Old Apr 12, 2012, 10:51 PM
jsarwar469 is offline
Find More Posts by jsarwar469
Joined Mar 2012
The duratrax i ntelispeed 12t is rated at 8.4v max...what are the chances of it handling a 3s? You guys think it can handle 3s?
jsarwar469 is offline Find More Posts by jsarwar469
Old Apr 13, 2012, 03:32 AM
traxx de maxx is offline
Find More Posts by traxx de maxx
traxx de maxx's Avatar
uk
Joined Nov 2010
no chance. I wouldn't even try it. Even if you ran a seperate bec i still wouldn't go there.
traxx de maxx is offline Find More Posts by traxx de maxx
Old Apr 13, 2012, 07:37 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Agreed, it'll end very badly. 3s fully charged is 12.6v, that's almost 35% more voltage than it is rated for.
wparsons is offline Find More Posts by wparsons
Old Apr 13, 2012, 02:47 PM
Joined Mar 2012
Lets say if I were to try it with a separate BEC which one should i get? ratings wise...how many volts or amps it should be etc.
Old Apr 13, 2012, 03:01 PM
uk
Joined Nov 2010
i still wouldn't use it with 3s, whats the power of the servos
Old Apr 13, 2012, 06:42 PM
Joined Mar 2012
I'd have to check that as soon as I get home...so the BEC connects between the ESC and the battery?
Old Apr 14, 2012, 03:19 AM
uk
Joined Nov 2010
no the bec is a battery eliminator circuit it plugs into the receiver to power the electrics by using a humpback battery pack.
Normally the bec is in the esc but if you ran a separate bec you would need to cut the red wire from esc to receiver.This is what is the most sensitive to over voltage.
What connects between the esc and battery is the LVC low voltage cut off, completely different thing.
Old Apr 14, 2012, 09:17 PM
Joined Mar 2012
I just added the 17 turn brushed motor and tekin rebel esc to the new RC truck i got.
I have a question. An over heating ESC can stop power supply to the motor? I run it for about a few minutes and suddenly the power starts to cut off to a point where its not moving at all...after waiting for a few mins it runs fine and same thing happens. When i touch the ESC it is very hot...I cant put my finder on it for more than lets say a few seconds. I dont think its the motor because the motor has a heatsink on it and i can touch it no problem. Maybe the 3s is got the ESC sweating idk..
I messaged a guy on rctech im trying to purchase a brushless kit from him. Its the...
castle sct esc with a 1406-1y 6900kv motor
Is that a good combo for a 1/10 4WD monster truck? It will also be paired with the 3s ofcourse.
Old Apr 14, 2012, 10:17 PM
kistner is offline
Find More Posts by kistner
Registered Basher
kistner's Avatar
United States, PA, Beaver
Joined May 2008
6900kv is too much for off road, way too much for 4x4 offroad
kistner is offline Find More Posts by kistner
Old Apr 15, 2012, 08:20 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
That motor is way too high of a kv for 2s, nevermind 3s. You want something in the 3000kv range if you're going to run 3s all the time.
Old Apr 15, 2012, 08:39 PM
Joined Mar 2012
What do yous thinks overheating? esc or motor? cause car totally stops after like 5 minutes of driving..then i have to wait a minute or 2 before it starts going again...im using a buzzer alarm and it shows 11 volts still elft
Old Apr 16, 2012, 07:25 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
What feels hot? It could be all of the above.
The ESC is the only component that will actually stop from heat and then work again. If you over heat a motor to the point it stops running, its usually toast for good.
What truck is this in?
Just an FYI, 11 volts resting on a 3s pack is more discharged than you want. Under load it's probably dipping to 10v or lower. The lowest you want is about 3.5v per cell under load.
You should be getting a lot more than 5 minutes before dipping that low though, my stadium truck with a 4000kv brushless gets about 40 minutes of running on 4000mah. (I run 5000 mah packs, but try to never discharge beyond 80% of their capacity). Is your pack getting a full charge (up to 12.6v)?
Old Apr 16, 2012, 06:48 PM
Joined Mar 2012
The ESC is main thing getting super hot to the touch.....besides that after lipo incident where it dropped voltage below 8v total the battery wont charge above ~3.85 per cell...guessing its time for a new lipo.
Old Apr 17, 2012, 09:52 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
If you can't get the pack above 3.85v/cell, it's definitely toast. Is the charger stopping automatically at that voltage, or is it timing out after charging for too long?
If the ESC is that hot, you're pulling too much power through it. You either need less voltage or a milder motor, or milder gearing.
Old Apr 18, 2012, 02:47 AM
Joined Mar 2012
Well this is weird...yesterday the charge was not going above ~3.85/cell after 15 mins of trying....today it charged right up to 4.20 each cell.
I ordered a 2S 5000 mah pack anyways. My next purchase is definitely a brushless combo.
Sold FS HPI Nitro RS4 2 Brand New Never Run. fastmax Cars - Cars and Parts (FS/W) 0 Mar 08, 2012 01:02 PM
For Sale HPI MT truck and HPI RS4 BennettOZ84 Cars - Cars and Parts (FS/W) 3 Apr 11, 2009 07:39 PM
For Sale hpi rs4 MT2 with new g3.0 engine + stuff! ranger306ci Cars - Cars and Parts (FS/W) 0 May 23, 2008 06:48 AM
For Sale HPI RS4 Rally HPI Nitro MT HPI Micro RS4 TeamAE RC10B4RS LexLutherXI Cars - Cars and Parts (FS/W) 4 Feb 28, 2008 11:56 AM
WTB New/Like New HPI RS4 MT RTR McGrrr Cars - Cars and Parts (FS/W) 4 Nov 17, 2003 12:00 AM
