Old Mar 15, 2012, 02:10 PM
GreenAce92_v2 is offline
Find More Posts by GreenAce92_v2
Euphoric flights
GreenAce92_v2's Avatar
United States, NY, Buffalo
Joined Aug 2011
Need your opinion on mechanical variometer
This was an idea to make a mechanical variometer based on the AC location of a glider and a small pivot.
This variometer could be made out of a paper clip if it could work which is where you guys come in.
Abstract:
A seesaw mechanism with electrical contacts is placed on an airplane. The fulcrum is located precisely on the Aerodynamic Center of the aircraft. Any change in height (impulse) would cause the see saw to pivot. The seesaw is quite sensitive and when the contacts meet, an LED circuit is completed and glows.
This variometer is intended for FPV use
Do you think that this idea would work?
GreenAce92_v2 is offline Find More Posts by GreenAce92_v2
Old Mar 15, 2012, 02:48 PM
glidermang is online now
Find More Posts by glidermang
ACE:
A couple of things to ponder -
1. Your device depends on acceleration. What about constant-rate climbs, when acceleration is zero?
2. What about when the airplane rotates? The contacts will close and you will get a false reading.
3. When the airplane does rotate (and it will), it will rotate about the center of gravity. That will result in a sensed accelertion at the aerodynamic center, and a false reading.
Originally, variometers were based on a closed chamber. As the airplane climbed, air moved out, and moved a pellet in a tapered tube. As the airplane descended, the air moved back in, and the movement elevated a pellet in another tube. The pellet indicating climb was usually green. The descent pellet was usually red.
Good luck.
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Mar 15, 2012, 02:51 PM
Euphoric flights
Joined Aug 2011
See this is why I needed to post this.
Thanks Greg, as always
What is the simplest vario you can think of that can be visually used by FPV?
The last one down is a bit pricey for my taste though I did come across this "pellet" Variometer you speak off on hang gliding forums.
Also a guy mentioned moire effect on one of the home made variometers.
I did find a full schematic layout of a home made vario but it seemed pretty complicated for a noob at circuit making.
Old Mar 15, 2012, 02:57 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Doesn't the Aerodynamic Center of the AC change with speed, AOA, etc? That is why they can fly nice but tuck under certain circumstances.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Mar 15, 2012, 08:29 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
How would this unit work in blustery turbulent air?
davidjensen is offline Find More Posts by davidjensen
Old Mar 15, 2012, 08:41 PM
tkallev is online now
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I built some free flight models in the 60's that used a pendulum to move the elevator and rudder ... models kind of staggered across the field until you got the range of motion right.
Bought a radio and never looked back
tkallev is online now Find More Posts by tkallev
Old Mar 16, 2012, 08:20 AM
ACE:
A variometer for RC use, that can also transmit a signal, will probably set you back $300. Sorry about that.
A basic variometer is actually quite simple, but bulky. It requires a vacuum bottle and a thermistor. It's the vacuum bottle that is bulky. Check out "variometer" on wikipedia.
There is no reason you couldn't use a GPS receiver in your model. The actual receiver in a cell phone is a chip about the size of a fingernail (the bulk in your cell phone is battery, screen, keyboard and speaker). If you started with a Radian, for example, you could use a whole cell phone.
Yours, Greg
Old Mar 16, 2012, 10:57 PM
rrcdoug is offline
Find More Posts by rrcdoug
rrcdoug's Avatar
Canada, BC, Kelowna
Joined Aug 2010
GPS variometer woes
I used a GPS based variometer last summer. It worked OK as long as the lift was gentle. The GPS usually has a "filter" to keep height data "reasonable", ie you are in a ground based vehicle or walking. The vario typically sensed lift for 30 seconds after winch launch as it caught up with the sudden gain in altitude. I am working on a pressure sensor driven system that will insert pressure altitude into the GPS NMEA stream so my software (SkyNavigator) will still read it.
The sturdiest and most compact varios we used for hang gliding were differentiated pressure altimeters. An analog electronic pressure sensor was sensed through a capacitor and some Op amps.The resulting signal was proportional to the rate of change of the pressure. This is pretty obsolete now with digital pressure sensors and microprocessors that can count feet (or meters). A lot of the RC varios are talking now!
rrcdoug is offline Find More Posts by rrcdoug
Discussion Need your opinion on this motor/esc combo. jake95 Dock Talk 7 Sep 08, 2011 12:12 AM
Discussion Need your opinion on this red bottom paint ken_nj Dock Talk 32 Feb 17, 2010 01:44 PM
Discussion Need your opinion on gasoline vs. nitro buggy lazer155 Car Talk 29 Oct 16, 2009 07:28 PM
Discussion Camera on top side or under - Your opinion please. Easystar owners need not respond. garris2 FPV Talk 11 Jan 15, 2009 05:22 AM
Need your opinion on a possible glider modification Vesperatus Electric Sailplanes 7 Feb 10, 2005 06:58 AM
