joined Dec 2011
Thanks, RG.
I guess it would depend on what you were planning to upgrade from.....Im very curious to see some results from the gents with alot of gyro experience on this little guy. Very intrigued.
Mendo
Old Mar 16, 2012, 12:00 PM
Joined Mar 2007
Thanks, RG.
I can see why you ask this...A cheap low res servo could get its butt worked to death!!!...Good question!!!
Kevin
Old Mar 16, 2012, 12:40 PM
Canada, QC
Joined Oct 2009
Since the first time they added a gyro on the tail of an heli, a high grade digital servo was a must, so same thing would apply here I guess. 3 decent quality digital servos would likely be a must unless you go very easy on the gain.
No matter how good a gyro system is, if you have a servo failure in flight because it's overused, then you're screwed.
Discussion Has anyone seen or used one of these? joe_crash Electric Ducted Fan Jet Talk 5 Dec 15, 2011 06:11 PM
Discussion Has anyone built one of these? MadDogMcQ Dock Talk 9 Nov 03, 2011 03:30 PM
Discussion Has anyone seen this one? makenzie71 Electric Heli Talk 4 Sep 19, 2011 01:47 PM
Discussion anyone have or seen one of these? electricrc68 Micro Ready-to-Fly 16 Sep 14, 2011 02:26 PM
Has anyone seen one of these fly? GregG Electric Ducted Fan Jet Talk 6 Jul 30, 2002 10:06 PM
