Old Mar 15, 2012, 12:23 PM
frankykae is offline
Find More Posts by frankykae
Joined Mar 2012
Question
Tacon 3674 1300kv and seaking 120a
Hello, I very new to the brushless electric (tired of swimming to get my nitro boat and even more tired of the maitance) and choosing the right battery is a little tricky, please help! Im building a brushless boat 26" with the following set up Tacon 3674 1300kv and seaking 120a. Please let me know if you need more info about the ESC and Motor. If you have any tips please let me know! thank you! Please help choose a Battery that can go fast can last more than 15 min.
frankykae is offline Find More Posts by frankykae
Last edited by frankykae; Mar 15, 2012 at 12:25 PM. Reason: Forget to ask the question...
Old Mar 15, 2012, 01:11 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Frank,
For a 26" boat that motor is more than enough...
I run a 31,5"Arowana with a similar motor, the Turnigy 3674-B-1900KV on 4S 5000mAh and with a 42K prop the boat runs over 65 km/h (a tad over 40 mph) for about 7 minutes.
With 1300KV your motor is a 'typical' 6S motor, which gives you about 26.000 rpm under load.
As the 6S set-up is less amphungry than my 4S set-up, you'll have a minute or two more runtime, so if you want to double that, you'l need to use two 6S lipo batteries, wired in parallel, to get more capacity (= more runtime).
Downside is the extra weight the boat will have to carry, slowing it down (a bit) and drawing more Amps, so doubling the runtime of a single lipo will be an illusion.
What boat are you putting this motor combo in if I may ask?
Pictures of the build would be nice...
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Mar 15, 2012, 01:30 PM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
It must first be determined whether or not the hull is capable of 40+ mph, so as Jan requested we need to know the hull. I too would recommend 6s with that motor and an x438-x440..........if the hull is worthy.
scorpion1 is offline Find More Posts by scorpion1
Old Mar 15, 2012, 01:35 PM
Joined Mar 2012
Hello guys! thanks for the quick replay, for now I'm using a Pro Boat Blackjack 26" nitro but i will upgrade it to a 31" (future project). So using 2 LiPo 6S Parallel what C-Rate should I use? I haven't put anything together yet (as soon as i do it i will put some pics) so it just the hull the BJ 26 (the red version)
Old Mar 15, 2012, 02:57 PM
Sneek, Netherlands.
Joined May 2004
Hi Frank,
That's a rather hot set-up for the relatively narrow cat, but, 40 mph can be done without changing the motor, read the link supplied with this film:
Black Jack 26 Brushless with mods (1 min 48 sec)
Knowing it's a catamaran I would expect a higher revving set-up to keep the propsize down.
Typically cats rev at 30.000 rpm+...
Capacity wise as high as you can carry, with 30-40C or higher.
Regards, Jan.
Old Mar 16, 2012, 09:11 PM
Joined Mar 2012
Perfect!! thank you guys!! one more question please, so can I put a bigger prop than a 36mm prop? or may be with 3 spokes?
Old Mar 16, 2012, 09:25 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
You can try up to an x442 i would think..............
Question Hobbywing Seaking 2848sl 3900KV rmartin00 Racing Boats - Electric 15 Mar 24, 2012 05:24 AM
Discussion Seaking 120a help willy007 Racing Boats - Electric 11 Feb 01, 2012 07:47 PM
Wanted WTB Seaking 120A ESC V2 syncronized Boats (FS/W) 2 Sep 09, 2010 10:10 AM
Wanted Seaking 120A ESC MarcRacer18 Boats (FS/W) 1 Oct 21, 2009 01:34 PM
Sold 4 New Traxxas #3674 Nylon 2.2" Rear Wheels Dyed Black JohnM Cars - Cars and Parts (FS/W) 1 Jan 30, 2007 08:06 PM
