aileron section
It's my first mini mouldie with this little space for servo and linkage
. And I thought my F3F and F3J planes have little space ...So I thought quite long time about the best aileron linkage. I had several ideas, but I came back to the method shown on Alexis' website. To be honest I do not like this kind of open linkages on the bottom side very much. But this is a "little effort implementation" and easy to maintain. So at the end of the build I will build a coverage to prevent the servos from damage when landing in higher gras. Some photos from the aileron section I worked on yesterday.
!Quote:
No mm give away for saving air drag...
Except two little things general built quality is very good from a current point of view (--> wing plating uneven, one very little bump on an aileron close to the linkage position). Wing fuse is very stiff, definitely! And I assume the very light fuse will be stiff enough for this size of model as well (as this is my first mini-mouldie I have no compaison to other mini's). More to come later about quality when build is finished and test flights are done.Btw, I really like the implemention of the aileron/wing change .No pesky resin nose, but nevertheless no gap at regular throws! |
V-tail and fuse servos
V-tail section is finished. Was not much effort as the holes were placed perfectly by aeromod.
Had planned to make the carbon bars removable, but it seems that I did not use enough grease ...With the ballast there is very little space in the fuse. The 488 BB MG servos have the absolute max size for the Prodij HM, the MKS 450 digital would fit better (but were not available, except the two for the ailerons). If both bras bars will be used in future in my fuse you have to replace the hole for fixing the main bar or you have to file of some of the smaller bar to get both into the fuse. Because of the "larger" 488 BB MG servos I will file off some off the smaller bar to make life easier in future (don't like to fiddle about too much at the slope when I am flying in winter times and having windy 0°C, -5°C or -°8C ).Currently working on the servo tray...
| Thread Tools | |
| Discussion Aeromod Prodij HM | Blanco Loïc | Slope | 41 | Mar 31, 2012 03:56 PM |
| New Product New HM Prodij | F3X | Multi Task F3X | 0 | Dec 02, 2011 10:48 AM |
| For Sale 60'' PRODIJ From AEROMOD | jboujon | Aircraft - Sailplanes (FS/W) | 0 | Jul 29, 2008 08:15 AM |
| Build Log Prodij-X (converting an Aeromod Prodij to crosstail full flying stab) | surfimp | Slope | 109 | Oct 31, 2007 05:11 PM |
| The new Aeromod Prodij 60" sloper is here!!!!(just put your components and go) | guillaume83 | Slope | 12 | Aug 31, 2003 09:46 AM |
