Old Mar 14, 2012, 08:25 AM
leo.geo is offline
Find More Posts by leo.geo
leo.geo's Avatar
Joined Sep 2011
Help with buying a good motor to perform with my esc
hi guys, i have 2 turnigy 25A Plush esc's....
will these motors work well with them? i need sum help!!!
please let me know you pros!!!
http://www.hobbyking.com/hobbyking/s...dProduct=14738
leo.geo is offline Find More Posts by leo.geo
Old Mar 14, 2012, 09:29 AM
matthew_herbe is offline
Find More Posts by matthew_herbe
United Kingdom, England, Crawley
Joined Nov 2011
they look fine for the esc's motors max current is 15.8A so 25Amp esc will be fine.
matthew_herbe is offline Find More Posts by matthew_herbe
Old Mar 14, 2012, 02:14 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Yeah, that motor will work fine with your ESCs, but the airframe might not. You'll need a fairly specific motor and prop for any given plane, and simply choosing a motor that works with your ESC isn't a great way to match up a power system.
What plane is this intended for?
Piece is offline Find More Posts by Piece
Old Mar 15, 2012, 04:44 AM
leo.geo is offline
leo.geo's Avatar
Joined Sep 2011
i plan to use twin motors on a cargo plane, the one from the ..''twins'' thread... if an esc is rated at 25amp wont that be too much for a motor with a max current that is 15.8 amps tho?
Old Mar 15, 2012, 06:06 AM
Piece is offline
Piece's Avatar
Joined Aug 2009
No. The motor will only draw as much current (amps) as it needs to spin the prop at your given input voltage. If you put a tiny prop on the motor it might only draw 5A, so that's all the motor and ESC have to handle. The ESC will simply take a maximum of 25A before you risk melting it or burning it out, whereas the motor is limited to about 16A. Since the motor can't take anywhere near what the ESC can, both components will be perfectly happy as long as you run the right prop.
Ideally you want the ESC to be rated about 20-30% higher than the highest amount of current that will ever be drawn by the motor (i.e. when you instantly crank it to full throttle from a dead stop). Your setup is good there.
Old Mar 15, 2012, 06:10 AM
leo.geo is offline
leo.geo's Avatar
Joined Sep 2011
thankyou, your a hero!! cheers for the info... just as a guess what props would you think might be suitable for my project ?
Help! help me pick motor/prop/esc for my quad abcd123 Multirotor Talk 3 Feb 09, 2012 08:29 PM
Discussion Help with my Gaui 500x with 330x power set, scorpion motor problem dwazzer Multirotor Talk 4 Feb 01, 2012 01:48 PM
Question Good 3d plane? with 24g motor and 12amp esc??? pilot1211 3D Flying 20 Jan 03, 2012 04:18 PM
Discussion Need help on a motor/esc combo for my trainer. superfastwrx Power Systems 3 Sep 27, 2011 12:47 PM
Question hey guys, im thinking about buying a Mamba Max ESC and CMs-7700 Motor combo for my 1/ poochy Car Talk 2 Feb 05, 2007 06:21 PM
