Old Mar 14, 2012, 09:33 PM
rcbobcat55 is online now
Find More Posts by rcbobcat55
sailplane nut
Herminie, PA 15637
Joined Apr 2007
F-16 foamie glider
Hello out there from RCbobcat55@yahoo Has anyone other than me looked at the Estes F-16 toy foam glider? I picked one up over the weekend at a local Cracker Barrel Restaurant and intend to convert it to a micro pusher jet. It has all the right moments and if you were to use tailerons you could remove the wings for transportation or shipping. I have ordered a small outrunner from HobbyKing and a 6 amp esc and will be converting it to RC. It spans about 21" and the wings are stretched a bit from the scale outlines but it looks really cool. It looks like it is made from the same grey foam that multiplex uses on some of its arf jets and pusher models. I am even thinking of building one as a micro slope jet. Maybe I can inspire others to try it out too. I am looking into buying a case of them to resell to others who cannot locate them locally. They sell for $15.00 a cheap pusher jet indeed. Anyone else interested in trying this I will take some photos of the build as I go along. How about someone coming up with an unusual semi scale color scheme? I saw some wild ones out at Luke AFB about a year ago when I was out there. Ok enough of this babbling. Thanks for listening Bob M.
rcbobcat55 is online now Find More Posts by rcbobcat55
Old Mar 16, 2012, 01:01 PM
jhmagill is offline
Find More Posts by jhmagill
Joined Dec 2004
I just picked one up at Cracker Barrel. Looks like it has possibilities. My thoughts are to cut out the cockpit area for all the radio equipment but I'm not sure what that would do to it structurally.
It has the perfect spot for micro servos between the wings and the elevator.
jhmagill is offline Find More Posts by jhmagill
Old Mar 19, 2012, 09:27 PM
JetMech2002 is offline
Find More Posts by JetMech2002
Racing Enthusiast AMA 3557
JetMech2002's Avatar
United States, MO, Sedalia
Joined Sep 2011
Got a couple today with Crashawk to convert to pusher config. Thanks for the heads up. Apparently Cracker Barrel is the exclusive distributor on these. Going to use a Turnigy 1818-3500kv motor, 2s Rhino 370 pack and a 10a esc. Elevator, aileron, throttle. Taking the dihedral out on the first try. Will try to post pics along the way.
JetMech2002 is offline Find More Posts by JetMech2002
Old Mar 20, 2012, 06:40 PM
jhmagill is offline
Joined Dec 2004
Pictures would be great JetMech2002. What are your thoughts on the tailerons? I've never done a model with tailerons.
Old Mar 21, 2012, 01:12 PM
Joined Sep 2011
I think the tailerons would work fine if you got enough support, but that support comes with added weight in the back, which may create issues.
Video Dynamic Foamie F-16 Indoors nagayama13 Electric Plane Talk 1 Jun 28, 2009 09:06 PM
Wanted Phase 3 F-16 Foamie Bookstar75 Aircraft - Electric - Jets (FS/W) 1 Sep 24, 2008 04:17 PM
