Old Mar 12, 2012, 07:54 PM
topgun21 is offline
Find More Posts by topgun21
What goes up, must be repaired
Mid-Michigan
Joined May 2009
What type of wing profile would work best?
I'm interested in building a 64" high wing FPV plane to help my local Search and Rescue team scan terrain quickly. The flight characteristics I'm looking for are as follows: 1. good lifting capability 2. slow speed flight 3. can be made of FFF or other foam materials.
I've been looking the the different flavors of KFm wing profiles. Would there be a better option? I'd like to hear your opinion.
topgun21 is offline Find More Posts by topgun21
Old Mar 12, 2012, 08:31 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
What is your power and payload?
What optics?
What would be your search procedure?
And, have you done any aerial photography?
Sparky Paul is offline Find More Posts by Sparky Paul
Old Mar 12, 2012, 09:02 PM
DPATE is offline
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
What is the wing planform? (aspect ratio, taper ratio, sweep, etc.)
DPATE is offline Find More Posts by DPATE
Old Mar 13, 2012, 11:52 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
For resolution of ground objects, the AP platform will have to be flying fairly low.
With a good image resolver.
Here's some aerial shots... "Too high" is only about 400 feet for any ground detail.
The best AP platforms I've seen are the hexa-copters for stability and ability to carry large cameras.
They are noisy, though.
Old Mar 13, 2012, 04:10 PM
Brandano is offline
Find More Posts by Brandano
Paul, actually, about the comment on your 2nd photo... if you refer to the size of the shadow, it will be pretty much the same at whatever altitude the plane is. Though it will become less defined as it gets further from the ground, as the light from the sun comes from a disk that has an appreciable size in the sky rather than a point source, but it would need to be very, very high up for the shadow not to be noticeable. Sorry, I am being obnoxiously nitpick-y, I know...
Brandano is offline Find More Posts by Brandano
Old Mar 13, 2012, 05:21 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Well yeah, the shadow will pretty much be the same at any distance, due to the distance to the sun.
But.... we can cleverly use the length of the shadow to compare to some other length which is not sun-dependent, such as the wheel ruts.. and then angle-side-angle our way through the trig..
Here's two examples...
In the second, I cloned the baseline measurement to get a nice wide angle..
I'm working on winkling out altitude from the second one..
Old Mar 13, 2012, 06:06 PM
DPATE is offline
Joined Oct 2010
Just make sure you don't use angle-side-side
(Ah, those were the good ole days)
Old Mar 13, 2012, 07:26 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Those photos were just some samples of what to expect with AP.
The OP hasn't returned... ???
Old Mar 13, 2012, 09:35 PM
topgun21 is offline
Mid-Michigan
Joined May 2009
What optics?
I'm sorry I was MIA, got busy at work. The photos attached were very interesting, they all appear to be shot from a fairly high altitude. I'm thinking all want to fly lower (true field testing required of course)
Here are some answers to your questions:
Power and Payload: HXT 42-60 600Kv 43A Brushless Outrunner powered with a 4s battery, payload: 4s cell, CCD video camera, video Tx, 3s lipo to power video system
Optics: Sony HAD CCD video camera
Search procedure is yet to be worked out with the SAR team and Commander, I need to get a plane built and filed tested before we get that far. I have to crawl before I run.
I'd like the wing to have no taper and be easy to construct. We're talking easy construction (foam, glue, and CF) Any ideas?
Old Mar 14, 2012, 05:44 AM
Brandano is offline
Paul, you are quite right, I didn't realize you were estimating altitude based on the size of a known feature (as the plane shadow obviously is) on an image with a known field of view.
I was thinking in the simplistic way the cartoon shadows grow as the object projecting it is closing in, which is unrealistic but makes for good storytelling.
On the second one you can deduce altitude by measuring distance from both references and triangulation. Depending on how accurate you want to be, you can probably ignore a few distortions due to perspective, or interpolate them, to obtain the distance between the reference points. Also, you need to assume that the reference points themselves are at the same altitude.
Old Mar 14, 2012, 11:03 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
Almost any plane can carry that video system. It would be easy to buy an ARF and install the motor/battery (Lots of power there) and video system.
Otherwise the plain vanilla Clark-Y profile would be OK for a airplane of that type.. which is pretty close to a SIG Seniorita, which comes in a electric form, but much less power.
One of mine carries this external pod with the camera on a tilting mount, E-flite 25 motor, 3 cells, and is quite capable..
Old Mar 14, 2012, 11:29 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
I don't have many aerial videos looking down.. but here's one.
Using a Canon Exilim at the widest lens setting.
Note how fast the ground goes by when it's low.
http://youtu.be/MOdJP_jOgss
Weather permitting, I might get another today, with a tilting camera mounted plane.
Old Mar 14, 2012, 07:42 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Check out this video.... The superiority of a copter over a plane is evident...
Moving slowly, and hovering.. with a image down link, should be what Topgun21 would find best...
http://www.youtube.com/watch?feature...&v=uHUPKYd_vLQ
Notice the shape of the copter on the roof....
And....
Absolutely superb...
http://www.panopixel.ro/multirez/bucuresti.htm
Old Mar 14, 2012, 09:33 PM
topgun21 is offline
Mid-Michigan
Joined May 2009
Thanks!
Thanks for your help Sparky. I love the Octocopters and agree it would be an idea platform, but I can't justify the cost. If the SAR group gets government funding or some corporate grants, I won't be able to fund that out of my pocket. I like the Sig plane, I was thinking the Clark Y profile would work too. I'll experiment on a 50% version and fly it and see what I need to adjust.
Old Mar 15, 2012, 01:20 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
So many factors come into play with a design of this sort. For example how will you launch and retrieve it? Can you be sure there will be a clear road way which can be used as an impromptu operating strip or will you need to hand or rail launch it and belly flop in some nearby clearing?
What maximum range are you expecting the radio set to operate over? A conventional radio is good to about a half mile at moderate altitude. If you need more range then you'll need specialized equipment.
You'll likely want the model to break down for easier transport. So you'll want to select a design which lends itself to this design aspect.
Likely there's more that you can think of from having worked with the unit. These are just the factors that jumped into my head from reading and considering the design problems at first glance.
There's a lot to be said for the idea of a big flying wing that is a cross between a delta wing and a tapered and swept back flying wing. Such a shape will tend to be thick and rugged if operating into rough fields. Yet the large amount of wing area in a smallish span can make for lower flying speeds which translates well to possible hand launching or using a short bungee rail launch system for operating from tight confines.
BMatthews is offline Find More Posts by BMatthews
Question What is best way to replace wing on HZ Champ winginman Scratchbuilt Indoor and Micro Models 4 Oct 04, 2014 10:09 PM
Question Suggestions on what kit to build that a NEU 1105 would work in? robh Electric Sailplanes 5 Jan 17, 2012 08:42 AM
Discussion What type of motor would be best? Csad Power Systems 4 Jan 21, 2011 03:55 PM
Discussion Would this wing profile work? clipper99 Aerial Photography 1 Feb 21, 2010 05:21 PM
What wing would work? NitroSpazzz Flying Wings 2 Sep 11, 2004 11:42 AM
