Old Mar 12, 2012, 11:25 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
Help!
best way to fasten winglets on a wing for DS
what have the fast guys been using.. plywood tips, blind nuts and goop ..then screw the tips on using both? or long staples and goop? thoughts?? thanks.
grfcon is offline Find More Posts by grfcon
Old Mar 12, 2012, 11:28 PM
KingOfTheHill is offline
Find More Posts by KingOfTheHill
Ninja of the Nasty
KingOfTheHill's Avatar
Joined Jan 2004
are you talking about the little coroplast winglets used on a chevron foam wing?
If so i use goop and when they get really beat up i just run a Razor blade, cut them off and put a new set on.
Some people tape them on, ive seen people put thin ply at the tips and match the foil and glue them in and then screw the winglets on.
hope this helps
KingOfTheHill is offline Find More Posts by KingOfTheHill
Old Mar 12, 2012, 11:30 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I just roughen the coro up with low grit sand paper, and Goop them on using a liberal
amount of Goop. Done that way, I've never had one come off in a crash. Usually they
end up getting torn up and I have to cut them off.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 13, 2012, 12:22 AM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Just goop here too.
1000MPH is offline Find More Posts by 1000MPH
Old Mar 13, 2012, 08:52 AM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
nice thanks.. I'll just rough em up with sandpaper and goop em.
Old Mar 13, 2012, 09:36 AM
bluzharp is offline
Find More Posts by bluzharp
setting CG with ceiling fan on
bluzharp's Avatar
USA, CA, Bakersfield
Joined Apr 2010
I use Goop too. A couple of 2mm carbon sticks CA'ed in the Coro really helps keep them straight.
bluzharp is offline Find More Posts by bluzharp
Old Mar 14, 2012, 01:49 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
That too. I use a sharpened pushrod to punch a hole perpendicular to the flutes across the
largest span and then slide a thin carbon rod of the appropriate size in there to keep the
winglets from bending over and creasing.
ian
Old Mar 16, 2012, 03:23 AM
isoaritfirst is offline
Find More Posts by isoaritfirst
isoaritfirst
isoaritfirst's Avatar
Not a Brummie/but close
Joined Sep 2005
Slot x-weave tape through a small slot, like a "U" bolt to fastened onto the top and bottom of the wing surface.
Add a thin strip of tape from the LE to the outside of the winglet.
Back up with double sided tape or glue.
isoaritfirst is offline Find More Posts by isoaritfirst
Old Mar 16, 2012, 02:06 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Used to do it that way, and was constantly tearing out the coro or just ripping them off the wing tips
both in combat and DS.
ian
Old Mar 16, 2012, 05:44 PM
isoaritfirst
Joined Sep 2005
ian
You can of course run a carbon rod up the fin in line with the wing root and use the tape as described but looping over the rod as well.
Old Mar 16, 2012, 11:07 PM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
In my experience as well, I find it best not to mount too securely. Goop has worked up to 180 something...but I try not to combat...
Old Mar 18, 2012, 11:00 AM
Big Gas is offline
Find More Posts by Big Gas
Semper Fidelis
Big Gas's Avatar
United States, CA, Redlands
Joined Jul 2005
I use 2 inch lag screws with goop. 2 per winglet. Drill some pilot holes and stuff goop in there with a screw driver. Gary uses 2 two inch staples using the same goop method. I've never seen him lose a winglet. We do a lot of combat though. Our wings are usually 20-25 oz. so the weight back there is worth the not having those things fall off.
Big Gas is offline Find More Posts by Big Gas
Question What is best way to replace wing on HZ Champ winginman Scratchbuilt Indoor and Micro Models 4 Oct 04, 2014 10:09 PM
Discussion The best way to find the CG and sweep angle of a Delta wing RTF Thumper Foamies (Scratchbuilt) 3 Dec 01, 2011 09:05 AM
Question easy tidy way to fasten wing to fuselage addict Parkflyers 3 Aug 24, 2007 06:49 PM
Question easy tidy way to fasten wing to fuselage addict The Builders Workshop 6 Aug 24, 2007 12:10 PM
