Old Mar 14, 2012, 12:40 AM
hidaven is offline
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
LiFe/ a123 rx pack voltage and servos
Hi, when the 2s LiFe packs are fully charged they read like 7.2 volts for a short time then drop to 6.5 and stay that way for the duration. Now i run these on 6v servos and they are fine taking the 6.5 volts. Im a little concerned about the initial 7.2V spike that they see in the beginning. Is this a concern?
My thoughts are to charge the lifes to maybe 95% to avoid this......Your thoughts?
TIA, Dave
hidaven is offline Find More Posts by hidaven
Old Mar 14, 2012, 01:07 AM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Imo, the "spike" will eventually cause 6v servos to deteriorate at faster levels. Even 6.5v would have the sam effect over time, meaning your servos won't last as long.
I use 2S lipos thru a Bec set at 6v for this very reason. Overvoltage leads to overamping, which will have detrimental results sooner than later.
You could certainly still use A123's thru a 6v Bec if you wished. Any plane big enough to require a separate Rx supply will handle the little extra weight of a Bec. Again, my opinion. Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Mar 14, 2012, 02:43 PM
600Bob is online now
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
A 5 cell NiMH battery charges to over 7 volts too, how many people run them through a regulator?
600Bob is online now Find More Posts by 600Bob
Old Mar 14, 2012, 04:44 PM
hidaven is offline
Joined Apr 2009
Thats true..........From what I read, if I charge these packs the night before i fly, they should discharge to the 6.5v level on their own......No biggie.
Sold Full micro Spektrum Flight pack W_motor/esc/rx and servos SilverHeli2000 Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 09:25 AM
Discussion Newbie to life/a123 and using for rx minnreefer Batteries and Chargers 20 Mar 14, 2012 07:54 PM
Sold Hobbico Life 2100 rx 6.6v pack - new rino Aircraft - General - Radio Equipment (FS/W) 3 Mar 03, 2012 09:55 AM
Discussion LiFe RX pack for Futaba R617FS Receiver HELP !!! Tracon Electric Plane Talk 17 Feb 18, 2012 07:46 AM
Help! Voltage regulator for LiFe RX battery? DavidEFM Power Systems 2 Oct 07, 2011 07:02 PM
