Old Mar 14, 2012, 01:45 PM
TheZero is offline
Find More Posts by TheZero
South Africa, GP, Krugersdorp
Joined Aug 2011
Question
GoPro video out cable pin-out
Hi all
Trust that you are all well!
I know it has been posted before, but now I cannot find it ....
Anyone got the pin-out for the goPro video cable to connect to a tx module?
Thanks!
TheZero is offline Find More Posts by TheZero
Old Mar 14, 2012, 02:15 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
PinFunction
GND
R video out – component Pb/Cb or composite (composite video out activated by grounding ID2 and ID3, component video out activate by grounding ID2).
G video out – component Y
B video out – component Pr/Cr
USB +5V power
as above
USB Data+
USB Data-
GND
Audio out Right
Audio out Left
Pwr/Mode button (tie to ground to activate)
Playback mode button (tie to ground to activate)
Audio in Right
Audio in Left
IR input
Trig digital output
GND (?)
ID1 digital input
ID2 digital input
ID3 digital input
ID4 digital input
Adapter output – power output for external equipment (follows internal battery power).
as above, but only powered when camera is on
VBat+ external power input ?
as above
GND
DATA interface I2C
CLK interface I2C
GND
daign is offline Find More Posts by daign
Old Mar 14, 2012, 02:30 PM
TheZero is offline
Joined Aug 2011
Hi there
Thanks, but I am actually looking for the pin-out of the side "earphone - type" connecter ...
Old Mar 14, 2012, 04:19 PM
FullmoonCat is offline
Find More Posts by FullmoonCat
Rank Amatuer
FullmoonCat's Avatar
United States, ID, Boise
Joined Dec 2011
Hm. If you strip the covering off the cable, you'll find standard video and audio wires, and a shield wire. Connect the shield wire to a ground wire (the negative wire of your power out/in), and the other wires to their appropriate places (yellow to video, white to audio).
That should do it.
FullmoonCat is offline Find More Posts by FullmoonCat
Old Mar 14, 2012, 04:57 PM
sg1anubis is offline
Find More Posts by sg1anubis
sg1anubis's Avatar
United States, AL, Huntsville
Joined Sep 2011
If you want a really clean cable I would suggest that you strip the stock cable down to the jack and remove the plastic encasement with a heated knife. Then you can solder wires directly to the jack and put some heat shrink over them to keep it protected. To figure out what part of the jack to solder to use a volt meter to test the continuity between the colored wires and the jack before removing those wires. Then just solder up the cable and you're done. I have a few pictures on my website from when I setup my FPV gear, but unfortunately I didn't think to take any pictures of how I soldered the cable.
http://polakiumengineering.org/?p=930
Scroll down a bit to pictures 6 & 12 and you'll see pictures of the cables I used with labels for each of the pins.
You may also want to check out this article:
http://www.rcgroups.com/forums/showt...ight=gopro+pan
sg1anubis is offline Find More Posts by sg1anubis
Old Mar 14, 2012, 05:02 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Or do this the simplest way and go here...
http://www.readymaderc.com/store/ind...1ndcn1i0ugoak5
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Mar 14, 2012, 05:04 PM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
Here is another one
http://www.rcgroups.com/forums/showthread.php?t=1612199
CheckSum is offline Find More Posts by CheckSum
Old Mar 14, 2012, 05:32 PM
TheZero is offline
Joined Aug 2011
Thanks for the reply's all of you, much appreciated.
I would buy a cable tomorrow, but shipment to South Africa takes forever + a day ...
Best answer so far from sg1anubis, thank you, will do the multimeter test. I am using a non gopro cable, so don't know yet what the wire colours will be ...
Old Mar 14, 2012, 05:37 PM
cryhavoc38's Avatar
Joined Mar 2007
understood about making one. much quicker.
just found this from diy drones
very inexpensive.
https://store.diydrones.com/Camera_L...cam-cbl-03.htm
Old Mar 14, 2012, 07:36 PM
CheckSum is offline
CheckSum's Avatar
Joined Jan 2011
very inexpensive.
Very nice, thank you!
Ctrl + D
Old Mar 15, 2012, 12:25 AM
sg1anubis's Avatar
Joined Sep 2011
I went ahead and wrote up a new tutorial explaining how I made the cable:
http://polakiumengineering.org/?p=1209
I also put together a new pinout.
Old Mar 15, 2012, 02:52 AM
TheZero is offline
Joined Aug 2011
Perfect!
Thank you!
Old Mar 15, 2012, 03:44 AM
brodjack is offline
Find More Posts by brodjack
usual old know-it-all
Blackpool,U.K.
Joined May 2005
nice one,just made one for my Gopro
brodjack is offline Find More Posts by brodjack
Old Mar 15, 2012, 04:23 AM
QiW is offline
QiW
Find More Posts by QiW
QiW
south east asia
Joined Mar 2009
here is a video guide .. its NOT MY VIDEO but something i found
How To Use a GoPro for FPV (7 min 12 sec)
QiW is offline Find More Posts by QiW
Old Mar 15, 2012, 09:05 AM
TheZero is offline
Joined Aug 2011
Now I am confused - the posted video above give different pin-out's?
Who is right here???
Discussion Need Pin Out diagram for Dominator Head Tracking Cable wannabe FPV Talk 1 Jan 21, 2012 06:35 PM
Help! GoPro video cable with 90 degree connector Stunt Double FPV Talk 5 Sep 30, 2011 09:44 AM
Sold new readymaderc gopro video,audio out cable ROCKY2 FPV Equipment (FS/W) 6 Sep 08, 2011 08:57 PM
Question Airtronics SD10G data download cable pin-out? whopkins Radios 2 Jun 23, 2011 06:06 AM
Trainer Cable Pin-out SkyCaptian Radios 1 Apr 20, 2005 01:54 PM
