Old Mar 14, 2012, 04:03 PM
WBD is offline
WBD
Find More Posts by WBD
WBD
Carbon Fiber Geek
WBD's Avatar
United States, TX, Irving
Joined Feb 2012
Question
Turnigy 9X (now ER9X) and nav lights not going off
I have a Turnigy 9x (ER9X) and have wired an E-Flite light controller LED system into my quad which works great except one small detail.
When the switch is on (THR) my lights are nice and bright. With the switch off the lights go dim, not off. Any idea on how to get them to go off when the switch is off?
I tried playing with the EPA but not sure what else to try.
WBD is offline Find More Posts by WBD
Old Mar 14, 2012, 09:23 PM
WBD is offline
WBD
WBD
Carbon Fiber Geek
WBD's Avatar
Joined Feb 2012
bump.
Old Mar 15, 2012, 03:01 AM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
I don't think it's a probem with your RC control but rather with the LED controller. Give us details about it.
Zen09 is offline Find More Posts by Zen09
Old Mar 15, 2012, 08:04 AM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
What channel do you have them plugged into? Are you using any mixes?
To dim an LED you have to pulse it rapidly, simply lowering the voltage won't make them dim the way a filament bulb does, so it sounds like it has something to do with the channel's characteristics. You mentioned the switch you're using as "(THR)", if you have it plugged into the throttle channel that might explain it. That's how the ESC slows a brushless motor, by pulsing it slower. Try connecting the lights to another channel, like the gear (5) channel.
dmccormick001 is offline Find More Posts by dmccormick001
Old Mar 15, 2012, 10:22 AM
WBD is offline
WBD
WBD
Carbon Fiber Geek
WBD's Avatar
Joined Feb 2012
Its an eflite light controller. I have it on the thr switch. Pulsing low makes sense. Ill try moving it and see what happens. Thanks!
Question SETUP Turnigy 9x with ER9X setup for NAZA? Medicineman76 Radios 0 Feb 26, 2012 08:51 PM
Sold Turnigy 9X with ER9X and battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 5 Feb 23, 2012 04:30 PM
Sold Turnigy 9X Version 2 board with ER9X and battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 6 Feb 22, 2012 11:03 PM
Discussion Turnigy 9x + Frsky + er9x JasonR54 Radios 3 Jul 04, 2011 11:16 PM
Help! How can use switch Turnigy 9X(FW. ER9x) in Simulator NiceOh Simulators 3 May 21, 2011 10:51 AM
