Old Mar 14, 2012, 04:25 PM
Robbie d is offline
Find More Posts by Robbie d
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
I should make up some decals, etc for my PO-2. Flies like a champ on a tiny CD-rom motor
Robbie d is offline Find More Posts by Robbie d
Old Mar 14, 2012, 07:10 PM
Chad Veich is online now
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Excellent choice of subjects Mr. Fawcett! From all accounts the Yak designs make very good models. The highly tapered wing makes some folks nervous but it has proven itself to be very docile despite the narrow tips. I have two Yak-11 designs currently flying, a 66 inch span sport version for racing and an 82" inch span giant scale version, and both builder's are extremely happy with the flight characteristics. The bigger one uses the scale ClarkYH airfoil with 3 degrees of wash out and is, according to the builder, the best flying warbird model he has flown. The smaller one is modeled after the Reno racer "Czech Mate", uses a SD6060 airfoil with the same 3 degrees of wash out and is a really nice flying model with no tendency to snap out, even in very high G turns. I have not doubt that your Yak will be a fine performer as well and I definitely look forward to seeing the finished product.
Here is the 82 inch span version built by a customer in Germany.
And the 66" span racer built by my friend Rober Vogel.
Chad Veich is online now Find More Posts by Chad Veich
Old Mar 14, 2012, 10:12 PM
Guy Fawcett is offline
Find More Posts by Guy Fawcett
RFC Cadet
Guy Fawcett's Avatar
Devon, Alberta, Canada
Joined May 2001
Progress 14-Mar-12
Well today I refined structural details on the fuselage drawing not much to show there
But I also started shaping the elevator and stab. Also managed to make the first piece of the fuselage.
Robbie
The PO 2 sounds great.
Chad
Very Pretty looking planes.
Guy Fawcett is offline Find More Posts by Guy Fawcett
Old Mar 15, 2012, 03:02 PM
Pat Lynch is offline
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
It is looking to be a great build Guy - I have always loved the freedom that comes with building from a 3-view. Did you make 'proper' drawings of the whole model or designing the structure as you go? Many folk, including myself, enjoy seeing how others approach the design/build task.
I hope you keep it up
Pat (also with a couple of unfinished models........)
Pat Lynch is offline Find More Posts by Pat Lynch
Old Mar 15, 2012, 06:37 PM
RFC Cadet
Joined May 2001
Design Philosphy
Hi Pat
What I try to do is create the best set of scale three views that I can. Once the scale drawing is complete I choose the scale of model I want to build and begin adding model structure. When possible I use full scale indicators for locating the models underlying bones. A row of rivets or panel joints indicate a rib or stringer location.
The model structure drawing and templates are added as I go and find a need for them.
In the case of the Yak I drew the rudder/fin assembly started construction and while waiting for glue to set ( I use carpenters glue) I started drawing the elevator/stab assembly and so on until I have an airplane.
Old Mar 15, 2012, 07:52 PM
RFC Cadet
Joined May 2001
Progress 15-Mar-12
Well I started to frame up the fuselage.
Old Mar 17, 2012, 03:27 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Originally Posted by Guy Fawcett View Post
Specification;
Wing Area : 728 sq.in.
Wing Span : 64"
Length : 56'
Proposed Moto r: Axi 5320/34,
Battery : A123 6 series x 2 parallel cells;
Prop : Vario 16D 3 blade 19.9"
Sound: Model Solutions (now Model Sound Inc.), SFX5.3 and 4" speaker.
Thats a big motor for a 64" span model
Mike Smart is offline Find More Posts by Mike Smart
Old Mar 17, 2012, 03:43 PM
eye4wings is offline
Find More Posts by eye4wings
...design-build-fly-publish...
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
A big motor, yes, but there is the weight of a sound system to carry as well Mike.
I'm using an Axi 4120 for my 60" La-5 which I surprised myself by deciding to repair about the time this thread started. ( I crashed it on its second flight three years ago - never got to find out if the automatic wing slats worked as I still had them taped shut).
I'm coming along for the ride so I can compare the two.
Do you have a target weight for yours Guy?
eye4wings is offline Find More Posts by eye4wings
Old Mar 17, 2012, 04:08 PM
RFC Cadet
Joined May 2001
Motor choice
Hi Mike
The motor was chosen for swinging the 19.9" 3 bladed close to scale size prop with sufficient rpm and pitch to produce the speed I want. Notice that the 6s2p pack is below normal size for the motor.
Hi eye4wings
Hoped for target weight is between 9 and 10 LBS. Gets windy here in Alberta and all my biplanes get too easily grounded
Old Mar 17, 2012, 04:25 PM
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
Thanks Guy. The only problem with more weight is that the wing loading and drag go up, but granted it does help a model punch through windy conditions with a better semblance of scale performance than just trying to do it with power alone.
Just checked my motor/prop and it is Axi 4130/16 with 20"x10"x3 not 4120 as stated before. Sorry about that.
I normally overprop my motors but compensate by dropping the cell count so as to balance the current draw - hence the larger pitch than normal. I was running 4S at the time of my crash but I may just try it on 5S if the current draw allows.
Old Mar 17, 2012, 04:43 PM
gbr677 is offline
Find More Posts by gbr677
Joined Jan 2007
Klimov Engine Rotation
Hi Guy
I was in the Museum of Flight last year and saw the original Yak 9U they have. Of interest to me was the reverse rotation of the engine.
I had seen new build Allison powered Yak 3's and 9's and the Klimov rotation was a surprise. Ramoser does left and right blades so it may be an option for you.
You may remember my dad Brent's 56" Enya 45 powered Yak 3 with retracts and flaps. It was an excellent flyer and turned heads in the late 60's-early 70's. It was published in MAN.
Dad built a 70" version for his winter trips to Phoenix in the late 90's. Flew even better at that size. He used it for warbird racing until it was midaired.
Dick Baum from Moose Jaw designed and built an even larger Yak 3 which he still flys.
I will try and rustle up some pictures.
Dad passed away peacefully in Yorkton last month.
Best regards
Garry
gbr677
gbr677 is offline Find More Posts by gbr677
Old Mar 17, 2012, 06:46 PM
RFC Cadet
Joined May 2001
Hi Garry
We really should keep in better touch (mostly my fault I guess). Very sorry to hear of your Dads passing and I do remember watching his Yak 3 flying at the 73 Yorkton Nationals even have some B&W photos somewhere around here.
Thanks for the info on the Klimov. Even with looking at all the pictures I hadn't noticed that and now another quandary, to counter rotate or not to counter rotate. That is the problem. Good thing is I haven't ordered the prop yet.
Old Mar 18, 2012, 03:06 AM
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
From the few pictures I have the Yak9 rotation seems to be clockwise viewed from the front - but in view of the cost of props at this size my own choice is to go with the cheapest available. Unless you fly with a load of Anoraks your bank balance is the most likely to notice the difference.
Making up your own 3-blade from a couple of 2-blade props cheapens it considerably of course - and I was grateful of having a spare blade left over when I crashed. The prop was the first thing repaired.
Old Mar 18, 2012, 10:44 AM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Looking good, Guy! Interesting to see you move on to WW2 models. You just want to chase my 109, don't you!?
Wolpertinger is offline Find More Posts by Wolpertinger
Discussion Yak-3, scale 1:6, composite build LZ23 Electric Warbirds 32 Apr 05, 2013 05:19 PM
Wanted AXI Gold 2217/9D+PG3 Outrunner Motor with 3.1:1 Gearbox PDX Slope Pilot Aircraft - Electric - Power Systems (FS/W) 0 Feb 20, 2011 10:09 AM
Discussion 16% semi-scale F18 Hornet(255% size)from 3-views 8kasl Pusher Prop Jet Models 33 Jun 21, 2006 09:38 PM
Discussion Yak-3 3 Views mikeperik Scale Fuel Planes 5 Jun 09, 2006 02:44 PM
Discussion Yak-3 3 Views mikeperik The Builders Workshop 1 May 17, 2006 12:37 PM
