Old Mar 14, 2012, 03:38 PM
Dr.JJ is offline
Find More Posts by Dr.JJ
Dr.JJ's Avatar
United States, MS, Biloxi
Joined Feb 2012
A "no landing gear needed" recommendadtion, good for grass landing plane.
I wanted to know what a good plane for landing in a grass field would be. Its not the smoothest field either, kinda chunky w 5-6" grass. I was thinking of a pby catalina 55" wingspand???
Dr.JJ is offline Find More Posts by Dr.JJ
Old Mar 14, 2012, 04:06 PM
RobC(UK) is offline
Find More Posts by RobC(UK)
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
A Multiplex Twinstar with a 250W - 300W brushless conversion and 7" X 4" props is fun off grass. Landing would be no problem but it might do a bit of mowing on take off. Apply some clear packing tape to the bottom of the fuz for protection.
RobC(UK) is offline Find More Posts by RobC(UK)
Old Mar 14, 2012, 04:08 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Iv noticed that any pusher style does good with rough surface landings. My flying wing and FPV Drones are stable enough to bring it to around 5mph before touchdown so very little space is needed. My aircraft range from 30" to 60" wingspan now.
chanyote66 is offline Find More Posts by chanyote66
Old Mar 14, 2012, 04:10 PM
chanyote66's Avatar
Joined Dec 2011
I had the wing come off my dual prop cargo and fly down my yard cutting two 9" wide paths through the grass... lost two good props that day, but gained a nice straight landing guide.
Old Mar 14, 2012, 05:59 PM
Dr.JJ is offline
Dr.JJ's Avatar
Joined Feb 2012
Is there any way to connect 2 motors to one esc and battery?
Old Mar 14, 2012, 06:02 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
To one ESC? Its been done, but the conventional wisdom says no. One battery? No problem.
Lardog is offline Find More Posts by Lardog
Old Mar 15, 2012, 06:43 AM
732002 is offline
Find More Posts by 732002
732002's Avatar
United States, OR, Lake Oswego
Joined Dec 2003
Hyperion sniper/Hacker super zoom.
3D performance with EPP durability. Belly lands easily without the landing gear.
732002 is offline Find More Posts by 732002
Old Mar 15, 2012, 08:27 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I'd recomend what 732002 says. These planes can be hovered in and dropped straight down. Would fly equally well with or without the landing gear, as long as you keep the CG in the right place of course. These are tough birds and any damage can be fixed with a little hot glue.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Mar 15, 2012, 10:17 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
You didn't say whether is had to be an ARF, or whether you were willing to build.
If build, and it is quite a simple build, I would recommend the Polaris, -
Polaris Seaplane Parkflyer thread
It will fly slow or fast, take-off from grass, even from water if you have any locally.
The pictures are of mine -
eflightray is offline Find More Posts by eflightray
Old Mar 15, 2012, 11:49 AM
Desert Rider is offline
Find More Posts by Desert Rider
Joined Mar 2012
Whatever you pick, be sure to move the aileron controls to the top of the wing if it has a low wing.
Desert Rider is offline Find More Posts by Desert Rider
Reply With Quote  (Disabled)
Old Mar 18, 2012, 07:48 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Any foam model with a high mounted pusher motor is ideal for belly landing, no chance to break props on landing, check what is available here:
http://www.rcgroups.com/forums/showthread.php?t=1454577
Doubletap is offline Find More Posts by Doubletap
Old Mar 18, 2012, 09:25 AM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
Multiplex EasyStar is a perennial favorite for this purpose (belly landings on any kind of surface.) Put some packing tape on the bottom of the fuselage.
rafe_b is offline Find More Posts by rafe_b
Old Mar 18, 2012, 09:46 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
"Polaris, "
I built one of those years and years ago, but it wasn't called a polaris. I don't remember the name it had then.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Mar 18, 2012, 09:56 PM
tom1968 is offline
Find More Posts by tom1968
Still circling in sink...
United States, MA, Grafton
Joined May 2006
The Parkzone Corsair (full-size, not micro) does fine on a field like that. I added some wedge-shaped "hats" made from folded aluminum flashing to protect the servo arms, and built it without the LG. Several dozen flights, still in good shape. Also any EPP or EPO flat foam 3D plane. Or a flying wing, as long as the aileron linkages are on top of the wing and not underneath.
tom1968 is offline Find More Posts by tom1968
Old Mar 18, 2012, 10:23 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
And if you want something a little more stout then packing tape for protection, check out anti chip tape. It's the stuff auto manufactures use on the rocker panels, door edges, and fenders for paint protection. 3M is a major maker of it, you can get small sections at most auto parts stores. Or if you are silly like me you buy a roll of it.
It's a little thicker then packing tape, but way tougher. I use it on all of my birds for those just in case situations. Like where the gear fails and sliding across a paved run way could tear the bottom off. The tape handles it just fine, and if you tear it up, it's a snap to replace it.
Even on the sponson of my water craft. Slips right over grass and dirt, and even the occasional asphalt and concrete.
http://solutions.3m.com/wps/portal/3...be7PJ6KTK7DLgl
Glacier Girl is offline Find More Posts by Glacier Girl
Discussion Breaking props on plane with no landing gear Bladebuster Electric Plane Talk 7 Jan 19, 2012 09:49 PM
Discussion SuperCub belly landing-no landing gear joshgfeller Beginner Training Area (Aircraft-Electric) 9 Jan 13, 2012 11:32 AM
Wanted lookin for good t250 or clone no gyro or rx needed blueindian Aircraft - Electric - Helis (FS/W) 1 Sep 06, 2011 11:49 AM
Wanted WANTED no NEEDED - Kyosho Sukhoi and Cap232 Landing Gear!!!!!! Rondog Aircraft - Fuel - Airplanes (FS/W) 2 Nov 26, 2005 02:15 AM
