Joined Mar 2012
Ran the rustler today with the ezrun 6000kv motor with 3s......geared at 18/86 and i got a max reading of 53mph with some off road tires. after about 7 laps back and forth the motor and the esc is not even warm.....well maybe because it was 1am...lol. I'm gonna try to dig up for a slightly larger pinion and put some street tires on and see test out again.
Still havent tried the CC 4pole 4600kv I think that one might be faster with 26/86 and 3s w/ street tires. i'm liking this! cant wait to pick up the tekin sc4x,,,,or a LRP vector 6.5 or something. Im just buying random motors that seem good in specs and name brand to go for top speeds without having to break the bank....what do you guys suggest which motor should I look at if i want to stick to 3s...and get 80 mph? *EDIT* I'm trying to choose between the Tekin Redline 6.5 sensored (6.5 Turns, 6700kv, 404 watts, 12.5mm rotor) and Tekin SC4X (4.5T, 4800Kv, 900 Watts, 12.5mm rotor) which one to get if I want to gear high??? I'm going for top speed, torque is not the main priority....but i also understand with a lower kv motor i'm able to run a bigger battery and bigger gears. |
Joined Mar 2012
the sc4x a local guy selling me one for 42 so I might just buy both and try them out. So on the way back from my class I picked up some custom gearing for the rustler....picked up a 62T 32pitch spur and a 22T pinion and I just ran it like 10 minutes ago with the castle creations 4pole 4600kv motor with 3s lipo and Im not very happy with the results.....the CC 4pole IS more torqy but the cheap ezrun 6000kv motor actually feels faster (top speed) with much higher gearing (86/26). |
Joined Mar 2012
But I remember reading somehwere in forums that MMP is only 65amp constant and a 100amp burst so I never really saw the point of buying one when 120 amp esc's are like half the price. but got one anyways only because i got lucky and got one used for a good price. Now as far as the motor goes I'm thinking about a few setups... 1 - Either run a Castle Creations CM36 9000kv 3s capable motor with regular gearing and run it on 3s (youtube has some videos people getting over 80mph easy on street cars and a t4 truck). I dont want to deal with heat and letting it cool down and stuff. I mean if a motor is 9000kv and it IS 3s capable pushing 80mph with stock gearing why will it over heat after a pass or two? I'm not pushing its limits or anything. 2 - Or get a Tacon 4074 (2000 - 2100kv) or a 4465 (2400 - 2600kv) 1/8th scale motor and gear it to the sky! both are 5s capable. (I still have to make sure these motors will fit in a rustler....i'm sure they will i'll b running a much smaller spur gear from another vehicle...some guy on youtube revealed the setup in his rustler and Im gonna try do same. kind of a how to video). I'm also picking up some foam tires. What you guys think? |
Just because a motor is rated to take the voltage of 3s, that only means it's ok when geared appropriately. Since that motor wasn't designed for your truck, the stock gearing means nothing to the motor voltage rating. To get big speed, you need lots of watts, not just RPM at the wheels. From what I can find, that old CM36 9000kv motor was only meant for drag cars and the whole CM36 line has been discontinued and replaced by the 1406 motors. Think of this analogy... a lotus elise is a fast car with 180hp, and the engine revs to almost 9000rpm. If you put that same engine in a full size pickup truck, it won't be nearly as fast because you'll need to gear it down a ton to not overheat or bog it down in the heavier vehicle. If you're topping out in the 60mph range because of heat, putting a higher kv motor with the same wattage output isn't going to get you anywhere, you'll need a motor capable of more watts (watts = volts * amps) to get more speed and run cooler. |
Joined Mar 2012
I understand what you're saying. but when buying the motor I was thinking rustler is a 2 wheel drive truck and probably lighter than most of the trucks out there. and with some street tires I might be fine but I guess I'm wrong.
I need a quick advise! the castle neu 1415 2400kv....can it handle a rustler running a 36t spur and a <24t pinion on 3 - 4s lipo? |
The rustler is light for a truck, but compared to a touring car, pan car or drag car it's probably 2-3 times the weight. It's also a lot less aerodynamic so you need more power to push the same speed.
What is your end goal with the truck?? IMO, figure out what speed you want, then look at people that have achieved that and see what they're running. Guessing at random parts, and buying things just because it's a good deal won't get you to where you want to be. |
| Thread Tools | |
| Sold FS HPI Nitro RS4 2 Brand New Never Run. | fastmax | Cars - Cars and Parts (FS/W) | 0 | Mar 08, 2012 01:02 PM |
| For Sale HPI MT truck and HPI RS4 | BennettOZ84 | Cars - Cars and Parts (FS/W) | 3 | Apr 11, 2009 07:39 PM |
| For Sale hpi rs4 MT2 with new g3.0 engine + stuff! | ranger306ci | Cars - Cars and Parts (FS/W) | 0 | May 23, 2008 06:48 AM |
| For Sale HPI RS4 Rally HPI Nitro MT HPI Micro RS4 TeamAE RC10B4RS | LexLutherXI | Cars - Cars and Parts (FS/W) | 4 | Feb 28, 2008 11:56 AM |
| WTB New/Like New HPI RS4 MT RTR | McGrrr | Cars - Cars and Parts (FS/W) | 4 | Nov 17, 2003 12:00 AM |
