Old Mar 15, 2012, 07:08 PM
wilevi93 is offline
Find More Posts by wilevi93
United States, AK, Fairbanks
Joined Mar 2012
Fuel for Norvel 074
I have a new norvel 074. I was planning on breaking it in on 0% nitro 25% castor fuel. For regular running, the manual says I need to run 20-22% oil with half of that being castor. I already have some cool power 15%, but its oil content is only 17% all synthetic. I was wondering if there would be any problem if I changed the fuel mixture to the following:
add 324ml cool power to an empty bottle (269ml fuel 55ml synthetic oil)
add 55ml castor
lastly add 121 ml plain methanol
Should end up with half liter of 22% oil 50/50 castor synthetic + 8% nitro.
I was worried that the cool power oil percentage might not be measured by volume. Does anyone see any problem with this plan? Will the engine be okay running this?
wilevi93 is offline Find More Posts by wilevi93
Old Mar 15, 2012, 08:35 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yes you can add oil to increase the percentage. Granted it does change the ratios some, but not really all that much to affect it too much. Adding more methanol is a good idea. So there is no problems with your idea that I can think of.
earlwb is offline Find More Posts by earlwb
Old Mar 16, 2012, 01:25 AM
surfer_kris is online now
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
I prefer to use full castor oil fuel (20-25%) on the Norvels, they are very tight when new and take a long time to break in. Use a heating gun or small torch to relive the TDC pinch.
surfer_kris is online now Find More Posts by surfer_kris
Old Mar 16, 2012, 04:44 PM
mtntopgeo is offline
Find More Posts by mtntopgeo
United States, MT, Superior
Joined Dec 2006
add 55ml castor
Why would you want to "break-in" this engine with no nitro? Seems that would be detrimental to long piston/liner life. ??? ............. George K.
mtntopgeo is offline Find More Posts by mtntopgeo
Old Mar 16, 2012, 04:48 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
He may not be from the USA and glow fuel with nitromethane in it can be much more expensive in some countries.
The engines do run OK with O% nitro in the glow fuel. You just don't get that extra power out of them you do with nitromethane. Also the needle valve tends to be a little more sensitive in its setting. You could also remove a head gasket shim or two to increase the compression a little more for 0% nitro fuel. If I remember correctly the engines come with three stacked head gaskets in them.
Old Mar 19, 2012, 11:13 PM
NACA0012 is offline
Find More Posts by NACA0012
Joined Mar 2012
When Peter Chin broke an engine in prior to review, his standard mix for most engines was 75/25 methanol/castor.
NACA0012 is offline Find More Posts by NACA0012
Old Mar 20, 2012, 10:37 AM
Joined Dec 2006
I 'd be quite surprised to learn that Mr. Chin would have "broke-in" a Norvel .074 with "no-nitro" fuel. Because of the unique metallurgy, & the greater than normal iterference fit of the P/L at TDC, it's quite important to get these engines up to normal high temperature soon as possible during the first several runs. ....
Maybe, like earlwb said, W93 may not be from the states. He may well intend to use "no-nitro" fuel even after the engine was broken in. If so, the fit would be fine, but some power would be lost. However, if that same engine were then to be used with the (what I call) norm 35% nitro fuel, the p/l fit would be loose. .......
George K.
Old Mar 20, 2012, 11:20 AM
Sweden
Most important for running-in the engine is to use a heating gun to pre-heat the cylinder and reduce the pinch at TDC.
You will not brake any engine by running with 0% Nitro, on the contrary lower nitro requires less compression ratio. The price of 10% Nitro fuel is about twice as high as for 0% Nitro here, so that is one reason to use low nitro levels. Some engines tend to run a little warmer on 0% nitro though compared to 10% nitro.
Here is my Norvel .074 running on 10% Nitro and 20% all castor fuel;
Super Chipmunk (speed 400 ARF) on glow (2 min 56 sec)
Old Mar 22, 2012, 02:16 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I have used and flown a number of 1/2a engines with no nitromethane in the fuel. You might lose some power and it makes the needle valve more sensitive to adjust, but the engines run just fine. With some engines you can remove a head gasket shim or two and it improves the performance quite a bit. The engine temperatures are about the same for with or without nitromethane in the fuel. So it isn't a big deal.
I never tried it with a Cox .020 engine though, so that I don't know, if it will work or not.
Post number 22 in this thread here http://www.rcgroups.com/forums/showt...1346066&page=2
show another fellow going with FAI fuel in a .049 engine.
Old Mar 22, 2012, 03:02 PM
Sweden
Sure you can get the .020 peewee to run on 0% nitro, but the problem is that the needle becomes very sensitive. The tank will heat up during a run and you have to chase the needle. You'll never manage to empty the tank, been there done that....
The Peewee runs much better as a diesel, long consistent runs all the way till the tank is empty and spins a 6x3 prop at around 10000rpm.
Old Apr 02, 2012, 01:12 PM
wilevi93 is offline
Joined Mar 2012
As far as I can tell, this is a controversial subject. Some people say you should use nitro, others say you don't need to.
Somebody needs to do a test with a temperature gauge to see what runs hotter, 0% nitro fuel, 10% nitro, castor, synthetic etc. It's my opinion that 0% heats the engine more since the ideal fuel/air mixture is leaner than with nitro fuel.
If 0% does run the hottest, it means the upper cylinder should expand nicely, preventing wear, also adding to prolonged engine life would be that you don't have the high pressures and stress in the engine as with nitro fuel.
If power is your main concern, then you should use nitro fuel regardless of engine wear.
Nitro fuel is a little expensive to buy where I live. (Alaska)
Old Apr 02, 2012, 06:41 PM
Joined Dec 2006
[QUOTE=wilevi93;21215406]As far as I can tell, this is a controversial subject. Somebody needs to do a test with a temperature gauge to see what runs hotter,
OK guys, first off, I'm fully aware that model engines can be run on "no nitro" fuel without destroying themselfs. The key words here, (in the opening post) are "breaking it in on 0% nitro". My concern was that the revlite norvels should be run up to get near max temperature asap when breaking-in. If that temperature was on the cold side for the first couple of runs, & then a switch to a "hi nitro" fuel was made for every day runing, the engine would be somewhat loose for the nitro. .................. So, after wilevi's last post, I removed my oldest Norvel .074 engine from its airframe & mounted it on the test stand. This engine has gone through 'bout 3 gal of fuel (33% nitro, & 25% oil). Just about all the run time has been at full throttle. ( bench readings 19K to 21+K; I don't have any doppler data so no telling what the unloaded RPMs are) with either Mas 5.5x4 or 6x4 props. It is quite loose, & has virtually no "pinch" left at TDC. Compresston, however is still quite good. .................. Three test for RPMs & temperature were run. ............#1; 2 shims & 33% nitro............... #2; NO shims (just a dab of Hylomar smeared on the bottom of the glo head) & no nitro. ....
#3; 2 shims & no nitro. ( The "no nitro" fuel was SIG's so called FAI fuel) All runs were made with the 5.5x4 prop. Test #1 gave 21,300 RPMs & 238deg F.........
Test 2 gave 21,000 RPMs &190 deg F. Test 3 gave 20,000 RPMs & 183 deg F.
Got to admit, (and eat a bit of crow) that I really expected much more than a 50 deg temperature difference between Nitro, & no Nitro . ................ Test #2 was a bit of pleasant surprise. Starting was a bit more cranky. ( had to give up flipping & grab the electric starter), & the needle was a bit more touchy, but the engine really transitioned & peaked nice. Idle needed to be a few hundred RPMs higher. (Maybe a carb with low end adjustment would help.???) ALL told, not much of a price to pay for almost identical top-end performance.!!! .......... Test 3 was a real pain. About 6 starts, before the engine would stay running. Then, I had to move the throttle very slow for just a few % & wait for the temperature to come up & let the engine start to run clean. Made it up to full throttle, & setting the needle was a real bear. Even after the temp. came up, & the needle was as good as it was gonna be, the engine would not continuously run "clean" . About every 5 seconds, it would give a single "burp". Don't have a clue as to what is causing this. (not enough combustion chamber temperature???). Regardless, what the cause, test #3 certainly ain't the way to go. .......................... Got to list a couple of possible pitfalls with this test. First, Damn cold in my basement with the double garage doors open; 'bout 38 deg F. .... Second, I'm not likeing the IR scanner, & the big differences of readings as I moved the scanner just a bit from an area in back of the clamp to just a tad more into the air stream. Think that a thermocouple or platinum RTD fixed to the back of the clamp would be much better. Also, might be better to kill the engine & immediately take the readings.?? Hopefully, I haven't bored everybody to sleep, & that there was some usefull info to be gleened from this long winded post....... (Comments, + or -, not only welcome, but requested......... George K.
Old Apr 02, 2012, 07:34 PM
wilevi93 is offline
Joined Mar 2012
Well, what I can glean from looking at the data is that running 0% nitro, although it is running leaner, it still won't develop as much heat as fuel containing nitro. It also develops less power which is to be expected.
38F ? Ha, that's nothin. I started my TT-07 at 10F in my driveway, just to test out if using a candle to preheat the engine is a viable method...... It's not, I had to use a hair-dryer to properly heat it (sigh) no winter flying for me.
Old Apr 02, 2012, 11:54 PM
nitroairplane is offline
Find More Posts by nitroairplane
Tiny diesels.... I love 'em
United Kingdom, England, London
Joined Aug 2011
I am sure engines run cooler with more nitro!
Well to a certain extent, when I ran FAI fuel in my engines they ran hotter and less steady harder to needle and sometimes sorta "skipped".
nitroairplane is offline Find More Posts by nitroairplane
Old Apr 04, 2012, 03:18 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
1) Less nitro means the engine needs MORE compression.
2) Break in the engine with the % nitro you plan on running. If you run 0% nitro, break in with 0% nitro. If you run 15% nitro, break in with 15% nitro fuel.
Pinecone is offline Find More Posts by Pinecone
For Sale NIB Norvel .074 with wrench Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 04, 2012 09:47 AM
Question What mount for a Norvel .074? microflitedude 1/2A Planes 7 Dec 04, 2011 08:39 AM
Sold Norvel 07 Glow Plug (.074) and starting spring jrbackus Aircraft - Fuel - Engines and Accessories (FS/W) 1 Nov 07, 2011 10:31 AM
Trade Norvel 074 for CC 25 amp brush less speed controller. mike7130 Aircraft - Fuel - Airplanes (FS/W) 1 Jan 03, 2005 01:57 PM
Motor mounts for Norvel .074 zoomzoooie 1/2A Planes 4 Oct 31, 2003 08:51 AM
