Old Mar 13, 2012, 10:02 AM
rcnutt is online now
Find More Posts by rcnutt
Centerville, In. USA
Joined Jul 2001
Looking for opinions on foam covering films
Which covering would be the best for white foam, Ultracote, Solar film or Towerkote? The plane is made of the cheap white foam that is used for insulation so I don't think it will handle much heat without melting. RCNutt
rcnutt is online now Find More Posts by rcnutt
Old Mar 13, 2012, 01:13 PM
Joined Jul 2001
I forgot to add econocote from Tower hobbies. RCNutt
Old Mar 13, 2012, 04:22 PM
Mitchell Covell is offline
Find More Posts by Mitchell Covell
Canada, ON, London
Joined Nov 2010
Laminating film is a good alternative if you can source some without having to buy a role. Roles are sized for laminating machines and usually sold in packages of two (top and bottom film). I bought some of the 5mm thickness film sold as pouches (12" x 18") closed on three sides, however the 5mm is much too heavy for a light plane. The 1.5mm or 2mm would be fine. The film is made of polyester, it is very strong, and it is dimensionally stable over a wide range of temperature. Mitch
Mitchell Covell is offline Find More Posts by Mitchell Covell
Old Mar 13, 2012, 09:01 PM
rcjunkie is offline
Find More Posts by rcjunkie
SEFF Contest Director
rcjunkie's Avatar
USA, GA, Stone Mountain
Joined Oct 2000
I've covered foam with all of the films that you mentioned. (not the shelf laminating film). I liked the Ultracote the best because how well it goes around corners and looks great plus they have more color choices. For economy reasons, the econokote from tower hobbies does just fine but with limited color options.
Hope this helps.
Ernie Schlumberger
rcjunkie is offline Find More Posts by rcjunkie
Old Mar 13, 2012, 09:44 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Hope this helps.
Ernie Schlumberger
I give RCjunkie 5 stars! he's right Ultracote from Hangar9 is the best straight on foam!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Joe Nall 2016
Old Mar 14, 2012, 12:57 AM
Lammergier is offline
Find More Posts by Lammergier
Bone Breaker
Lammergier's Avatar
Dallas , Texas, United States
Joined Oct 2002
I use 3mil low temp laminate. Works on depron blue cor and epp. I bought a 250ft roll for $22. sold some and it covered about 3/4 of my cost. Works great!
Lammergier is offline Find More Posts by Lammergier
Old Mar 14, 2012, 08:20 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The covering film from HK works the same as ultracote at very low heat. Stretches and shrinks about the same. I covered this 1/3 scale Christen Eagle with it. Would have cost quite a bit for Ultracote. The HK stuff is $8.28 for 5 metres. Works very well.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Mar 14, 2012, 08:35 AM
rcjunkie is offline
rcjunkie's Avatar
Joined Oct 2000
Good looking covering job Gord. Wish I knew that Hobby King covering worked that well. I might have gone that way on my Decathlon. Just bought $150 worth of 21st century to cover it.
Ernie
Old Mar 14, 2012, 11:27 AM
Joined Jul 2001
Lammergier -- Where did you but the 3 mil laminate? Does it come in any colors? RCNutt
Old Mar 14, 2012, 06:12 PM
TFM70 is offline
Find More Posts by TFM70
USA, GA, Carrollton
I bought my Doculam from this place. You can buy one roll. When I bought mine , I got the 1.5 mil 25 in. wide by 250 ft roll. $15.25 per roll plus $5.95 shipping. It works pretty good on balsa, haven't used any on foam, but I read somewhere that it works good on foam. You can paint it with Walmart $1 spray paint.
http://www.oregonlam.com/Laminating_...e.html#1525250
TFM70 is offline Find More Posts by TFM70
Old Mar 14, 2012, 07:13 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
You can get Doculam from Staples in about 16 in. width about 6 or 8 ft. for a few bucks. Works great on foam and takes paint well as TFM 70 says. There are different brands of document film at Staples but havn't tried them.
Gord.
Discussion Using High Temperature Films on Foam for Trim hoppy Painting and Finishing Tips 0 Dec 11, 2011 10:05 PM
Discussion Best covering material for foam? wparsons Scratchbuilt Indoor and Micro Models 12 Nov 25, 2011 07:21 PM
Question Looking for opinions on 1st balsa ARF CD68 Electric Plane Talk 24 Sep 06, 2011 11:02 PM
Discussion Advice on covering films wanted (wot4) checkcanopy Painting and Finishing Tips 4 Jul 26, 2010 08:49 PM
Question Plastic Iron On Covering Films Whorges Sailplane Talk 9 May 17, 2006 02:56 PM
