Old Apr 26, 2012, 05:12 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
Originally Posted by bobepine View Post
I shall try that. Thanks for sharing, dk.
c05's on this bug? Bwahahaha! I'm curious as to how you mounted the motors, but the thought of it makes me laugh. If it worked, this would be a mean little bug.
Best,
Chris
Yeah still working out the bugs on this one. Might not work at all but what the heck right??? Here is what she looks like and the motor mounts. I used the old tail servo mounts for the 4G6 and mounted a set of MiniCP landing skids to the battery tray.
dkfuji is offline Find More Posts by dkfuji
Old Apr 26, 2012, 08:20 PM
Air Vaca is offline
Find More Posts by Air Vaca
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
Hi Darryl,
Good luck! Hope it works better than the BL ufo#8. We found [aside from no props] that a lower kv motor [4000-5000] was needed. The gyro induced an over compensation occillation. ..and the gyro gain wouldn't go low enough to stop it.
regards,
Bill
Air Vaca is offline Find More Posts by Air Vaca
Old Apr 26, 2012, 08:54 PM
klamp54 is offline
Find More Posts by klamp54
United States, PA, Sayre
Joined Apr 2012
Originally Posted by Balr14 View Post
I don't want to start any debate or argument, but if you like the Ladybird you would probably also enjoy the Blade MQx. It's a lot bigger, but still a micro so it's better suited for outdoors. They both have very similar flight characteristics, the MQx has sharper response. Flight time is about 10 minutes. I enjoy flying both of them and switch back and forth between batteries. I love the durability of these little guys!
I'd have to buy a Spektrum™ 2.4GHz DSM2™
klamp54 is offline Find More Posts by klamp54
Old Apr 26, 2012, 10:05 PM
afloyd82 is offline
Find More Posts by afloyd82
ladybird, miniCP, msrx, 4F180
Joined Jan 2012
love it
afloyd82 is offline Find More Posts by afloyd82
Old Apr 27, 2012, 03:17 AM
hobbyone.com.hk is offline
Find More Posts by hobbyone.com.hk
Joined Aug 2011
Just wondering is any one interested in DEVO12 with Ladybird Combo:389.5$?
http://www.hobbyone.com.hk/cn/product.jsp?id=11085
hobbyone.com.hk is offline Find More Posts by hobbyone.com.hk
Old Apr 27, 2012, 03:32 AM
jasonjetski is offline
Find More Posts by jasonjetski
Micro-Heli-Concepts
jasonjetski's Avatar
Australia, NSW, Blacktown
Joined Dec 2006
Just wondering if the case comes in the deal too.
Regards Jason
jasonjetski is offline Find More Posts by jasonjetski
Old Apr 27, 2012, 07:37 AM
RaymondM is online now
Find More Posts by RaymondM
Multirotor Promotor
RaymondM's Avatar
United States, MI, Cadillac
Joined Apr 2011
Subscribed
RaymondM is online now Find More Posts by RaymondM
Old Apr 27, 2012, 09:21 AM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
Oversky has a new motor listed on their site which would probably perfect for the ladybug. Its a hp03 meant for a conversion for a heli tail. They have newer kv motors. Problem is expense. If I was doing the swap I think I would use the hobbyking 5gr motors here http://www.hobbyking.com/hobbyking/s...er_2000kv.html they would probably slide into the stock motor cage.
If weight is the issue then check out this one http://www.hobbyking.com/hobbyking/s...er_7700kv.html
mescalinedream is offline Find More Posts by mescalinedream
Old Apr 28, 2012, 10:40 AM
bobepine is online now
Find More Posts by bobepine
bobepine's Avatar
Joined Jun 2011
I tried even longer booms today. I installed a better light setup, as well, having received some more lights from OnceAfly. (He made about 30 of them for me. I really don't know where that guy gets gis patience from... But I appreciate his help. I couldn't do it. The soldering points are so tiny! )
The word is: Much better recovery with the longer booms. Still flips easily, but doesn't shake as much on the recovery, basically. The downside is I'm feeling the weight now. Less lift. less punch and about 30% less flight time. Mind you, I also added heatshrink to all 4 booms in an attempt to make the booms stronger. No good. The extra weight isn't worth it. I split one boom on my first hard crash despite the heatshrink. And it wasn't that hard of a crash. The next time, I will not use heatshrink. Instead, I will fill the hollow with CA glue. I realize this will seize the motor mounts and the booms together and I will have to replace the whole boom assembly if they break, but I don't care. These things break too easily.
Sorry, I don't have a stock bug for size comparison anymore. My wife didn't like it so I sold it. I shipped it to Spain yesterday.
The good thing is I have now tested too long (The above pictured), and too short (stock booms). So now I know what to shoot for the next time. I need to go about 6mm. shorter than the above and it will be the optimum length, I believe.
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Apr 28, 2012, 04:45 PM
afloyd82 is offline
Joined Jan 2012
Dang Chris good expermientation.
Im still having fun with my LB I just havent been doing much flying lately. The weather has been nice and now I have my modded mountain bike out and have been hitting the trails a lot. Putting a lot of CNC parts on the bike eats into the RC money.
Speaking of flying the LB I think ill go outside right now and pop it up into the air.
Old Apr 30, 2012, 11:50 PM
Dusty819 is offline
Find More Posts by Dusty819
United States, FL, Miami
Joined Jun 2011
Lady bird lights
Chris
Hi,i an lb and would like to put some on it can you tell me what lights i need and how you would install them,thanks.
Dusty819 is offline Find More Posts by Dusty819
Old May 01, 2012, 06:06 PM
Warrior0465 is offline
Find More Posts by Warrior0465
Joined Apr 2012
I like it, looks good
Warrior0465 is offline Find More Posts by Warrior0465
Old May 01, 2012, 06:28 PM
ForumFever is offline
Find More Posts by ForumFever
Joined Oct 2011
was going to buy one of these....noticed its made by walkera....then didnt bother.
ForumFever is offline Find More Posts by ForumFever
Reply With Quote  (Disabled)
Old May 01, 2012, 06:35 PM
Joined Apr 2012
Buy one. Mine Flys great haven't had any problems with it, flips and moves pretty fast
Old May 03, 2012, 01:00 AM
bigflier is offline
Find More Posts by bigflier
Joined Mar 2012
The QR Ladybird is available here:
http://www.hobbyone.com.hk/cn/product.jsp?id=11087
bigflier is offline Find More Posts by bigflier
Discussion Walkera QR Ladybird ScarFace_ Mini Multirotors 1781 Dec 22, 2015 08:40 PM
Discussion my UFO... test flight. not so good, but cool! areis81 Multirotor Talk 5 Feb 27, 2012 11:15 AM
Discussion So I have a defective X-ufo charger... aximbigfan Coaxial Helicopters 6 Dec 28, 2007 11:52 PM
Discussion Info needed - NY Grace 103 Mini Ventus HoverDown3K Electric Sailplanes 0 Jun 28, 2006 08:30 AM
Discussion Ok,....so you know those 1channel up/down UFO's......? Corbin_Dallas Scratchbuilt Indoor and Micro Models 2 May 11, 2006 09:53 PM
