This thread is privately moderated by racerxky, who may elect to delete unwanted replies.
Old Mar 15, 2012, 05:42 PM
racerxky is online now
Find More Posts by racerxky
Watts is where its at!
racerxky's Avatar
United States, WA, Seattle
First Fruits from Cutter Research
My research into vinyl cutters has its first tangible results. I really like the Silhouette Cameo. It's only 12" wide but it is the cheapest cutter I was looking into and its performance with our materials and ease of use are great. I would like to find a wider cutter that has similar cost and performance. I may get to evaluate one of the chinese cutters from USCutter.
Evaluating these machines is expensive and time consuming. If something is not going well it can take a lot of messing around to decide if the problem is your setup, the machine or the software. Many test cuts have to be made changing just one variable at a time. I'm not keen on wasting my time like that too often.
racerxky is online now Find More Posts by racerxky
Old Feb 13, 2013, 12:02 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Your inbox is full so I can't reply via PM.
Regarding my Grumman Goose:
I just use Adobe Illustrator and carefully measure everything in 2D. The CL415 should be pretty easy because it's a flat-sided fuselage and flat-bottom wing.
warhead_71 is offline Find More Posts by warhead_71
Old Feb 13, 2013, 02:01 AM
racerxky's Avatar
Got it. Thanks!
Discussion Marker/Cutter Tool from Small Flying Arts madbomber The Builders Workshop 9 Dec 13, 2012 07:58 AM
Help! NAZA question about switching from 3s to 4s, do I have to change in software first. jasper7821 Multirotor Talk 9 Mar 09, 2012 11:07 AM
Question Help making a "hot wire cutter" from soldering iron rcguy1958 The Builders Workshop 3 Oct 28, 2011 04:15 AM
Sold Us cutter vinal cutter ufo jerry Aircraft - General - Miscellaneous (FS/W) 5 Oct 13, 2011 08:35 PM
Question Research my first flying wing Frenchy Pop Electric Plane Talk 2 Oct 01, 2008 01:41 PM
