Old Mar 15, 2012, 07:28 AM
brodjack is offline
Find More Posts by brodjack
usual old know-it-all
Blackpool,U.K.
Joined May 2005
Omni-directional antenna
just fitted one of these
http://www.foxtechfpv.com/58g-11dbi-...nna-p-369.html
am i right in asuming the face with the silver paper in the picture should be pointing to the plane,give or take about 30-40 degrees?
only mine gets same real good reception infront,behind,above and even side on to the RX antenna...not complaining just curious..
brodjack is offline Find More Posts by brodjack
Old Mar 15, 2012, 07:46 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
i don't know which side is front on that, but the big sticker would be my guess.
patches have side lobes that add gain off center. generally speaking, you can expect omni performance out to about 90 degrees or so.
But with a directional patch like that, the best benefit is to point it right at the plane.
gundamnitpete is offline Find More Posts by gundamnitpete
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Mini-HowTo Build a cheap shroud for your CP omni antenna pr0ject42 FPV Talk 10 Feb 13, 2012 07:28 AM
Discussion need the best omni directional antenna for receiver WBFlyer FPV Talk 10 Jul 07, 2007 10:24 AM
Discussion I need the best omni-directional antenna WBFlyer FPV Talk 2 Apr 11, 2007 11:59 PM
Omni-directional antenna for bit-tx? Angry_Monk Scratchbuilt Indoor and Micro Models 4 Aug 12, 2005 04:05 PM
