Old Apr 11, 2012, 03:15 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
So are we really saying that this unit from BEVRC is the EXACT same device (including firmware revision) as the acclaimed FJ-DVR-SD4 ??
Ian Davidson is offline Find More Posts by Ian Davidson
Old Apr 12, 2012, 02:20 AM
aeromodellers is offline
Find More Posts by aeromodellers
Joined Sep 2010
No.. the firmware is different. Hardware is the same.
BEVRC has customized the firmware with their logo in the spash startup screen and they have removed the "motion detect" function. Rest all functions are the same.
THe quality of the recordings are quite good for such a small recorder.
aeromodellers is offline Find More Posts by aeromodellers
Old Apr 13, 2012, 03:51 PM
igorek82 is offline
Find More Posts by igorek82
United States, NY, New York
Joined Apr 2011
In this case it's only a matter of time until someone uploads FPV-Japan's firmware onto it.....
igorek82 is offline Find More Posts by igorek82
Old Apr 14, 2012, 10:51 PM
Joined Sep 2010
Does anyone has an access to the firmware? i could nt find the firmware for this recorder.
Old Apr 15, 2012, 05:15 AM
bovi is offline
Find More Posts by bovi
Joined Oct 2010
I do not have BEVRC logo.
I have splash FPV-JAPAN in the middle of screen at start and then FJ-DVR-SD4 on low right corner...
No sign of BEV anywhere.
bovi is offline Find More Posts by bovi
Old Apr 15, 2012, 01:36 PM
Thermicdude is offline
Find More Posts by Thermicdude
Still hackin'
Thermicdude's Avatar
Port Elizabeth, South Africa
Joined Nov 2005
Where and when did you purchase it?
Thermicdude is offline Find More Posts by Thermicdude
Old Apr 15, 2012, 01:41 PM
bovi is offline
Joined Oct 2010
At BEVrc, on 22.03.2012, received on 03.04.2012. But got without battery ...
Old Apr 15, 2012, 01:44 PM
Still hackin'
Joined Nov 2005
The plot thickens - bought mine at pretty much the same time as yours but it arrived with a battery. The FPV Japan model comes sans battery which for various reasons is shipped separately from the US; looks like you got one of those! BTW, bevrc.com or .net?
Old Apr 15, 2012, 03:30 PM
bovi is offline
Joined Oct 2010
http://www.bevrc.com/bevrc-pv700-hig...der-p-297.html
Probably they forgot to flash my device with bevrc logo
Old Apr 18, 2012, 02:14 PM
Ho-Jazz is online now
Find More Posts by Ho-Jazz
Taking care of business
Ho-Jazz's Avatar
United States, GA, Buford
Joined Nov 2009
Looks like the price is now 199.00. Daymn my luck...went to buy today and its gone up. Any you guys still see the 119.00 price??
Ho-Jazz is online now Find More Posts by Ho-Jazz
Old Apr 18, 2012, 04:38 PM
bovi is offline
Joined Oct 2010
When you add it to chart, there should be $119 in shopping list, i just tried.
Old Apr 18, 2012, 04:41 PM
Ho-Jazz's Avatar
Joined Nov 2009
I logged in, put in cart. It's 199.00 on my end with 20.00 ems shipping. What country you in bovi? Wonder if that's the diff. I just tried it again. 199.00. And your link above does not work anymore for me.
Old Apr 18, 2012, 05:13 PM
bovi is offline
Joined Oct 2010
Weird... I am from Slovenia.
Even if I am not logged in, there ie $119.
And i tried 2 diffrent browsers... Link is OK.
Old Apr 18, 2012, 05:30 PM
rogueqd is offline
Find More Posts by rogueqd
Quads, 4 times the fun.
Australia, NSW, Brookvale
Joined Apr 2011
Mine arrived today. I have to say I'm glad I didn't pay $199 for it. It looks like it was a factory second from Japan-FPV or something.
It has scratches on the back of the case, only slight surface ones but it's supposed to be new. When I pulled it out of the box one side had some white residue on it (which wiped off). Also the wired remote on/off button looks like someone's kid made it and the white label on the battery was stuck on crooked.
Delving further in, the 2.5mm 4 pin plug for AV-in is a custom pin layout so you can't use a standard 4-pin cable. Standard is audioR-audioL-video-ground, BEVRC is +5v, video, ground, audio. If I want to eliminate the RCA plugs and go straight from my receiver to the unit I'm going to have to buy a 2.5mm plug and make a custom cable. EDIT: I've done this, the solder points on a 2.5mm plug are almost surface mount size.
Most disappointingly, there appears to be no 720x576 video mode. I have an NTSC camera. 640x480 produces a good image. 720x480 turns the circles in to ovals, and 720x576 records a 720x480 video, that has the same bad aspect ratio. I tried a PAL camera and got the same results. So in the end you can only record at 640x480.
Apart from that it seems to work well. The picture looks good (at 640x480), you can turn the time stamp on and off and it records through static.
Version says: B257.11.08.22
Test equipment:
Camera: PZ0420 from http://www.securitycamera2000.com
Video Tx/Rx: 5.8Ghz 200mw from Hobby King
Recorder: BEVRC PV700 high quality digital video recorder
Code:
General
Complete name                  : E:\Temp\BEVRC Recorder\640x480 test.AVI
Format                         : AVI
Format/Info                    : Audio Video Interleave
File size                      : 27.4 MiB
Duration                       : 20s 777ms
Overall bit rate               : 11.1 Mbps
Video
Format                         : MPEG-4 Visual
Format profile                 : Advanced Simple@L5
Format settings, BVOP          : No
Format settings, QPel          : No
Format settings, GMC           : No warppoints
Format settings, Matrix        : Default (MPEG)
Codec ID                       : XVID
Codec ID/Hint                  : XviD
Duration                       : 20s 633ms
Bit rate                       : 11.1 Mbps
Width                          : 640 pixels
Height                         : 480 pixels
Display aspect ratio           : 4:3
Frame rate                     : 30.000 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Compression mode               : Lossy
Bits/(Pixel*Frame)             : 1.200
Stream size                    : 27.2 MiB (99%)
Writing library                : Zoran
Audio
Format                         : ADPCM
Codec ID                       : 2
Bit rate mode                  : Constant
Bit rate                       : 88.2 Kbps
Channel(s)                     : 1 channel
Sampling rate                  : 22.05 KHz
Bit depth                      : 4 bits
Stream size                    : 225 KiB (1%)
Interleave, duration           : 92 ms (2.75 video frames)
General
Complete name                  : E:\Temp\BEVRC Recorder\720x480 test.AVI
Format                         : AVI
File size                      : 44.9 MiB
Duration                       : 30s 196ms
Overall bit rate               : 12.5 Mbps
Video
Codec ID                       : XVID
Duration                       : 30s 33ms
Bit rate                       : 12.4 Mbps
Width                          : 720 pixels
Height                         : 480 pixels
Display aspect ratio           : 3:2
Standard                       : NTSC
Color space                    : YUV
Bit depth                      : 8 bits
Bits/(Pixel*Frame)             : 1.201
Stream size                    : 44.6 MiB (99%)
Audio
Format                         : ADPCM
Codec ID                       : 2
Bit depth                      : 4 bits
Stream size                    : 327 KiB (1%)
Interleave, duration           : 92 ms (2.76 video frames)
General
Complete name                  : E:\Temp\BEVRC Recorder\720x576 test.AVI
Format                         : AVI
File size                      : 117 MiB
Duration                       : 1mn 40s
Overall bit rate               : 9 762 Kbps
Video
Codec ID                       : XVID
Duration                       : 1mn 40s
Bit rate                       : 9 676 Kbps
Width                          : 720 pixels
Height                         : 480 pixels
Standard                       : NTSC
Color space                    : YUV
Bit depth                      : 8 bits
Bits/(Pixel*Frame)             : 0.933
Stream size                    : 116 MiB (99%)
Audio
Format                         : ADPCM
Codec ID                       : 2
Duration                       : 1mn 40s
Bit depth                      : 4 bits
Stream size                    : 1.07 MiB (1%)
Interleave, duration           : 92 ms (2.77 video frames)
rogueqd is offline Find More Posts by rogueqd
Last edited by rogueqd; Apr 21, 2012 at 05:21 PM. Reason: Added video info + firmware version + 2.5mm plug info
Old Apr 18, 2012, 08:56 PM
caall99 is offline
Find More Posts by caall99
Power-line attraction pilot
United States, MA, Natick
Joined Jun 2011
it appears that the DVR from BEVRC did in fact go back to 199. i used to be able to add it to the shopping cart and it would show up as 119, but in the last couple days its staying at 199 even in my shopping cart. unfortunate.
it appears this DVR has more limitations than what i thought at first. perhaps its not the best option? is there a better one for a comparable price tag? also, how many of these downfalls can be attributed to firmware and how many to hardware?
caall99 is offline Find More Posts by caall99
Discussion Yet another video recorder Good/Bad? rcimports FPV Talk 0 Nov 14, 2011 12:58 AM
Discussion Does anybody know this Video Recorder Dataage HDPRO DMB mr..speed FPV Talk 0 Nov 13, 2011 03:31 PM
Discussion Supply power to Video splitter and Recorder ? SpookiePower FPV Talk 2 Sep 28, 2011 01:40 PM
Sold Airplanes with free HD video recorder wsalcedo Aircraft - Electric - Airplanes (FS/W) 0 Sep 04, 2011 03:23 PM
