Lake Orion, MI
Joined Jul 2004
Pipistrel Taurus G4
Hi All!
I was reading one of the aviation pages relating to electric flight (full-scale) and found the announcement of the Nasa Green Flight Challenge and the amazing aircraft that won it! The Pipistrel Taurus G4... Go ahead.. Look and drool... Just up our alley, right? ![]() My plans are to build an R/C stand-off scale model of this plane in time for the Toledo show in about a month. I've been drawing, thinking and calculating and accumulating parts since before Thanksgiving. Now is the time to build! I've got here an early systems diagram Here More pictures to come. |
Lake Orion, MI
Joined Jul 2004
Here's what I've come up with so far for equipment.
The servos (all 11 of them) are Hitec HS-81. The ESC is a CC ICE-50. The motor is a brushless 14.4V @ 600-800 Watts (45 A) . The prop is an APC electric 14x10. The radio is a Futaba FASST 7-channel The servo hookups are a mixture of traditional plus new Futaba SBus Here is about what the ribs are going to look like. The spar is connected to a steel rod passed throught the fuse pocketed in aluminum tubes.
Lake Orion, MI
Joined Jul 2004
More Build
2 weeks to Toledo and I've been taking as much time as I can get away with to get this finished.
I've gotten the majority of the wing structure built up and have the lower surface sheeting mounted. Plans are to put in some diagonal bracing (suggested by club members at our "In the Bones" meeting. I'm also planning on applying some carbon tape to the top edge of the spars and battery boxes to further reinforce the center section. I've gotten a start on the motor mount which will also serve as the mounting point for the ESC. In addtion, if I need more cells I have room to put a 3rd pack in series inside the motor mount. I still need to figure out how to strongly mount the motor pod to the center section.
Lake Orion, MI
Joined Jul 2004
Last night the Skymasters Radio Control Club of Michigan had one of their last non-flying club meeting of the Winter which was our annual "In the Bones" meeting.
7 other members had wonderful projects to share with the Membership and guests. I had the first opportunity to fully assemble the model (taped in place) with all of the flight surfaces mounted. The motor pod is taped in place at an approximate angle as I've seen in the full-scale planes angle with the landing gear down. As seen, the canopies are resting in place so this is approximately how it will look with the exception of the motor pod cowl. Some of the suggestions from experienced builders included adding diagonal bracing between ribs, surface carbon fiber tape and tying in the battery bays more tightly to the wing joiner tubes. Another concern raised was about the possiblity of the two tail sections moving in different directions since they are not currently connected in any way. The concern is that this would put twisting stresses on the center section and contribute to instability. The suggestion was to run some sort of joining rod or tube at the rear of the fuselages to maintain separation distance and couple the movement of the tails. We've got a family road trip planned over the next week, so no further progress will happen until the week before Toledo. It's going to be quite the manic week!
| Thread Tools | |
| Sold Scorpio Taurus Plus ARC | brockettman | Aircraft - Fuel - Airplanes (FS/W) | 1 | Apr 01, 2012 06:28 PM |
| Wanted "TAURUS" kit 40-60 size | lla | Aircraft - Fuel - Airplanes (FS/W) | 3 | Jan 14, 2012 12:03 AM |
| Sold Taurus | wizzinbya | Aircraft - Fuel - Airplanes (FS/W) | 7 | Sep 08, 2011 11:47 AM |
| Discussion Pipistrel Taurus G4 | Gil Gauger | Sailplane Talk | 7 | Jul 31, 2011 08:54 PM |
