Old Mar 12, 2012, 03:58 PM
bsimons is offline
Find More Posts by bsimons
Silent Quadrotor - Has anyone built one using belt driven tailrotors?
Hi All
I would love to build a quadrotor, but I can't stand the "swarm of angry bees" noise they make. After seeing ( or hearing rather) the belt-driven modification of a Multiplex Funcopter, and the variable Pitch Quadrotor from MIT, I'm inspired to make "silent" quadrotor.
My idea is to start with four belt drive tail kits. I would replace the blades with larger diameter ones, and power them with a single high-power, low speed brushless motor like the one in the funcopter. This seems deceptively easy. Has anyone tried this approach? If so, can you offer any words of warning?
bsimons is offline Find More Posts by bsimons
Old Mar 12, 2012, 04:05 PM
wizprod is offline
Find More Posts by wizprod
Denmark, Region Zealand, SorÝ
Joined May 2010
Belts and their gears will make quite a bit of noise, also, it would the craft have way too many moving parts..
What kinda noise do you mean?
wizprod is offline Find More Posts by wizprod
Old Mar 12, 2012, 04:06 PM
machina is offline
Find More Posts by machina
Linux Compatible
machina's Avatar
United States, DC, Washington
Joined Dec 2007
Been done. Well, kind of, this was a gear linkage.
http://www.openpilot.org/op-member-b...ad-using-a-cc/
machina is offline Find More Posts by machina
Old Mar 12, 2012, 04:27 PM
bsimons is offline
The piercing, beating noise that comes from four high-speed props travelling at slightly different rpms. (I have the same problem with gear-driven tailrotors like the stock funcopter tail, I guess I'm overly sensitive)
I know there will be more moving parts than the typical quad, but it should still be less complex (and easier to pilot) than a single rotor heli. Besides, I'm a mechanical engineer - this sort of thing is my bag.
Old Mar 12, 2012, 06:11 PM
tgreening is offline
Find More Posts by tgreening
It Eats Vets
tgreening's Avatar
United States, OH, Canton
Joined Feb 2012
I'm having a hard time picturing the benefit of what you're after. What could be more simple than four props direct driven straight from the motor shaft? How is adding belts and pulleys to the system going to quiet anything down?
Ok, maybe I didn't pay close enough attention. You are wanting to replace 4 motors with a single motor which controls 4 varaible pitch props instead of 4 fixed pitch correct? That makes more sense.
Still not sold on any sound reduction though. At least not enough to make a huge difference, but maybe I should check out some of those links and maybe be enlightened.
tgreening is offline Find More Posts by tgreening
Old Mar 12, 2012, 06:21 PM
wizprod is offline
Joined May 2010
Have you tried listening to a multirotor with 13" or 14" props?
t sure is less complex than a single rotor heli, however it's much more complex than a normal multirotor. The gears will be point of failures, and you'll lose energy there as well.
It'll be a fun build, but not a very energy effective one.
With your background I'm sure you have considered all this already.
Old Mar 12, 2012, 07:35 PM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
go for it but be prepared to find out why everyone else doesn't build multi's like that
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Mar 13, 2012, 11:40 AM
machina is offline
Linux Compatible
machina's Avatar
Joined Dec 2007
Also keep a computer science major nearby. You're going to have to change the code running on the FC in order to compensate for for controlling pitch and not RPM.
Old Mar 13, 2012, 02:58 PM
bsimons is offline
Good point. I wonder where the code will be different. Instead of changing the PWM signal to the ESCs, I'd be changing the PWM signal to the servos. That, and I have to figure out what speed to run the one motor at. It sounds like a fun challenge though.
(I also have to see if a double-sided belt will fit into a standard heli tail tube so that I can get two of the rotors turning backwards)
Old Mar 13, 2012, 04:17 PM
zerosight is offline
Find More Posts by zerosight
Deutschland
Joined Nov 2011
Try to find 3 or 4-bladed props with less pitch. Buy good quality motors with less rpm, high voltage and build as light as you can and you will get e pretty silent copter. I just saw (and hear) today a hexa with 9" 3-blades instead of 8" 2-blade. It was a significant difference.
zerosight is offline Find More Posts by zerosight
Old Jan 24, 2015, 08:44 AM
iamtheroboto is offline
Find More Posts by iamtheroboto
I am the robot of pop...
iamtheroboto's Avatar
Lake Chargogagogmanchaugagogchubunagungamaug, Webster, MA
Interesting to find this thread on my first search attempt.
I was thinking about something similar this morning.
The brushed motor, geared quads all over the place today are much quieter (prop noise) than a brushless direct drive quad or a similar size..... The noisy part is the gears meshing. I'd like to try replacing the gear reduction to a belt driven reduction system...
in theory it would make it much much more quiet!
iamtheroboto is offline Find More Posts by iamtheroboto
For Sale 250 size colective pitch belt driven heli quadcopter007fpv Aircraft - Electric - Helis (FS/W) 3 Jul 07, 2012 02:15 AM
Discussion Belt Driven better than Shaft Driven? shaneel Beginner Training Area (Heli-Electric) 1 Jan 11, 2012 08:39 AM
Discussion Has anyone ever tried to set up belt drive on newer trucks? PowerSet Off-road Cars 23 Jan 06, 2012 03:58 PM
Discussion Has anyone built one of these? MadDogMcQ Dock Talk 9 Nov 03, 2011 04:30 PM
Has anyone tried to build a belt driven hornet II? kevinO Micro Helis 2 Jul 06, 2004 06:39 PM
