Old May 14, 2012, 07:03 PM
jsarwar469 is offline
Find More Posts by jsarwar469
Joined Mar 2012
I picked up 4 chassi from a local guy and he gave me a good deal on it.
-Duratrax BX buggy electric
-Traxxas Rustler electric
-Traxxas Stampede
-HSP bazooka Nitro Buggy (all parts interchange with OFNA)
Those are the 4....the rustler I'll be keeping for spares for my rustler....And out of the other 3 I dont know which one to start with....they all need electronics and wheels/tires...The HSP bazooka he mentioned the parts are interchangeable with the OFNA 9.5 Violator....and he also said something about electric conversion being possible and somewhere online the parts can be found.
I'll probably keep the duratrax but the stampede and the OFNA they have to go....Before posting this on any forums I would like to know are there really electric conversion kits for it?
And lastly, If I find the parts for these out of my budget and decide to let someone else work on them what are they worth? the stampede, hsp bazooka, and the duratrax? rememer there NO electronics at all...not even servos.
jsarwar469 is offline Find More Posts by jsarwar469
Old May 15, 2012, 12:37 PM
rustlererad3 is offline
Find More Posts by rustlererad3
Outdoor Extremist
rustlererad3's Avatar
Pennsylvania
Joined Jul 2010
stampede maybe 100
rustlererad3 is offline Find More Posts by rustlererad3
Old May 15, 2012, 01:53 PM
kistner is offline
Find More Posts by kistner
Registered Basher
kistner's Avatar
United States, PA, Beaver
Joined May 2008
that might be a bit high on the stampede, depending on how used it is. You can get a new chassis on ebay $42-47, new vxl trans $30-40. round up for shocks, slipper, odds and ends and you are close to $100 shipped for a new one like pictured above.
kistner is offline Find More Posts by kistner
Old May 15, 2012, 02:05 PM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
Novak makes a conversion kit for the ofna violator
Old May 15, 2012, 04:49 PM
Joined Mar 2012
Looks like the Novak 5015 is out of stock and discontinued...I dont want to get into nitor so I guess it'll have to go too.
EDIT: Looks like there are a few on eBay 5010, 5013, 5017, 5019, 5069
Will any of those work on the Ofna 9.5? THeres not much information on ebay. But what im trying to figure is which one of those come closest to fit the 9.5? I'm sure im going to have to mod a few things.
You think 80 shipped is a fair price? or lower?
Old May 15, 2012, 09:05 PM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
80 sounds like a good number if its pretty clean, not giving it away either.
5015 is the novak ofna kit
Old May 15, 2012, 09:13 PM
Joined Mar 2012
Its super clean...I'll take some snaps and post it.
Yea the ofna it is 5015 but its out of stock.
EDIT:
I've made a thread
http://www.rcgroups.com/forums/showthread.php?t=1653800
http://www.rctech.net/forum/r-c-item...-pictures.html
The stampede i posted it for 65 + shipping...if one of you fellas whose been posting here frequently and would like to buy i can do 65 free shipping.
Old May 17, 2012, 06:10 AM
Joined Mar 2012
Whats do you guys think the HSP bazooka is worth? the roller I have it up and Im getting offers but I really dont know what its worth or how much I should sell it for.
Old May 19, 2012, 04:12 AM
Joined Mar 2012
Ok so after researching a little I have found the novak brushless conversion kits posted for the cars they all use a universal chassis. So i've decided to keep the hsp bazooka for now and i'm planning on working on this car slowly. I'll be ordering the conversion kit 5014 in a few days because the motor mounts and the battery mounts are all look alikes in all of the pictures and the chassis seem to have similar screw holes etc.
I have started to look into 1/8 size Motors...and for this particular buggy is 2300kv too high or is it just fine?
Also will a 1/10th scale motor work with is if the KV is low enough?
And the ESC doesnt matter right? As long as it can live up to the motors demand correct?
Old May 19, 2012, 07:29 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You'll want the bigger motor for a 1/8th scale vehicle, as well as a higher amp ESC. At a minimum I would say a 3674 motor, but I would go for a 4060 or 4074, and whatever size you want about 2000-2200kv.
You'll need either a 4s5000mah pack, or two 2s5000mah packs in series to run it as well.
*edit* - motor sizes are diameter and length, so a 3674 is 36mm diameter and 74mm long.
wparsons is offline Find More Posts by wparsons
Old May 19, 2012, 03:52 PM
Joined Mar 2012
Got ya! thanks
the mah capacity has to match ? I cant run 2 batteries with different mah's? If I do I'll have to run a lipo alarm or something for the lower one? or what if the ESC has lipo cutoff it wont detect the low voltage on the lower mah pack?
Old May 20, 2012, 07:45 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You'll want to run the same mah... ideally two identical packs. For my boat packs (it runs two 2s in series), I have matched pairs that were bought together and only ever run together, that might be a little extreme, but it makes things more consistent.
Old May 20, 2012, 05:48 PM
Joined Mar 2012
No thats not extreme thats smart....will last longer that way i bet.
I want to get a battery with a good size amp putout....how do i determine that?
Is it the discharge rate that determines how quickly or how many amps it can put out?
Lets say If i get a brushless system and I want to get the MOST out of it, I would need a battery that can handle the amps, so what does that really mean like how much amps the battery can put out when fully pressed on throttle?
Old May 20, 2012, 06:17 PM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
Ideally you would want your battery to exceed your draw. Current is the amp hour rating on battery times the c rating. 4000mah times 30c gives 120 amp available. You have to divide milli amphours by 1000 to get amphour
Old May 20, 2012, 07:48 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
For a 1/8th scale buggy, you'll want a power system thats ok with ~150a, and you'll want 40c to 50c 5000mah packs (40c 5000mah = 200a constant if it's a true 40c pack).
Definitely don't under spec the ESC or batteries, 1/8th scale e-buggies can pull A LOT of amps.
Sold FS HPI Nitro RS4 2 Brand New Never Run. fastmax Cars - Cars and Parts (FS/W) 0 Mar 08, 2012 01:02 PM
For Sale HPI MT truck and HPI RS4 BennettOZ84 Cars - Cars and Parts (FS/W) 3 Apr 11, 2009 07:39 PM
For Sale hpi rs4 MT2 with new g3.0 engine + stuff! ranger306ci Cars - Cars and Parts (FS/W) 0 May 23, 2008 06:48 AM
For Sale HPI RS4 Rally HPI Nitro MT HPI Micro RS4 TeamAE RC10B4RS LexLutherXI Cars - Cars and Parts (FS/W) 4 Feb 28, 2008 11:56 AM
WTB New/Like New HPI RS4 MT RTR McGrrr Cars - Cars and Parts (FS/W) 4 Nov 17, 2003 12:00 AM
