Old Mar 15, 2012, 06:01 PM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
Problems with Orange RX DSM2 and Failsafe
I tried the failsafe on my DX7 and an Orange RX 7 channel DSM2 RX and when I turn off the TX to check the failsafe, the servos simply go limp when the signal drops. Anyone else having problem like this? Any suggestions?
Thanks for your help,
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Mar 15, 2012, 06:49 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Not every RX has Preset Failsafe, most only have Hold Last Command.
How you testing FS? Turning off the radio?
freechip is offline Find More Posts by freechip
Old Mar 15, 2012, 08:37 PM
dmcquinn is online now
Find More Posts by dmcquinn
dmcquinn's Avatar
United States, MO, Chesterfield
Joined Jan 2004
The servos should all hold their last position except for the throttle which should return to whatever position it was in when you last bound the system. When you say "go limp" do you mean that you can easily move the surfaces as if the servos have been turned off?
dmcquinn is online now Find More Posts by dmcquinn
Old Mar 15, 2012, 09:10 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
When I turn off the radio the servos typically go to where I set them up in failsafe (in this case full up and right elevon.) In this case they simply de-energize and I can move them freely. Looks like I need to set up my Spektrum RX if I plan to use failsafe.
Thanks again for your help,
Jimmy
Old Mar 16, 2012, 05:52 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
This is because you have the receiver set for PRESET FAILSAFE
In this case they simply de-energize and I can move them freely. Looks like I need to set up my Spektrum RX if I plan to use failsafe. Thanks again for your help,
Jimmy
Most will just hold last command.
Old Mar 16, 2012, 06:54 AM
grmis is offline
Find More Posts by grmis
grmis's Avatar
France, IDF, 91
Joined May 2011
Setting failsafe on OrangeRX DSM receivers
Hi,
If one needs *all* channels to go to some specific positions on signal lost, one should bind the receiver in the following way:
- TX & RX off
- Plug the binding plug
- Switch on the RX -> flashes
- Remove the binding plug -> RX keeps flashing
- Switch on the TX in binding mode with the sticks at desired positions
This worked for me with(Dx6i) with the 6ch as well as with 9ch receiver from OrangeRx. I think it is the same procedure with most genuine spektrum receivers.
If you don't remove the plug before switching on the TX, only the throttle channel will move (to zero) in case of a signal loss ("Preset failsafe" mode, as mentioned above). Hope this helps!
grmis is offline Find More Posts by grmis
Old Mar 16, 2012, 07:21 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by grmis View Post
... I think it is the same procedure with most genuine spektrum receivers. ...
It is the same procedure BUT not all receivers have both failsafe methods.
Old Nov 17, 2015, 03:40 AM
placho is online now
Find More Posts by placho
Joined Mar 2015
Hi,
- TX & RX off
I tried more or less the same with the AR6210X Spektrum RX and a R111NX Orange satellite. The procedure was:
- TX & RX off
The result is the sames as in this video:
Comparison of Spektrum, Orange and Lemon DSMX satellite receivers on HiSky HCP100s helicopter (4 min 10 sec)
The thing is that the throttle, even if I leave it down, when I turn off the TX, it start spinning. Any advise on this? Thank you very much!
placho is online now Find More Posts by placho
Sold Orange RX 9 Channel RX DSM2 NEW!!! $30 shipped HD Hucker Aircraft - General - Radio Equipment (FS/W) 2 Apr 06, 2012 09:19 PM
Sold 4 NEW Orange RX 6 Channel RX's DSM2 $42 shipped! HD Hucker Aircraft - General - Radio Equipment (FS/W) 1 Mar 10, 2012 08:56 PM
Sold N.I.P. R610 6ch DSM2 rx, orange RX. 10 usd shipped nemoskull Aircraft - General - Radio Equipment (FS/W) 1 Mar 08, 2012 12:41 AM
Sold One AR6200 with Spektrum DSM2 satelite and a 9Channel Orange RX with 3 orange sats crosby Aircraft - General - Radio Equipment (FS/W) 3 Feb 19, 2012 06:57 PM
Sold Two Orange RX DSM2 (Spektrum compatible) receivers with Satellites -= GYRO =- Aircraft - General - Radio Equipment (FS/W) 13 Jan 22, 2012 01:37 PM
