Old Mar 15, 2012, 02:58 AM
not103 is offline
Find More Posts by not103
not103's Avatar
Italy
Joined Mar 2009
Thermal Scout by Winded Shadow System tone variometer
Hi,
below a shor video of maiden flihgt with the Thermal Scout in tone output mode directly connected to the mic in of 5.8Ghz 200mv transmitter.
As you can see it works very well and it's a cheap gadget great to add to our fpv gliders..
The plane used is a Multiplex Easystar 2.
Variometer maiden flight (2 min 44 sec)
And there the vendor web site http://wingedshadow.com/thermalscout.html
not103 is offline Find More Posts by not103
Old Mar 20, 2012, 01:45 PM
brucey is offline
Find More Posts by brucey
brucey's Avatar
Joined Apr 2011
After seeing your video I've just ordered on for my easy glider.
brucey is offline Find More Posts by brucey
Old Mar 20, 2012, 04:30 PM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
I've been using one for a while on my BOT and you can't beat it for the price. It can be turned on/off from a radio switch.
Gary Evans is offline Find More Posts by Gary Evans
Old Mar 20, 2012, 08:49 PM
philthyy is offline
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
As soon as I saw this video, I called them up and ordered one. I'm currently building a FPV EZ Glider so this is perfect.
philthyy is offline Find More Posts by philthyy
Old Mar 21, 2012, 12:50 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
But if you're doing FPV with an OSD which displays your altitude, why do you need this?
Ian Davidson is offline Find More Posts by Ian Davidson
Old Mar 21, 2012, 02:54 AM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
ive just ordered the lastonedown vario ... cant wait to try it out with my modded skywalker
Blackrat is offline Find More Posts by Blackrat
Old Mar 21, 2012, 06:04 AM
Mesa, Arizona
Joined Nov 2006
Because it is easier to use than the visual. With the visual you will focus on that spot of the OSD when thermaling when you should be flying the plane and watching for traffic. It frees up your eyes. All full sized sailplanes use analog varios with audio.
Old Mar 21, 2012, 06:16 AM
Old Blighty
Joined Apr 2010
Ahh, ok, gotcha - thanks
Old Mar 22, 2012, 01:28 AM
brucey is offline
brucey's Avatar
Joined Apr 2011
Also the GPS isn't as sensitive and won't react as quickly.
I also liked the look of the 'Last one Down' vario, it was just a bit out of my price range.
philthyy, post back once its installed let us know how you get on with it.
Old Mar 25, 2012, 12:40 PM
Cosworthnz is offline
Find More Posts by Cosworthnz
Cosworthnz's Avatar
Joined May 2005
Vario and Mic on one audio channel
Can you connect this in parallel with a microphone so you can have the vario and on-board sound using one audio Chanel?
Cheers
Cosworthnz is offline Find More Posts by Cosworthnz
Old Mar 25, 2012, 11:28 PM
brucey is offline
brucey's Avatar
Joined Apr 2011
I was going to try that when mine arrives
Old Mar 26, 2012, 02:52 PM
philthyy is offline
UAV Integrations
Joined Nov 2005
I will definitely post up pics and vid once its installed and working. I'm really excited to try this! I'ver never thermalled a big glider before, much less FPV'ed one! (although I've been FPV'ing for 8 years now)
Old Mar 26, 2012, 03:37 PM
Mesa, Arizona
Joined Nov 2006
Cheers
Yes you can. You need to supply the vario speaker such as one from an ear bud. You can then position it near the on-board mic and you willl hear both. That is how mine is set up.
Old Apr 04, 2012, 02:13 AM
brucey is offline
brucey's Avatar
Joined Apr 2011
Just received mine in the post today, its tiny!
Old Apr 04, 2012, 02:29 AM
andreas77 is offline
Find More Posts by andreas77
Sverige
Joined May 2009
Another option is to use a 100nF cap in series with the output from thermal scout, then connect it in parallell to the mic. That's how it's done on the SimpleOSD.
I connected my thermal scout like that and it works.
andreas77 is offline Find More Posts by andreas77
Discussion Thermal Scout by Winged Shadow - A New Thermal Detector skyhawk1 Electric Sailplanes 56 Jun 19, 2015 10:33 PM
Sold NIP Thermal Scout Bud Morrison Aircraft - Sailplanes (FS/W) 4 Oct 19, 2011 09:59 PM
Sold SOLD NIP Winged Shadow Systems Thermal Scout, $35 Ninjak2k Aircraft - Sailplanes (FS/W) 0 Aug 09, 2011 07:19 PM
Discussion Variometer or Thermal Scout? Evan D Thermal 9 Jun 29, 2011 08:15 PM
