Old May 21, 2012, 02:38 AM
jsarwar469 is offline
Find More Posts by jsarwar469
Joined Mar 2012
Say for example turnigy nanotech 6000mah pack rated at 25 - 50C, we dont know the exact discharge rate, so the worst is 150 and at its best 300? Are these kind of batteries reliable? Or should i get one with an exact number for guaranteed output?
And for the 150a+ power system a 6000mah pack at 25c puts out minimum of 150 and maximum of 300, does that fulfill the requirement?
jsarwar469 is offline Find More Posts by jsarwar469
Old May 21, 2012, 08:02 AM
traxx de maxx is offline
Find More Posts by traxx de maxx
traxx de maxx's Avatar
uk
Joined Nov 2010
bigger the better dude,
traxx de maxx is offline Find More Posts by traxx de maxx
Old May 21, 2012, 08:16 AM
kistner is offline
Find More Posts by kistner
Registered Basher
kistner's Avatar
United States, PA, Beaver
Joined May 2008
The second number may be a burst rate
kistner is offline Find More Posts by kistner
Old May 21, 2012, 09:51 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Second number is the burst rating, only good for a couple seconds.
Do yourself a favour and get 40c or 50c packs, 25c isn't going to cut it in an e-buggy. Also stay away from nano-tech packs, they aren't worth the extra money at all.
If you don't care about hardcase packs, you can get either of these:
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
wparsons is offline Find More Posts by wparsons
Old May 24, 2012, 09:32 PM
Joined Mar 2012
I have a question regarding the novak brushless kits, they say a 550 size novak hv motors are "required". I want to know of that's really the only choice I have when it comes to motors....or can any 550 size motor will fit the mount?
Old May 24, 2012, 10:26 PM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
I would think any 550 will work. Most motors I've bought list the distance between the mount holes so you should be able to check if you have another motor in mind.
Old May 24, 2012, 11:13 PM
Joined Mar 2012
well this conversion kit doesn't use the motor mount holes....it uses a heatsink mounting thing...are all 550 size motors same in outer diameter?
Old May 25, 2012, 04:59 AM
Joined Mar 2012
Well this is weird. i just tried the stock RC 540 that came out my stock exceed rc monster truck and it wont fit the heatsink...550 is supposed to be bigger than the 540 right?
Old May 25, 2012, 01:33 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
550 is just longer than 540, the outer diameter should be the same. If the mount is relying on the outer diameter of the motor, the novak 550's might be a bit bigger if they're finned.
Any picture of the mount setup?
Old May 25, 2012, 02:49 PM
Joined Mar 2012
teamnovak.com/products/brushless/hv_conversion_combo/index.html
if you slide down all the way there are pictures of all the items in the kit and u can find the mount there...the one I bought is for a mbx5 or something so it seems like ill have to drill 2 new holes...gonna pick up a mod 1 pinion and use a 550 motor to determine where to drill holes
Old May 25, 2012, 06:52 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Do you have the mount in your hands yet? If you do, put a non finned 540 motor in it and see how it fits. You can figure out the motor diameter needed from there. I'm not sure which diameter Novak lists as their 550's have part of the can finned and part not.
Old May 25, 2012, 07:33 PM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
novak 550's are 36mm wide - standard width and the same as typical 540's
Old May 25, 2012, 09:05 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Are they 36mm at the finned part, or the smooth part?
Old May 26, 2012, 01:03 AM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
No finned part, its all smooth
Old May 26, 2012, 01:45 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
They look finned to me at the ends, but I can't tell from pictures if its actually any bigger in diameter or not.
Sold FS HPI Nitro RS4 2 Brand New Never Run. fastmax Cars - Cars and Parts (FS/W) 0 Mar 08, 2012 02:02 PM
For Sale HPI MT truck and HPI RS4 BennettOZ84 Cars - Cars and Parts (FS/W) 3 Apr 11, 2009 08:39 PM
For Sale hpi rs4 MT2 with new g3.0 engine + stuff! ranger306ci Cars - Cars and Parts (FS/W) 0 May 23, 2008 07:48 AM
For Sale HPI RS4 Rally HPI Nitro MT HPI Micro RS4 TeamAE RC10B4RS LexLutherXI Cars - Cars and Parts (FS/W) 4 Feb 28, 2008 12:56 PM
WTB New/Like New HPI RS4 MT RTR McGrrr Cars - Cars and Parts (FS/W) 4 Nov 17, 2003 01:00 AM
