Old May 09, 2012, 03:18 PM
isoaritfirst is offline
Find More Posts by isoaritfirst
isoaritfirst
isoaritfirst's Avatar
Not a Brummie/but close
Joined Sep 2005
This is the excert from the translated instructions.
Can someone translate any better?
What interests me at the moment is the amount of movement I need to build into the flap surface.
depth -5 / +5 mm 20% expo
drift -7 / 7 mm
Aileron 18/9 mm 20% expo
component (component + ailerons) 0 / +1.5 / +3 mm (Inter 3 pos)
-10 / +10 Mm (4-axis control)
mixing depth components to -7 / 7 mm (this mix is mandatory for Prodij HM)
20 mm air-brake component (or cross on the end of travel)
fins -20
isoaritfirst is offline Find More Posts by isoaritfirst
Old May 09, 2012, 03:50 PM
moatdib is offline
Find More Posts by moatdib
Wollongong, Australia
Joined Jul 2008
/!\ Positive throws indicate a control surface going down /!\
- Elevator: -5/+5mm <-> 5mm up/ 5mm down
- Rudder: -7/+7mm
- Ailerons: -18/+9mm <-> 18mm up/ 9mm down
- Flaps (note that this moves the central flap and the ailerons by the same amount):
if using a 3 position switch: 0/+1.5mm/+3mm <-> 0/1.5/3mm down
if flying 4 axis (using throtle stick to adjust flaps): -10mm/+10mm
- Mix elevator to flaps (again this moves the central flap and the ailerons):
AMENDEMENT:
@ -5mm elevator -> +7mm flaps
@ +5mm elevator -> -7mm flaps
- Butterfly/crow brakes: +20mm on central flap, -20mm on ailerons
@Loic: please confirm that the ailerons move with the central flap for elevator to flap mixing.
I will translate the manual in full shortly if someone wants it.
moatdib is offline Find More Posts by moatdib
Old May 09, 2012, 04:40 PM
isoaritfirst
Joined Sep 2005
Thanks a lot for that.
I don't think I would have built in -10mm throw on the flap without that info.
Old May 09, 2012, 05:25 PM
droydx is offline
Find More Posts by droydx
Fun ain't cheap!
droydx's Avatar
United States, CA, Santa Barbara
Joined Apr 2003
Yes, it's a lot of up for a flap. That is why the throw becomes so critical on that servo. You are going to enjoy it!
droydx is offline Find More Posts by droydx
Old May 10, 2012, 01:10 PM
lblife is offline
Find More Posts by lblife
lblife's Avatar
USA, CA, Seal Beach
Joined Aug 2010
A full translation would be great, if you have the time.
Matt
- Rudder: -7/+7mm
AMENDEMENT:
lblife is offline Find More Posts by lblife
Old May 10, 2012, 03:29 PM
moatdib is offline
Joined Jul 2008
Alright, I'll jump on that ;-)
Old May 10, 2012, 04:33 PM
Blanco Loc is offline
Find More Posts by Blanco Loc
France, Midi-Pyrnes, Toulouse
Joined Sep 2005
- Rudder: -7/+7mm
AMENDEMENT:
Yes ailerons moves with the central flap for elevator to flap mixing (same amount for ailerons and flap on both sides).
Regards
Loc
Blanco Loc is offline Find More Posts by Blanco Loc
Old May 14, 2012, 06:56 AM
moatdib is offline
Joined Jul 2008
Translation of the manual is here.
Note 15/05/2012: Corrected version - confused fore and aft, used 'front' now
Cheers
Old May 14, 2012, 09:46 AM
lblife is offline
lblife's Avatar
USA, CA, Seal Beach
Joined Aug 2010
Thank You!!!!!
Old May 14, 2012, 11:54 PM
moatdib is offline
Joined Jul 2008
ooops, there is a glitch in the manual: whenever I wrote "aft" think "fore" ;-), I'll correct that and upload the correction...
updated manual, see post above
Old May 15, 2012, 06:57 AM
isoaritfirst
Joined Sep 2005
Thanks for that very nicely done..
Old May 23, 2012, 05:18 PM
isoaritfirst
Joined Sep 2005
Model is finished - just needs a few small details sorting out and balancing.I will post a few pics tomorrow.
Looking forward to a nice maiden this weekend. forecast looking good.
Old May 29, 2012, 04:39 PM
isoaritfirst
Joined Sep 2005
20mph wind, and warm and sunny
Maiden of ProdiJ
What a great performer.
Even flown empty it whips around the sky, with great aerobatic prowess and also a real nice accurate feel to it.
Very Pleased
Old Jul 02, 2012, 03:39 AM
isoaritfirst
Joined Sep 2005
ProdiJ HM continues to impress.
Despite a few issues with flat batteries.
The model is fitted with 2/3A 1600 Interlect cells and 5 x MKS 6100 servos. I don't know why but I didn't expect battery usage to be an issue and as the model is great fun to fly I tend to fly it a lot.
It has locked me out twice, and although I haven't completely found out why, I now suspect very high battery usage, following recharging yesterday to 980mah after a 2 hour session.
I have now fitted an on-board battery monitor hopefully this will help to keep the model safe.
Good test though. First "off" was while a friend was flying it and away it went freeflight for quite some time before burying itself nose cone deep into the hillside. Broken tailplane joiner and a small crack in the D Box, broken servo and stripped wing wiring. All soon fixed and as good as new.
Then off it went again, almost out of sight along Rhossili S Wales. It took a couple of hours to find and was buried beyong th eLE of the wing seating, - Nose cone was split for a few cm and pushed so far up the fuz it took two of us and several attempts before we could remove it. End result stripped wing wiring again. Now changed to a plug arrangement that hopefully would disconnect if needed.
This is one strong model that I have now tried hard to destroy twice and nearly lost once - so not a great start.
But now all sorted (I hope) wiring plugged, and repairs all almost as new, and flown lots and lots this weekend.
It is a great model to fly and caused quite a stir on the hill, super fast and turns great.
Old Jul 02, 2012, 12:16 PM
F3X is offline
F3X
Find More Posts by F3X
F3X
F3X's Avatar
Joined Jun 2001
He-he same Aeromod toughness!!
Nice set of toys you have there!
Beautiful slope as well!
F3X is offline Find More Posts by F3X
Discussion Aeromod Prodij HM Blanco Loc Slope 42 Jan 10, 2014 07:28 PM
New Product New HM Prodij F3X Multi Task F3X 0 Dec 02, 2011 10:48 AM
For Sale 60'' PRODIJ From AEROMOD jboujon Aircraft - Sailplanes (FS/W) 0 Jul 29, 2008 08:15 AM
Build Log Prodij-X (converting an Aeromod Prodij to crosstail full flying stab) surfimp Slope 109 Oct 31, 2007 05:11 PM
The new Aeromod Prodij 60" sloper is here!!!!(just put your components and go) guillaume83 Slope 12 Aug 31, 2003 09:46 AM
